Question about Toshiba e570
Initialize my Pocket PC
How can I initialize my Pocket PC e570 to factory default?
    Master:
  • 903 Answers
When you initialize your Pocket PC, the factory default values are reset to the status as when you originally purchased the Pocket PC e570. NOTE: When you initialise your Pocket PC, all data stored in the memory is deleted. Personal programs and data are permanently deleted from your Pocket PC’s. The factory pre-installed operating system Pocket PC 2002 remains intact. Before initialization your Pocket PC, remove all storage cards. To initialize your Pocket PC, please follow these steps: Turn off the power to the unit. Then press the power button while pressing and holding the reset switch with the stylus. Release the power button. When a screen appears, release the reset switch When initialization is completed, the "Welcome Screen" will appear. Set up the system according to the startup procedure as indicated by the on screen instructions.
Posted on Sep 08, 2005
2 Suggested Answers
SOURCE:
  • 903 Answers
SOURCE: Initialize my Pocket PC
I have sony DSC-W190,i want correct menu setting ,bcos if i take a picture its not clear,i think may be menu setting changed,idnt any idea about menu setting pls help.....
If the Menu settings in the camera is changed, then I suggest you to reset the Camera back to factory default. Initializing the Camera back to factory default will set all the settings in the Camera back to factory default.
To initialize the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
You can also try a manual reset;
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
The blurry image capturing can also adjusted by changing the ISO Settings or the Scene Selection modes.
Thanks for using FixYa!
Apr 07, 2011 | Sony Cyber-shot DSC-W190 Digital Camera
How do i factory reset my guitar pedal?zoom gfx 707
ZOOM 707II and GFX707 All Initialize/Factory Recall The patches in the USER group can be returned to theoriginal condition at any time, even if you have changed them. The All Initialize function returns all patches inthe USER group to the default condition. Factory Recall can be used to reset only specificpatches in the USER group to the default settings. 1. Turn power to the 707II on while pressing the[STORE/EXECUTE] key. The indication "ALINIT" appears on thedisplay. - To perform All Initialize, proceed to step 2. - To perform Factory Recall, use the TYPE [down]/[up]keys and [down]/[up] foot switches to select the patch that you want to return to the factory default condition. (The bank andpatch number are shown on the[BANK/PATCH] indicator.) 2. Press the [STORE/EXECUTE] key once more. All Initialize or Factory Recall is carried out. If AllInitialize was carried out, the unit automatically returns to the play mode. The contents of patches stored by the user will belost when the defaults are restored. To cancel All Initialize/Factory Recall, press the[CANCEL/EXIT] key before step 2.
Feb 23, 2011 | Audio Players & Recorders
Como resetar o gfx8
zoom GFX-8:
The All Initialize/Factory Recall function is a special function
that lets you reset the GFX-8 to the condition in which it was originally shipped. When All Initialize is performed, all settings of the unit including all user group patches are returned to the default condition. Factory Recall can be used to reset only specific user group patches group to the default settings.
1. Turn power to the GFX-8 on while keeping the STORE key depressed.The display shows "ALL-INIT".
• To perform All Initialize, Continue with the next step.
• To perform Factory Recall, Use the BANK UP/DOWN foot switch and foot switches 1 - 4 to select the patch (from a user group) that you want to return to the factory default condition.
2. Press the STORE key once more.
If All Initialize was carried out,
Note that when All Initialize is executed,
the contents of all patches stored by the user will be overwritten (erased).
When wishing to cancel All Initialize/Factory Recall,
press the EDIT/CANCEL key before step 2.
source: ZOOM GFX-8 User Manual.
Oct 13, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
How to reset to factory specs
There are two types of Reset options for the DSC-H9 Sony Camera, one is power reset and the other is Initialize. Follow the steps below to power reset the Camera:
Remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds.
Then, reinsert the batteries after 1 minute.
Initialize:
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.
HOME-->SETTINGS-->MAIN SETTINGS 1-->INITIALIZE-->OK
Aug 07, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Pocket e570, Remote Control Earphones
If you are going to use either Windows Media Player or Windows Media Player 8 on your Pocket PC e570 you will need to program Media Player to recognise the button functionality of the Remote Control Earphones.
Sep 11, 2005 | Toshiba e570
PocketPC e570, Is there an opportunity to set it back to factory default?
you could set back the e570 factory default very easily. On the left side of the pda you could find a small button, called RESET button. You have to do these following steps: The pda have to be turned off, then press the power button while pressing and holding the reset switch with the stylus, release the power button and when a screen appears, release the reset switch. But be careful, when you reset your pda all data will be lost and make sure that all storage cards are removed!!!
Sep 11, 2005 | Toshiba Genio e550
Sep 08, 2005 | Toshiba e570
When you initialize your Pocket PC, the factory default values are reset to the status as when you originally purchased the Pocket PC e330 or e310. NOTE: When you initialise your Pocket PC, all data stored in the memory is deleted. Your Pocket PC's initially installed programs are not deleted. Before initialization your Pocket PC, remove all storage cards. To initialize your Pocket PC, please follow the steps: Turn off the power Press the power button while pressing and holding the reset switch with the stylus. Then release the power button When a screen appears, release the reset switch When initialization is completed, the Welcome screen appears. Set up the system according to the screen as in the case of startup procedure.
Sep 08, 2005 | Toshiba e330 Pocket PC
When you initialize your Pocket PC, the factory default values are reset to the status as when you originally purchased the Pocket PC e740. NOTE: When you initialise your Pocket PC, all data stored in the memory is deleted. Your Pocket PC's initially installed programs are not deleted. Before initialization your Pocket PC, remove all storage cards. To initialize your Pocket PC, please follow the steps: Turn off the power Press the power button while pressing and holding the reset switch with the stylus. Then release the power button When a screen appears, release the reset switch When initialization is completed, the Welcome screen appears. Set up the system according to the screen as in the case of startup procedure.
Sep 08, 2005 | Toshiba e740 Pocket PC
Not turn on
The Toshiba Pocket PC e570 is shipped with an Enabled security feature, which switches off the batteries. In order to be able to turn on the unit, the Battery Switch must be in a battery "Supply" position. Please check if the Battery Switch is in a Stop position or Supply position. The Battery Switch can be found on the lower left edge of the unit, next to the "Cradle Connection Port". Please see the below diagram The Battery Switch supplies or stops power to the Pocket PC. When using the Pocket PC for the first time, slide this switch to the left with the stylus pen. The Battery Switch Lock on the lower left side of the unit (see the diagram), secures the main Battery Switch to the Supply position. If you have further questions, please refer to the Instruction Manual page 2-3 (13 of 103).
Toshiba e570 Logo
142 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
