Question about Freezers
Whirlpool Freezer Hi, I have a Whirlpool Bottom Mount freezer. Model is EB22DKXFW01. I noticed the freezer was slowly (like over the course of a week) getting less and less cold. It still didn't go all the way warm, but steaks were getting pliable! I took everything out, removed the back panel (inside the freezer) and saw that the fins, wires, lines, etc...were caked in frost. I unplugged the unit, and let it thaw out. I took the panel off of the back of the fridge and got most of the water out of the drain pan. At this point, I have left the cover inside the freezer off to watch it and see how it does. It is freezing fine, but I am not sure that it is defrosting. The defrost timer is working, because I can hear the little motor running and the dial moves/clicks on/off. However, the fins seem to be building up frost quickly again (over the course of 2 days). Defrost heater? Thermo switch? I only know what I know from talking to people and searching the web, so don't assume that I actually know what a part looks like or where it goes (except the timer). Any help would be appreciated! Thanks! Jason
  • calebsun Aug 31, 2008
    That was, in fact, the problem. Thanks for your input!
    Scholar:
  • 62 Answers
Most likely you have a defrost problem. IF, you think the timer is ok then the most likely problem is the bi-metal. That is a little part usually on the top right side of the evap coil and has two wires on it. If you can find the defrost timer and advance it slowly till the refrigerator stops running, then being in the defrost postion you can see if the heater is coming on. If so you have a bad timer. If NOT, then either the heater or the bi-metal is bad. Usually it is the bi-metal
Posted on Aug 31, 2008
Our Whirlpool upright freezer has a sheet of ice in bottom at drain--why?
Melt it again, and check it runs down the small drain hole, If not, clear the hole with a drinking straw. If it keeps freexing up, you may need an auxiliary heater added to the drain hole.
May 24, 2014 | Freezers
Freezer doesnt work anymore
try unpluging for 6 hours ,remove all items from vent area. if it gets to hot compressor can lock up if so call a repairman
Feb 19, 2018 | Freezers
The freezer compartment does not seem to be working properly. Top part an everything is frozen but further down it it less cold an on the bottom draw the ice is slowly melting
From your indications, it sounds like your evaporator fan is not functioning and evenly distributing the cold air throughout the freezer.
Jul 07, 2011 | Zanussi ZX57 / 3 Freezers
Hi we have recently moved to a house an we have inherited a fairly new whirlpool chest freezer which works very well but there is a lot of condensation on the outside which results in small pools of water...
The insulation between the inside and the outside of the freezer haas become water logged, This can be twmporarilly remedied by switching off the freezer and letting the insulation dry out for a few weeks, less in hot dry climates, but the solution is temporary and the problem will reoccur. To have the foam replaced means a complete strip down of the freezer and is seldom worth the cost. I am sorry, but you will probably have to get used to living with the problem. Incidently, it does make inroads into your electricity bills.
Jan 16, 2011 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
One side of freezer has stopped freezing... bottom is not frozen
You have either got a blockage in the system or there is a leak. My bet it is a leak. Seen this many times on the whirlpool.
May 28, 2010 | Whirlpool 14.8 cu. ft. / 419 liter Chest...
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
Feb 05, 2010 | Freezers
Whirlpool upright freezer AFG823NF-Thermostat not working properly
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
Feb 03, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezers Logo
128 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
