Question about Sharp 20F-630 20" TV
Connecting the video camera to a computer
I have a video camera Sharp Model VL-H860 serial No.909398620, works very well and I wonder If would be possible to save the tapes in a PC since the computer has the same three jacks (video, audio left, audio right) like a TV have when connecting the video camera as a VCR. My computer is a Gateway GM5442 serial No.CCW74 710 01950 If so, how can I do it, is there any software to be installed and where can I get it.
Thanks for your advise
Vicente Orellana
  • vicenteo Sep 01, 2008
    Absolutely insufficient. All you say is "try using nero", but what is "nero", you have to understand that I am not an expert and for such reason I asked your assistance and the answer has to be clear. If there is not a person with the capacity to answer my question, it is ok and please refund me the payment.
    Thank you very much.
    Vicente Orellana
  • vicenteo Sep 05, 2008
    Following your instructions, I got NERO but it didn't work. If you check such software, it has the following menu options: Start page, Rip and burn, Create and Edit, Home entertainment, Back up, and under "Create and Edit" I found the only applicable option for my problem and it is "Author, edit, and captures video". Under this option I selected "capture video to hard drive", then "capture device" but the two options are for TV channels and no one for VCR (video camera). I spent many hours trying to capture the video camera and I couldn't. I hope you can find a real solution.
    Vicente Orellana
    Master:
  • 763 Answers
Does your camcorder has a USB? tell me exactly the problem or what do you want to do. let me know the other interface too if it has no USB interface. id like to help you with this cause ive already use some kind of you camcorder but i cant remember if it has a USB slot.
CHARCOIS
Posted on Sep 05, 2008
    President:
  • 1,263 Answers
In... order for the computer to rcognize your video camera you have to install a driver. if you do not have a driver install cd you can download the driver from your cameras manufactures web site. once this is accomplished you will then be able to hook up through your patch cables and when you do a screen will come up with option tabs. this will allow you to transfer your files. if the files have a different format. a window will pop up and you will be able to download the codec that will allow your computer to read the files. this may take some time but be patient please rate this ......thanks
    Sergeant:
  • 241 Answers
Hi there there are free programs for you to download. If your computer has the same connections as the camera you are one step ahead I have some links for you and there are many programs that let you convert the analog /tape signal to a digital format
Posted on Sep 01, 2008
  • Jayson Brollini
    Jayson Brollini Sep 01, 2008
    If your movies are in 8mm or Hi8 format, you have a simpler option:
    Today's Digital8 camcorders can play those older formats just fine.
    That means you don't have to rig a Rube Goldberg-style plumbing system
    from your VCR to your camcorder to your PC. Instead, just put your old
    Hi8 tape in the camcorder, press Play, and capture the video in digital
    format on your PC.
    Unfortunately, you can't do the same for VHS.
    VHS and mini-DV tapes are so different that no camcorders can play
    both. Digital8 camcorders, on the other hand, can read analog 8mm tapes
    because Sony intentionally designed the format for backward
    compatibility. Score one for Sony.
    Making MoviesFinally,
    now that the video is on your PC, all you need is some DVD production
    software to finish the job. DVD software can help you break the video
    into chapters, add menus at the beginning of the disc, and write the
    whole video to a recordable DVD using your PC's DVD-R drive.
    To
    date, the only consumer drives capable of writing to the widely
    compatible DVD-R write-once format have been DVD-RW and the
    latest-generation DVD-RAM models. Soon, however, second-generation
    DVD+RW drives will offer the capability to write to DVD+R write-once
    discs. Industry experts suggest that movies on both DVD-R and DVD+R
    discs should be compatible with about 85 percent of home DVD players.
    Movies put on DVD-RW and DVD+RW rewritable discs, on the other hand,
    tend to work with only about half the home DVD players out there. Of
    course, compatibility is less likely with older DVD players.
    Some good DVD production packages include Pinnacle Systems' Pinnacle Express (about $34), Sonic Solutions' MyDVD ($79), and Ulead's DVD MovieFactory (about $44).
