Question about NetGear WGR614 Wireless Router
Wireless computer not working
I have a netgear router the two wired and one of the wireless connections are working. I don't know how to fix the other wireless. I have tried setting up a wireless network, but I'm doing something wrong. the net gear connection will not even open.
  • Carl Navarro
    Carl Navarro May 11, 2010
    It has to. How are you connecting to it?
  • 37 Answers
1. make sure that the wireless card is properly installed in your computer. (if it is a laptop, make sure that the wireless switch is on).
2. make sure that the distance of the wireless router and wireless pc is not very far
3. if you know the wireless configuration of your router proceed with number 4, if not see my note below.
4. right click the wireless icon on the pc, choose 'view available wireless network' or connect to a network.
5. check if your SSID is showing. If it is showing and it says secured, click on it and enter your encryption (either WPA or WEP or WPA2).
6. if SSID is not showing, go to the router configuration page and change your channel. play around with your channel until your non working pc sees the SSID.
note(checking router configuration): on the wired pc, open internet explorer browser, type http://192.168.0.1 (default username is admin & password is password or 1234) Note: if you changed your ip address or password on the router, use that.
Posted on Oct 21, 2008
    Problem Solver:
My tg585 v8 wifi wireless LEDlight is orenge its OK orNO
Posted on Apr 03, 2011
THE WI-FI FROM NETGEAR DOSNT WORK
What is the model number of your router?
Is it Linksys or Netgear. You have selected Linksys router and you are asking about Netgear router?
Please explain the problem in details.
How many wired and wireless computers do you have?
Do you have any computer wired to the router?
Can you access the Internet on the wired computer?
If the wired computer is also not working then I think you many need to check the Internet connection on the router.
If only wireless computer is not working then you should check the wireless settings on the router and the computer.
What is the operating system on the computer?
I can suggest you few websites which may help you.
Try Fix Home Network
Try How to connect to the Wireless on your computer
May 19, 2012 | Linksys Wireless-G WRT54G Router
The CD is not available for installation is it necessary? I have all of the cable if the Yellow cable connects to the cable router what does the white cable on the wireless router connect to. Thank...
If the cables supplied have RJ45 connectors then they are used for connecting and configuring the wireless settings in Netgear router and to connect the Netgear to the DSL modem foe Internet access.
Most likely the color of the cables is not important.
To configure the wireless settings, connect a cable from one of the LAN ports (not the WAN/Internet port) to the LAN port on your computer. You may remove this cable after configuring the wireless settings if you want to connect to the Netgear by wireless only. You need to connect other computers to the Netgear's LAN port with a cable if they do not have wireless cards installed in these computers.
The other LAN cable is used to connect the Netgear WAN/Internet port to the DSL modem so you computers can connect to the Internet via the Netgear router.
Follow these instructions to configure the Netgear router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 23, 2011 | NetGear WGT624 Wireless Router
Netgear wireless wgr614 is configured and the ports wired connected and is working ok while wireless portion the laptop running vista says connection is limited and unable to browse
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Apr 07, 2010 | NetGear WGR614 Wireless Router
I ordered a wireless router so I can hook up my PS3. My computer is not compatible with wifi so I thought I'd just leave it hooked up to the modem. The instructions tell me to put the CD into my computer...
You have to use the computer to insert the CD
As your computer is not wireless compatible, you can have this connected to the router itself on the wired connections and use PS3 on wireless
Do NOT connect your computer to modem and also Netgear to modem.
Either one of them won't work. Instead connect modem to Netgear and computer to Netgear with an ethernet cable.
After this type of connection is made, try to setup the router with the CD inserted into computer.
This is how things work!
Jan 22, 2010 | NetGear WNR1000 Router
My wired connection to the router works fine but the wireless connection is not working
What have you tried?
Is this a new router? (Some Netgear have wifi turned off by default)
do you see the SSID name on your computer?
Has it ever worked?
It does happen that the output transistors fry so it works wired but not wireless
JOAT
Oct 10, 2009 | NetGear MR814 Wireless Router
Netgear connection
is that wired connection or wireless? if it is wired, checked the cable and the port, make sure that the LAN connection is enabled.
if it is for wireless, checked the wireless settings of the router, enable the wireless card of the wireless computer and, verify the wireless settings of the netgear adapter and from there connect to it.
Jun 26, 2009 | NetGear DG834G Router
Netgear Wireless Router won't work with my Linksys wired router.
As asked above, why would you want the wired router and the wireless router on the same network?
The direct answer to your question(s) is found on Netgear's website. http://kb.netgear.com/app/answers/detail/a_id/965/kw/wpn824/r_id/166
The key is to turn off the Netgear DHCP, and give it an address that is unreachable by the Linksys DHCP ie if the Linksys gives out IP addresses starting at 100 or 101, you set your IP address to 99, turn off the DHCP, and plug it into the network NOT using the WAN port, ever. We tend to start at 251 or 221 just for clarity's sake.
The point is you answered your own question. The Netgear wired and wireless works fine. One piece of equipment and better reporting statistics....what are you missing?
Carl
Apr 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
Connecting Netgear Wireless Router to @Wire Wireless Router
You don't need to connect your netgear, you have only to connect your computer to the 2Wire (is wireless also) - If your computer ins not wireless Only you have to do is insert a wireless PCI card in your computer or and USB wireless device and connect to the 2Wire Wireless Router
Feb 11, 2009 | 2wire HomePortal® 1800HW Router...
NETGEAR WIRELESS
More details are needed here, do you have mac address filtering on and is your router using dhcp or fixed address for your computers?
Jan 17, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
203 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
