Question about Garmin GPSMAP 180 GPS Receiver
Garmin gps 180 does not power up
Please let me know what wires need to be hooked up i connected red to power and black to ground & it does not turn on
  • Anonymous Mar 31, 2014
    I tried to hardwire my Garmin GTM 26 into my motor home, but when I cut the charger wire, I found that the positive wire was shrouded in an outer layer of copper wiring mesh. I went ahead and connected the red wire to positive and the white to negative, but there is no power flowing to the GPS. What should I do?
    Problem Solver:
  • 5 Answers
Lcstryper, I'm looking at my manual and you have it wired right, red power, black ground. Manuel also says to hold button down until you hear the power tone sound.
Got a meter, check to see you have power where you hooked it up.
Seadrive Joe
Posted on Aug 29, 2008
What is the connection path from Garmin 72 to raymarine c80, using NMEA 1083
I'm taking this as you want to send the gps information to your C80 not receive from the C80? If this is the case the brown wire on the garmin is the nmea data out +. The Black wire is considered nmea out neg (-) of the garmin. So hook the garmin brown to the white on the raymarine. Hook the black from the garmin to the green on the raymarine. That means you are outputting lat/long info to the raymarine from the garmin.
Jan 14, 2012 | Raymarine C80 GPS Receiver
I have a SI-TEX black box receiver and I'd like to connect it to a Garmin GPS chartplotter. The SI-TEX black box receiver instructions at one point say:"If the GPS has a NMEA output (or NMEA REF) connect...
Yes, the NMEA- output (I think you lefy uot the "-" in your questoin), anyway, the NMEA - or NMEA negative or NMEA ref is hooked to battery supply ground.
Dont forget to program the Garmin to look for 48,000 baud data.
Jan 10, 2010 | Boating
To wireup 160c Garmin fishfinder, there are seven clored wires. The book shows red and Yellow to hot. Black and blue to ground. Do the white, green and brown connect? Can the black and yellow be connected...
You only need the red and black wires to supply power to the unit. The red positive wire goes to a positive terminal on your battery or positive side of a bus bar or switch, the black negative wire goes to the negative terminal on the battery or negative common bus bar. Do not try to earth the black wire to an aluminum boat hull... You are asking for trouble! Best to run the black wire straight back to the negative battery terminal or negative bus bar that is wired to the negative battery terminal. The other colored wires on the 160C plug are used for interfacing with NMEA2000 compatible devices, like a compatible GPS.
Jun 14, 2009 | Garmin Color Fishfinder 160c
How to hardwire to HD motorcycle
Black or ground to chasis, Red to battery if you want it to have power all the time.
To the fuse box to a switched line if you want it to turn off with the bike.
Be sure to have a fuse in line with the power wire to prevent damage to the GPS umit or a fire on the bike.
May 23, 2009 | Garmin zumo 550 GPS Receiver
I need a wiring legend for the Rampage BA200 sub woofer
Red - power
Black - ground
Blue - turn-on (switched 12 volt)
Green and Gray -- Hook to factory/aftermarket stereo for the signal.
Jan 14, 2009 | Car Audio & Video
Malfunctioning Garmin GTM 20 fused GPS power adapter
The two red wires are +VE Supply and both connect to pins 1 and 2
The two brown wires are Supply Ground and both connect to pins 8 and 9
Pins 3 through 7 are the traffic recievers digital interface:
Purple/violet connects to pin 3
Yellow connects to pin 4
Blue connects to pin 5
Black connects to pin 6
Green connects to pin 7
Dec 30, 2008 | Garmin GTM 12 FM TMC Traffic Receiver...
GPSMAP 180 power/data connector
Okay
guys: book says:
PIN 1 (red) 10-40 volts DC
PIN 2 (black) Ground
PIN 3 (blue) NMEA out Shows this goes to Autopilot/NMEA devise and to RXD positive RXD negative goes to ground (black)
PIN 4 (brown) NMEA in Goes to GBR 21 Beacon Receiver to a blue wire, brown wire on thaat devise goes to PIN 3 and the negative goes to ground
PIN 5 (white) no connection
PIN 6 (Green) no connection
PIN 7 (yellow) goes to alarm low Shows going to negative terminal on alarm relay and positive terminal goes to PIN 1 (red)
All Greek to me, have fun
Seadrive Joe
Feb 03, 2008 | Garmin GPSMAP 180 GPS Receiver
Garmin 525s will not turn on
This is a common problem with 400 and 500 series garmins.  The only fix is to take it back and exchange it.  There has been a software update to prevent it from happening but once it powers down it's too late for the update.  This has been a known problem since they hit the market in May. Any respectable retailer should exchange it with no questions asked, especially if you just bought it.
Oct 25, 2007 | Garmin GPSMAP 525s GPS Receiver
Garmin GPSMAP 180 GPS Receiver Logo
357 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