  • Jayson Brollini
    vicenteo
    can you see my post? I hope this will help you
    I need to know so that I can help you with the problem at hand.
    Please make sure that you PC has those connections
    in most cases you have JUST the video input Yellow/ or a S-Video
    Your audio on the back is in a smaller type connections. It looks like a small phone jack. You might have that cable already with your camera if not you just need a (female mono Y-Spliter to RED and White Males Plug) this is found at any store that carries elctronics
    Rate the Advise from FixYa ExpertKindofcheap
    President:
  • 1,952 Answers
Http://www.myzips.com/
carpet with an attached cushion can be installed quickly and easily using a good ... consider upgrading your Adobe Reader software to the latest version, .
    Master:
  • 521 Answers
Nero is a software cd .which you get at any computer shop to load the sofware you wanted to make the connection between pc and camera.
without that software of nero it would not happen as you want to do.and for cables and other connecting wires contact
www.radioshack.com
pls do rate the solution
thanks.
regards.
fixya expert team
  • 6,487 Answers
Yes you can do that .try checking this link for some tip http://www.neonet.on.ca/docs/newsletter/wirednewstimmins/2004/septwirednews.pdf
Hope that helps.......
Posted on Aug 28, 2008
    Master:
  • 623 Answers
You can do that...try using nero
Its a sharp vl-h860 hi 8 dis
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support
heatman101
Apr 26, 2011 | Cameras
I need to transfer my sharp VL h860 Hi 8 tapes to my computer to burn them to DVD. Whats are my options? Thanks!
You can get videos from this camera, or any analogue video source, into a computer, but you need more than just a cable. You have to play them into an analogue video interface port. These are available as expansion slot cards for a desktop PC, or as a USB plug-in interface (which is what you need for a laptop). The interface will come with drivers and probably software to digitise the video input and record it to a file. Lots of third party video editing software will also be able to accept the input from this kind of port. You don't need any "driver" related to the camera, it is just a video signal source. The connecting leads will be standard RCA signal plugs, like the ones you use to connect to a TV or VHS recorder. You probably already have a lead for this.
Once you have the video on the computer, you will need DVD "Authoring" and burning software, which will usually come as part of the same package. You can download such software for free from the internet- my first stop would be www.download.com.
Jan 31, 2011 | Sharp VL-H860U Camcorder
How to connect my sharp VL h860 Hi 8 to my computer
Searching for an S Video Cable for Sharp VL-H860U HI Camcorder
Nov 08, 2010 | Sharp VL-H860U Camcorder
Hello! I have a very old Sharp VL-H860 camcorder. We don't use it much, but yesterday we were trying to watch old videos on the camcorder, and it won't play. It makes a strange buzzing noise, the screen...
I also have one and it works great but I don't have the audio/video adapter on the side so I cant view my films on TV. I would be interested in your camcorder or maybe vise versa? Regards, Pete
Dec 27, 2009 | Sharp VL-H850U Camcorder
My camera is a sharp VL-AH131 HI8i got an inverse image at the VIEWCAM, and while I turn the lens, there's certain position where it is right, but it's not where it should be.
Sorry, i haven't a solution just wondered if u new where i could find the audio and video leds for this product asi have tapes but can't transferethem to vhs, dvd, avi without the leads, hope you can help me....George..
Mar 25, 2009 | Sharp VL-AH131 Camcorder
I HAVE a sharp viewcam vl-h860 hi8
If you're pretty sure the camera is just dead and have already resigned yourself to buying a new one you could just pry the door off and get your wedding tape out. There are lots of places that can transfer it to VHS or DVD for a small fee. On another note, I have a camera just like it, have lost the AV cable and can't seem to find a replacement online. Care to sell me yours? If so send me an email at turnerts@charter.net. Thanks!
Staci
Mar 04, 2009 | Sharp Viewcam VL-AH130U Camcorder
NEED DRIVER FOR SHARP VIEWCAM MODEL VL-PD3AE
http://www.sharpusa.com/products/TypeSoftware/0,1086,47,00.html
If I had a model number it would be alot easier
Oct 19, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Sharp 20F-630 20" TV Logo
63 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
