Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
Posted on Jul 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you connecct the wireless printer to my wirelss router
Anonymous
Level 2:
Novelist:
  • Expert 111 Answers
  • Posted on Jul 17, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
111
Questions
0
Helped
45110
Points
258
  • On the printer,push the MENU button,push the up or down button to go to select network then press the OK button.
  • under network menu go to WLAN then press the OK button to confirm the selection.
  • under WLAN menu go to setup wizard then press the OK button
  • when Network I/F switched to wireless is displayed ,press OK to accept.the printer will search for available networks.
  • select your SSID or network name on the list it will display then press OK.If it only showed your SSID then just press OK.
  • Use the a,b and OK buttons to choose the one of the options below:
  • no authentication or encryption or password , select open system ,press OK then choose none for encryption type.press OK.
  • No Authentication with WEP Encryption:Choose Open System, then select and press WEP for the Encryption Type and press OK.
  • Authentication with WEP Encryption:Choose Shared Key and press OK.
  • Authentication with WPA/WPA2-PSK (TKIP or AES) Encryption:Choose WPA/WPA2-PSK and press OK
  • after selecting the correct option,press OK.Always remember,WEP or WPA keys are case-sensitive.You can use the ? and ? keys to move the cursor left and right. For example, to enter the letter a, press the 2 key on the dial pad once. To enter the number 3, press the 3 key on the dial pad seven times.The letters appear in this order: lower case,upper case and then number.
  • press OK after entering the password.
  • the printer will attempt to connect to the router.If it successful,it will display the word connected on the printer.
note: you need to know the encryption type and password type (wep or wpa) for the wireless setup to be successful.you can get the info you need from your router account page or GUI.
Where is the WPS button on a netgear wireless router?
Not all routers have such a button.
Follow the instructions that came with the printer to "manually" select your wireless network, and to enter the password for your network.
Hi I have an acer imeline 5820t.Normally i connect wireless,but this morning i tried to connect and it says connected but when i try to go online it says NOT CONNECCTED,tried trobleshooter ,but that says...
try going to dos prompt or command prompt
TYpe in config/renew
press entershttp://www.thewindowsclub.com/reset-tcp-ip-internet-protocol
If it is windows 8 it could be a bug that stops the http protocol
this means the internet browser won't load up the page .
http://support.microsoft.com/kb/299357
the usual symptom you can ping the WI Fi Router at the dos prompt but the internet Browser Won't connect
Need username & password for my E1000
First check the wireless settings of your router. You will find all the wireless settings under the wireless tab.
For this you will need to access the setup page of the router by entering 192.168.1.1.
See how to connect kindle to wifi
I purchased a wirelss printer (HP Officejet 6500) and need to install it. HP says that the firewall in the router (Dlink DI524) is blocking it. Any ideas how to fix the problem and get it working. THe...
If you are using a network switch or Access Point to create wireless network, you need to access its software and turn off its firewall and if you are connecting the printer with the Bluetooth of your computer you need to turn off the firewall of your computer.
I have changed my wirelss router toa Linksys and now need to set up wirelss printing from my HP6110. how do I do this? The new wireless router is a WRT310N.
You will need to check the wireless settings of the
router
is there any computer connected to the router ?
If yes then you can open the router set up page on
that computer.
Router set up page is the page where you can check
all the wireless settings of the router.
IS your printer wireless or it is connected to the computer.
If printer is wireless then you will need to connect to the wireless network.
If it is connected to the computer and you want to share the printer then you will need to enable the file and printer sharing on all the computers.
Click here for step by step instructions
Connection to a printer
switch on your printer. then use the main terminal which will be your system to create a wirelss network connection and follow the steps in wizard. be sure to include the printer at one step.
Printing to a network via wireless router
Usually wireless routers prohibit master browser (network neighborhood) communications from traversing between the wireless and wired computers. You can usually overcome this by setting a static ip address for the computers with the printers so that they are not a moving target (addresses are always changing with DHCP). Then you can use UNC paths to get from wireless computer to your target on internal network. For example, to connect to printer (with shared name BrotherH) on a wired computer with static ip address of 192.168.0.19, on wireless computer create a network printer and manually enter the address \\192.168.0.19\BrotherH , now the wireless computer should be able to traverse and connect to the wired printer.
Your wireless router should have a pool of static ip addresses available, say 192.168.1.1-49, you can specify this to your liking, and then you can also have a block of handed out DHCP numbers, say 192.168.50-60 or whatever.
Can't make the wireless feature work
C4480 is not a wireless printer per-say.
what they mean is that if have a wirelss router you can connected it to the router and printer from any wirelss connection.
you do need a wireless source. this printer don't have one.
1helpful
Wep key
You can define a new WEP key by entering into your router's configuration (usually http:192.168.1.1) and then go to "Setup" and "Wireless". Here you can define a new WEP key.
Norman Weimar
Norman Weimar
k24674
