Pentax Optio S5n Digital Camera Logo
A
Anonymous Posted on Sep 08, 2005
Video clips on s5n
I am not able to playback any video clips taken on this camera....I am using a fairly up to date Mac running panther and quicktime 6. Does anyone have any mac based advice?
Anonymous
Level 3:
Master:
  • Master 542 Answers
  • Posted on Sep 08, 2005
Anonymous
Master
Level 3:
Master:
Answers
542
Questions
37
Helped
55345
Points
1594
Your solution lies here: http://www.oreillynet.com/pub/wlg/7231
1helpful
My macbook pro recognized my JVC JY HD10U but won't recognize the image from the screen in order to import what I've filmed.
I am not sure what software you are trying to use, but if you are using quicktime for example to import your footage it should be very easy. Once you connect the camera in playback mode to your macbook with a firewire cable open up quicktime then go to file-> New Movie recording. From there it should see a camera connected but no video. Hit the record button and then start playback on the camera. You should then see the video start to record onto the mac. Let the entire video play though and when it is done hit stop and you have you files! You can now use those in virtually any video editing software!
Hope that helps!
tip
Convert Canon MXF files to ProRes 422 for Final Cut Pro X Editing and QuickTime...
Canon XF Plugin not work for FCP X-MXF files Import to FCP X for Convert MXF to ProRes <br />Best Canon XF video converter on Mac-Canon XF100 to ProRes for FCP X <br /><br />I have a Canon XF100 and would like to get the videos to FCP X. However, there is no Log and Transfer option, and the iSight runs when I click the camcorder button on FCP X. I googled and noticed that there is Canon XF plugin for FCP 7, but <b><a href="http://www.aunsoft.com/video-converter-mac/">Canon XF plugin not work for FCP X</a></b> yet. <br /><br />As Canon XF Plugin does not work for FCP X, I have to look for the workaround for editing Canon MXF files on Mac. I find Aunsoft Video Converter for Mac as a great tool to make the videos compatible to Final Cut X. It would <b><a href="http://prores-converter.com/2011/07/convert-canon-mxf-files-to-prores-422-for-final-cut-x-editing-and-quicktime-playback/">Convert Canon .mxf files to ProRes</a></b> 422 and ProRes 422 (HQ), so that I can import into Final Cut X, export ProRes 422 at the same settings as the original and play it with QuickTime. <br /><br />Below is the simple step-by-step guide to convert Canon MXF files to ProRes 422 for Final Cut X editing and QuickTime playback. <br /><br />First, download Canon XF100 videos to Mac with Canon XF Utility. You will get the folder with files like .CIF, .THM, .MXF and .SIF. <br /><br />Second, import .MXF files to Aunsoft Video Converter for Mac. Just run it as best <b><a href="http://canon-videoconverter.com/2011/07/convert-canon-mxf-files-to-prores-422-for-final-cut-pro-x-editing-and-quicktime-playback/">Canon XF video converter on Mac</a></b>, then click the Add button to import .mxf files or drag and drop the files to the application UI. <br /><br />Third, choose Apple ProRes with 1920x1080 output. Click the format option to choose Final Cut Pro &gt; Apple ProRes 422(*.mov) as output format. Click the Settings button to choose 1920x1080 as video size. <br /> <br />Fourth, click the convert button under the preview window to start converting Canon XF100 files to ProRes for FCP X. <br /><br />Soon after the conversion is done, you can import the <b><a href="http://www.aunsoft.com/video-converter-mac/">ProRes files to Final Cut X</a></b> and enjoy HD video editing and playback. <br /><br /><b>Tips:</b> <br />If you are using iMovie, Final Cut Express, just choose Apple Intermedia Codec as output format for HD video editing.
tip
Sony TX7 to iMac Converter-Deinterlace 1080i MTS to QuickTime MOV Cyber-shot...
Cyber-shot DSC-TX7 is a new camera by Sony for consumers to shoot 1920x1080i and 1440x1080i AVCHD videos in .mts format. The camera also includes MP4 output, but only with 1440x1080p, 1280x720p and 640x480p resolution. To get HD 1920x1080 videos, the output videos is .mts as file extension. This format provides high definition videos, but is recorded with interlacing artifacts.
However, to play Sony TX7 camera AVCHD videos on big-screen iMac smoothly, I need HD video converter for Mac. I find Aunsoft MTS/M2TS Converter for Mac as the perfect Sony TX7 MTS to MOV Converter on Mac OS X to handle my movies. With this Sony to MOV converter, I can show my recent trip to my relatives and friends from iMac, sharing the joy and experiences.
