Question about Pentax Optio S5n Digital Camera
Pentax s5n No Display Problem
Hi, I have owned my Pentax S5n for about a week now and I have come accross a problem. The steps to cause it occur as follows: 1 Turn on Camera. 2. Go to Movie Mode 3. Switch off Camera. 4. When I turn the camera on, there is no display information. The camera has the lcd running with the image from the lens but there is no information on the lcd screen and the buttons do not work (so you cannot change it out of movie mode). Pulling out the batteries and/or the memory card make no difference. To answer my own question. I found a way around the problem by total chance. I turned the camera on while holding the menu button after playing with it for about 30 minutes trying everything I could think of. The lcd starts with a black screen with the 'ver 1.00' and then starts correctly showing the movie mode. If anyone else is stressing, I have no idea what I am doing so try so at your own risk! Can anyone tell me if: a) They are having the same problem b) What I am actually doing to get the camera working c) If this is not just me, If Pentax is aware of this problem and if there is likely to be a fix at some time.
I could not see pictures on LCD screen of My Pantax Optio50
Posted on Jan 08, 2009
    Master:
  • 542 Answers
Ive got the s5n and dont have the same problem. Maybe you should return yours. Btw what software are you using to edit your videos and have you found a good way to play them through your dvd player in mpeg-4 or another format?
Posted on Sep 08, 2005
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Reset factory setting pictures
You may download a copy of the manual at http://www.pentax.jp/english/support/man-pdf/optio-s5n.pdf
Reset instructions are on page 151.
Sleep timeout is on page 148.
Auto power off is on page 149.
May 16, 2013 | Pentax Optio S5n Digital Camera
My Pentax Optio WP beeps 3 times, goes dim and turns off. The battery is charged up fully. Any suggestions?
Hi Jesslionbery,
Please try removing the memory card that has been installed in it , if any.
When you remove the memory card make sure it starts.
If the above trick does not work , try using NIMH battery instead of the ones that you have in and check if it works.
Also if you update the firmware of the camera , it may solve your problem, please find this link for more information , as the crashing problem has been resolved for many because of a firmware update.
http://www.pentaximaging.com/customer_care/show_firmware?firmId=6442215.
Hope this helps ..:)
Jun 28, 2011 | Pentax Optio T20, T10, A20, A10, W20, W10,...
My mac (10.6.7) does not recognize my camera pentax optio S5n and can not find the driver on the internet, what I can do?
hey download the drivers for your camera on this link: http://www.userdrivers.com/Digital-Camera/Pentax-Optio-S4-Digital-Camera-USB-Drivers-for-Mac-OS-Windows/download/
May 30, 2011 | Pentax Optio S5n Digital Camera
My camera fell into sea water but it is still under warrenty.... will they repair it for me?? its just 2 months i bought it..
No, they will not fix a problem caused by the owner dropping the camera in the ocean....only manufacturing defects.
Oct 21, 2010 | Pentax Optio S5n Digital Camera
Hi I have a Pentax P70, however there is an intermitent fault where the saved images are corrupted, and turn pink/purple. Any ideas what may cause this?
Try this...go into the camera menu and find "reset"...follow the on-screen instructions. Download any pics you want to save from the card. Go into the menu and find "format"...follow the on-screen instructions.
May 11, 2010 | Pentax Optio P70 Digital Camera
Largest capacity SD card for Pentax Optio S5N
The maximum supported size is most likely 2GB SD Card. Cards with 4GB and more are following a new (incompatible) standard called SDHC (SD High Capacity), SDHC cards work only in devices specifically supporting SDHC. The Optio S5N uses the old SD standard where 2GB are the maximum size.
May 17, 2008 | Pentax Optio S5n Digital Camera
Pentax K100D black spot on images
To clean the sensor on the K100D . . .
1) Turn the camera on.
2) Press the "Menu" button.
3) Press the right arrow to the "Set-up" tab.
4) Press the down arrow to the "Sensor Cleaning" item on list.
5) Press the right arrow & follow the on-screen instructions.
And don't touch the sensor with anything. (You will damage the sensor).
And don't blow on the sensor. (You will get your spit on the sensor).
I used one of those old rubber blow bulbs that people used to clean their lenses with before the Lens Pen came along.
Take care & Happing Imaging!
Glen
Apr 17, 2008 | Pentax K100D Digital Camera
Wont turn on
Usually when we see this kind of symptom it is due to an internal fuse being blown. Sometimes they blow for seemingly no reason, but once replaced the camera functions as normal and lives a long productive life. With a camera this new it is a highly likely explanation for sudden death. The fuse is not user accessible and the camera will have to be sent to a repair facility or the manufacturer for the problem to be diagnosed and the fuse replaced. David Millier Advance Camera Repair
Feb 26, 2007 | Pentax Optio S5n Digital Camera
Cracked lcd
In most cases the LCD is slightly different on most models of cameras. If there are only slight differences between models in the same line such as the megapixel rating or the internal memory the part may cross over. Models of the same camera from different production years also usually cross. I would say that VERY rarely does an LCD part cross over between model lines. Search online for a camera repair facility, you may be able to find one who would be willing to sell you the part. Be forewarned that replaceing the LCD is not always a straight forward process and there is always a chance of harming the camera in other ways while you try to fix it. David Millier Advance Camera Repair
Feb 25, 2007 | Pentax Optio S5n Digital Camera
Video clips on s5n
Your solution lies here: http://www.oreillynet.com/pub/wlg/7231
Sep 08, 2005 | Pentax Optio S5n Digital Camera
Pentax Optio S5n Digital Camera Logo
90 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Vuk B
Damen Wong
Damen Wong
Are you a Pentax Camera Expert? Answer questions, earn points and help others
