Question about Refrigerators
How to clean the ice/water dispenser...it is NASTY
Our ice maker dispenses just fine, but up underneath it is filthy. How can we get up in to it to clean it? Thanks
  • jummy08 Dec 24, 2008
    How do I clean the inner part of the ice/water dispenser of my GE side by side fridge? It has mold and mildew, I have not used it in months because of this.
  • 706 Answers
Without removing the entire system.. you can buy one of those inexpensive steam cleaners and wash away all the scum.. Or.. fill a spray bottle with white vinegar and spray some on the areas you can't reach..then rinse off with clean water.. ( I prefer the steam method myself since I can focus it on the specific area in need of cleaning).. Hope that helps..
Posted on Aug 29, 2008
My ice maker just stopped working. The water dispenser is working fine. I thawed and cleaned the tube running to the ice maker, but still no ice. What else should I try?
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Jul 02, 2009 | Refrigerators
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Face plate around ice maker/water dispenser needs to be removed.
there are screws on the bottom of the plate. re,oive the drain pan underneith the dispenser and the screws are underneith that.
Apr 04, 2009 | KitchenAid Refrigerators
GE GSS25SGRE side by side water dispenser...
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Aug 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
560 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