Here are the steps I used to convert and deinterlace 1080i AVCHD videos to H.264 MOV for playing my Nevada trip on QuickTime Player.
Step 1. Load Sony TX7 MTS to Aunsoft MTS/M2TS Converter for Mac.
After transferring Sony DSC-TX7 AVCHD videos to Apple iMac hard drive, run Aunsoft MTS/M2TS Converter for Mac as Sony MTS converter and click the "Add" button to load .mts videos.
Step 2. Choose H.264 output format.
Click the "Format" option and choose HD Video > H.264 HD Video(*.mov) as output format. The Mac Sony TX7 MTS to MOV converter will transcode 1080i .mts videos to 1080p .mov for QuickTime on Mac.
Tips: You can also choose the .mp4 output format for playback on iMac, as QuickTime Player supports .mp4 videos.
Step 3. Convert Sony TX7 AVCHD to MOV.
Click the convert button under the preview window, and the Mac Sony MTS converter starts converting Sony DSC-TX7 MTS to MOV in full HD 1920x1080.
After the conversion, I show Sony TX7 camera videos at home to relatives with big-screen iMac. Take Sony TX7 camera or other AVCHD camcorders for your travel, and it is easy to show relatives the recent wonderful trip with the HD videos and beautiful scenes.
on Aug 03, 2010 • Cameras
2answers
Computer cannot read and play the .mp4 video files from my Sanyo XActi CMOS 1920X 1080 .Is there a software I can download from the net?
Yes.
This is what the Sanyo CG9 Users Manual has to say about viewing videos taken with the camera:
"About video clip files recorded with this camera
You can use Apple’s QuickTime to play back video clips on a computer.
Playback may be possible using other software that supports the ISO
standard MPEG-4 AVC/H.264 (AAC audio)."
There are many ways to view mpeg-4 videos, but the one that is recommended for your camera from the CG9 support webpage is apple's quicktime available from apple here.
tip
Flip video to mov converter for mac,best converting flip video to mov on Mac OS...
MOV as a multimedia container file is widely welcomed for its high compression ratio and perfect
definition.
[url="http://www.flip-converter.com/article-flip-mac/Flip-video-to-mov-converter-mac/"]Mac flip to mov converter[/url] is specially designed for Mac users to convert flip videos(Flip Ultra, Flip Mino, Flip Ultra HD and Flip Mino HD) to MOV format on Mac OSX, besides, other mainstream video files like avi, mpeg1, mpeg2, mpeg4, m4v, wmv, 3g2, 3gp, dv, mkv, mp4, flv can also be converted by the program. The converted formats can work well with many video players, such as Windows Media player, iTunes, QuickTime, iMovie, Final Cut Express(FCP) or some popular portable devices like: iPod, iPhone, Zune, Apple TV, PSP, Gphone,
Palm, iRiver, Blackberry and different mobile phones.
More and more Mac users adore free software QuickTime to entertain themselves with enjoying movies, video clips, music. as a file extention, the MOV file type is primarily associated with 'QuickTime' by Apple Inc.
the QuickTime (.mov) file format functions as a multimedia container file that contains one or more tracks.
Flip camcorder give people a new way to save and share their happy moments, its convinent and easy-to-use, but for the flip camcorder users, not all the time you can successfully import your flip video to Mac’s
QuickTime for playback
[url="http://www.flip-converter.com/article-flip-mac/Flip-video-to-mov-converter-mac/"]Best mac flip to mov converter [/url]can convert your flip video to mov for QuickTime on Mac OSX10.4Tiger, v10.5 Leopard and v10.6 Snow Leopard. It has corresponding codec to assist you to convert Flip video to mov for QuickTime.
Downloading videos to imovie on a Mac
Apple Quicktime downloads are available here.
1helpful
3answers
I can't download my videos from my JVC GZ-HD7U into my PC using Magix Edit Pro.
It happens because you didn't install the quicktime plugin. once the quicktime is installed it will show the preview of the video so you can make your selection.
download the quicktime plugin: http://www2.cli.co.jp/products/ne/update_qtc_for_gzhd7/qtc3e_update.htm
if not download the VLC player. it will nearly play every format. Choose your .tod file and play it on vlc. http://www.videolan.org/vlc/
hope its helps :) by the way i got the same camera :P
Optio 330 Avi (Motion Jpeg) playback problem under WinXP
Do you have quicktime installed? From what I remember there it uses a quicktime codec.
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
