Question about Refrigerators
Maytag MBF2256HES fridge not cold - Refrigerators
  • Anonymous May 04, 2009
    For some weeks the fridge made some noises occasionally got louder and louder until one day we really started thinking something was wrong. Within a few days, the freezer became warm and so did the rest.
    Looks like we'll loose all of our food. The soonest we can get it serviced is 4 days.
4 Suggested Answers
  • 67 Answers
SOURCE: maytag mbf2256hes fridge got warm,but freezer don't
ITS A BAD ADAPTIVE DEFROST CONTROL
Posted on Aug 11, 2009
espressonist
  • 1711 Answers
SOURCE: hi i have Maytag fridge
You can confirm this if you touch the condenser and after 1 hour you had switch it on, then the temperature of condenser should be about 130-140 F. If it is less than 120 F then you had a Freon leak.
Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
There are also many other things that can go wrong with your fridge and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly
Posted on Sep 27, 2010
bobicehouse
  • 1524 Answers
SOURCE: My Maytag refrigerator Model# MBF2256HES,
Bad damper control. http://www.appliancepartspros.com/Appliance-Parts/whirlpool-control--damper-item-number-ap4079111.aspx
Posted on Jun 11, 2011
Fridge cycles on and off every few seconds
sounds like the compressor can't start. could be the compressor itself, or the capacitor that kicks it on
Nov 13, 2013 | Maytag Refrigerators
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
I have a maytag fridge (freezer on bottom) the fridge is not very cold. freezer has started to get ice near the door opening in the last week.
if you see ice near the door the door muat not be closing all the way or the gasket could be ripped,ice will form where warm and cold air are mixing together,did you remove any of the shelves or baskets in the freezer or in the fridge?i've seen people clean out the fridge and the shelves weren't put back in correctly keeping the door open,check that or food packages that might be hitting the door,when the warm air gets in it usually freezes the air ducts,this is why the fridge is warm,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer into the fridge section and then it returns through other air ducts so if warm air is getting in it will freeze up the air ducts,you can try shutting down the machine or unplug it,remove the food from the freezer and with a hair dryer hit the back inside wall of the freezer,blow the air up into the vent holes in the back wall,if you see water dripping down through the slots you have ice up in there,keep blowing the hot air up into the holes until you don't see any more water dripping,if you can remove the ice maker and remove the back inside wall of the freezer would be better.first check the freezer back wall to see if there's any frost or like snow on it,if so you could have a defrost problem,bad jazz board,this is the computer board that's behind your digital controls in the fridge section,bad defrost thermostat or heater,also do you mean the floor of the freezer has ice on it,you could have a blocked drain in the freezer.write back with more info and let me know what you find and hopefully i can help you better.
Sep 05, 2012 | Refrigerators
I have a Maytag fridge MTF2193arw, the freezer is nice and cold with the fan working, but the fridge is not cold with no air movement.The unit is 3yr
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 15, 2010 | Maytag Refrigerators
Maytag fridge getting too cold
what happens when set on the warmest setting? still too cold then I'd think it was the thermostat. Good luck
Jul 03, 2009 | Freezers
Freezer works, fridge doesn't
freezer ok no refrig???? do you here a fan on in the freezer sect when you open the freezer door?? common problem to have a bad evap fan motor and the unit will not blow the air up to the refrig compartment
Oct 27, 2008 | Maytag MBF2256H Bottom Freezer...
Refrigerators Logo
287 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
