Question about Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
Electriic oven control broken
I need to replace the "control panel" which is the clock, timer, oven temp up and down buttons et on my mgr4452bdw... the control buttons do not work and the panel hass pushed in from the metal piece on top. i have located the part (74010453) is this a very difficult repair for a fairly mechanically inclined woman?
thank you!!
  • 3 more comments
  • champster22 Oct 05, 2008
    THE TEMP CONTROL BUTTON WILL NOT LET ME INCREASE THE TEMP.......... PAST 350 DEGREES..............I CAN REDUCE THE TEMP USING THE DOWN BUTTON,THE UP BUTTON WILL NOT WORK,
    champster22@hotmail.com
  • dixlbc Nov 01, 2008
    I have the same problem but only the bake button does not register unless I clean the contact on the board with a Q-Tip. Even then it goes back to not working after a few days or hours.
  • mellojoi Feb 08, 2009
    The control pannel will not allow us to change the oven temp. It's permanently on the default temp of 350. Is it worth fixing?
  • levibarjonas Apr 01, 2009
    Cannot increase temp.
  • Anonymous Apr 22, 2009
    My control panel has also fallen in on itself.  The more button doesn't work, either.  The landlord thinks he can fix it, but I am far from optimistic.  How much does the replacement part run?  Not that I have to pay for it, but the owners are in a "budget situation".  I can't wait to us the oven again!
Maytag #mgr4452bdw the clock will not set the face reads 5-A-6 and the oven will not come on
Posted on Oct 10, 2008
For Kenmore 7903019400 wall oven error code F 11, the touchpad/keyboard is the replacement part called the clock/timer? as clock/timer or range control panel are only parts listed? so which part is it
F11 means a shorted button on the button board. This could actually be a shorted button, or it could be a bad connection to the embedded microprocessor. There is literally no way to tell without actually testing the unit. If the EOC module (electronic operator control) comes with a button pad, change them both out if you can't test them separately. Kenmore has other manufacturers make their equipment for them (frigidaire, whirlpool, electrolux, etc), so the generic equivalent board may be cheaper to buy somewhere else than sears. Your local appliance service center will know what parts fit what sears models. The model number you provided is useless to me. 25321842-21syibu3fgwpdxocjnkpw0ib-3-0.jpg
Dec 14, 2014 | Kenmore Kitchen Ranges
I have a black Maytag Gas Range stove the oven wont heat up. The ignition what i think it is, is glowing but when I tap the bottom of the stove it will light. What part do I need and where can I get it....
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Maytag MGR4452BDW / MGR4452BDQ /...
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
No lights on the control panel including the clock. the burners work but no lights at all for the oven or timers ets. MAYTAG Model: MER6769BAW
I would check the wiring first. Look for any loose connections to the board or any burnt wires. If all that is good you have no choice but to replace the clock.
Sep 17, 2010 | Maytag MER6769 Gemini Electric Kitchen...
I just replaced both the igniter and safety valve for the oven. When I plug in the oven, the oven comes on and stays on without setting the bake temp. The flame wont go out unless I unplugthe power
Your electronic oven control(clock) has failed in a short circuit mode.
Approximate cost is $120.
Go to repairclinic. com and enter your model number for a replacement electronic oven control.
Jan 10, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
Water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Jan 06, 2010 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Whirlpool oven/ temp decreases when increase control is pressed
you need to replace the ( e o c ) the clock ) it's lost the ability to comprehend your needs .. the 350 start up is normal / but the up arrow should increase temp .. time should not be changing .. replace the clock / this part # 4452240 is n l a ) your clock can be sent in to be repaired / only . hope this info will help .. & 238.00 last price on this clock .
Dec 02, 2009 | Dishwashers
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Oven not heating to proper temp
go to: RepairClinic.com
you'll need make & model #.
Nov 16, 2008 | Frigidaire Ovens
Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range Logo
507 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal De GO PATS
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
