Question about Toshiba e570
Remote Control Earphones
How do I enable the buttons on my Remote Control Earphones for use with my Pocket PC e570?
    Master:
  • 903 Answers
When using either Windows Media Player or Windows Media Player 8 on your Pocket PC e570 you will need to program Media Player to recognise the button functionality of the Remote Control Earphones by following these steps: Select Tools, Buttons. Select each individual function and press the relating button on the remote control. After all buttons have been programmed, press OK which should take you back into Media Player. N.B. The remote control buttons will not function when playing back voice recordings as the earphones can only be used for listening in this mode.
Posted on Sep 08, 2005
Pocket e570, Remote Control Earphones
If you are going to use either Windows Media Player or Windows Media Player 8 on your Pocket PC e570 you will need to program Media Player to recognise the button functionality of the Remote Control Earphones.
Sep 11, 2005 | Toshiba e570
Initialize my Pocket PC
When you initialize your Pocket PC, the factory default values are reset to the status as when you originally purchased the Pocket PC e570. NOTE: When you initialise your Pocket PC, all data stored in the memory is deleted. Personal programs and data are permanently deleted from your Pocket PC’s. The factory pre-installed operating system Pocket PC 2002 remains intact. Before initialization your Pocket PC, remove all storage cards. To initialize your Pocket PC, please follow these steps: Turn off the power to the unit. Then press the power button while pressing and holding the reset switch with the stylus. Release the power button. When a screen appears, release the reset switch When initialization is completed, the "Welcome Screen" will appear. Set up the system according to the startup procedure as indicated by the on screen instructions.
Sep 08, 2005 | Toshiba e570
Not turn on
The Toshiba Pocket PC e570 is shipped with an Enabled security feature, which switches off the batteries. In order to be able to turn on the unit, the Battery Switch must be in a battery "Supply" position. Please check if the Battery Switch is in a Stop position or Supply position. The Battery Switch can be found on the lower left edge of the unit, next to the "Cradle Connection Port". Please see the below diagram The Battery Switch supplies or stops power to the Pocket PC. When using the Pocket PC for the first time, slide this switch to the left with the stylus pen. The Battery Switch Lock on the lower left side of the unit (see the diagram), secures the main Battery Switch to the Supply position. If you have further questions, please refer to the Instruction Manual page 2-3 (13 of 103).
"Driver is not digitally signed"
If you install the Toshiba Pocket PC e570 via USB cradle under Windows 2000 or Windows XP a warning message may appear durning this installation: The driver for the USB cradle comes from Microsoft and is integrated in the ActiveSync 3.5 Software. This driver has not been signed, therefore this warning appears. Please Note: This is only a warning messages. You can certainly continue with the installation, and expect the driver to run well. Microsoft has produced a new ActiveSync Version 3.5 and has released it 1st of March 2002 . The issue is solved in the new version. The version number has remained the same, but the Build Number has increased form Build 1176 to Build 12007. This new ActiveSync Software can be downloaded from the Microsoft.
Windows CE Program's
On the new Toshiba e310, e570 and e740 Pocket PCs, Microsoft's new operation system Pocket PC 2002 is installed. The question whether Windows CE programs run under Pocket PC 2002 has no definite answer. Most Windows CE Program will run under Pocket PC 2002. Pocket PC 2002 is an improved version of Windows CE, or rather, the next generation of Microsoft PDA operating systems. Some parts of the internal architecture of the operating system, like the e-Mail system, are of a complete new design and in fact, quite different. So if you run older Windows CE programs using "old and possibly, changed parts of Window CE system", it is quite possible that the Windows CE program will not run or will not operate correctly. Tip: To avoid problems or data loss, we suggest using Pocket PC 2002 programs only. Please note: Pocket PC 2002 is only available for Intel "Strong ARM" processors. This is different to Windows CE, where several CPU's types were supported. Only Windows CE Programs for Intel Strong ARM" processors may run an Pocket PC 2002.
Sep 08, 2005 | Toshiba e310 Pocket PC
Sep 07, 2005 | Toshiba e330 Pocket PC
Print
To be able to print from your Toshiba Pocket PC you will need additional software such as PrintPocketCE. This software allows you to print using Infrared, Bluetooth, Wireless network and serial connections.
Sep 07, 2005 | Toshiba e570
Synchonize
To synchronize your Toshiba Pocket PC (e570, e310, e740) with your notebook over a Infrared connection, please follow the below instructions: Ensure that the Microsoft program ActiveSync is installed on your notebook Ensure that the infrared port of the notebook is enabled Line up your Pocket PC IR lens with the IR-lens of the notebook On your Pocket PC, please on to "Start" and select for the menu "ActiveSync" Tap with Pocket PC pen on "Tools" in the left lower corner and select "Connect via IR.." The synchonisation will start automatically. Simple follow the on screen instruction to complete the process Please see below:
Sep 07, 2005 | Toshiba e310 Pocket PC
"Pocket PC 2002 Update 1.0"
Microsoft Pocket PC 2002 Update 1 official statement This document provides useful information for end users and IT professionals to successfully update Microsoft® Pocket PC 2002 with the Microsoft® Server ActiveSync® client. It also outlines improvements to the Pocket PC 2002 software included in the update. New Feature: Microsoft® Server ActiveSync® client gives users the ability to synchronize directly through Microsoft® Mobile Information 2002 Server with their Microsoft® Exchange Server. Improvements: Improved support for Point-to-Point Protocol (PPP) connections to correct problems experienced when connecting to read e-mail or browse the Web while away from the office. Improved connection support in instances where a specific Internet Protocol (IP) address must always be used. Connection Manager no longer reverses static IP addresses and Domain Name System (DNS) server names. Improved Pocket Outlook Object Model (POOM) support for additional programs you can download or buy for your Pocket PC 2002. If you encountered problems with new programs crashing on your device, this update will help prevent future crashes. Improved viewing of Wireless Application Protocol (WAP) pages. Improved e-mail support for Simple Mail Transfer Protocol (SMTP) servers. Further improvements have benn made in the following features: PPP Networking Connection Manager POOM (Pocket Outlook Object Model) WAP Inbox To download this MS Pocket PC Update 1.0 from our Download files area click here Download and unpacking instructions: To download the file, simply "click" the desired file or link and select save to disk. Download the file to a known directory on your hard disk drive. For example: c:\Temp Open Windows Explorer and locate the "downloaded file" on your hard disk drive. Use an unpacker program to extract the files to a known location on your hard drive. The shareware WinZip unpacker can be downloaded from http://www.winzip.com
Toshiba e570 Logo
82 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
