Question about HP iPAQ HX4705 Pocket PC
Ipaq 4705 wont connect to internet
My 4705 used to connect to the internet via wi-fi or while in the cradle. Since upgrading firmware in the 4705 it will not, and it seems like it is not recognizing its network adapters. Has anyone else had this happen after a flash update. All else seems fine with the ipaq. Thanks.
    Master:
  • 450 Answers
Try running through this WI-FI setup tutorial, its very helpful. http://wifi.aximsite.com/
Posted on Sep 08, 2005
SOURCE:
Ethernet conection dosen't work
More than one computer or just one? Sounds like something wrong with the computer lan port.
Jan 10, 2013 | Computers & Internet
My new zte v9 wont connect to the Internet
you can access the Internet through the mobile network or via Wi-Fi.Your mobile network settings are pre-configured by your serviceprovider and there is no need to change any settings. Wi-Fi Wi-Fi provides wireless Internet access over distances of up to 100meters.1. Tap Home > Settings > Wireless & networks .2. Select the Wi-Fi check box to turn Wi-Fi on
Dec 02, 2012 | ZTE V9 Smartpad Android Internet Tablet
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
I have a Netgear DG834G v4. Wireless connection is fine, ISP is fine and Internet via wireless is perfect. Nothing via the LAn ports seems to work. Both XP and Win 7 machines see Lan as an undefined...
DHCP SERVER in Router and DHCP server in Wireless Conflicting - Set WI Fi DHCP router leases to say 192.168.0.10 to 192.168.0.100 and default gateway as 192.168.0.1 and on the router set the router's ip address to 192.168.0.1 make the Wi Fi router address 192,168.0.2 . Set in the router the DHCP address leases to 192.168.0.101 - 192.168.0.254 and default gateway 192.168.0.1 or deactivate one of the dhcp servers and rely on one dhcp server like the routers and then deactivate the wi fi's dhcp server.
Jul 28, 2017 | NetGear DG834G 54 Mbps 802.11g Wireless...
HI...CANT CONNECT MY IPAQ HX4700 WITH INTERNET(WIRELESLY)I CAN SEE MY NETWORK ON SCREEN,BUT DONT WANNA ACCEPT NETWORK KEY.IAM SHURE THE KEY IS CORECT.RESULT OF WI-FI SELF TEST SAYNG:YOUR WI-FI IS NOT...
Are you sure you got the key correct? You sHure have problem getting your spelling coRect. If you are sure, check if you got the encryption protocol (WEP, WPA, WPA2) and sub-protocol settings correct, and check your SSID, key number (1-4), etc.
Jan 17, 2011 | HP iPAQ HX4700 Pocket PC
My blue ray player claims to have built in wi fi; but I can't seem to get it to hook up to the internet, it keeps telling me that it is missing hardware
Hi devinanne, please don't shoot the messenger as I am just answering your question. This Blu-Ray player does not have wi-fi for any purpose. And the only reason it connects to the internet is for software/firmware upgrades. For that, it must be connected via the LAN port on the rear just above the USB port via an ethernet cable.(See page 44 of your manual). It does have Anynet+ which means it can control all of your Samsung audio/video devices from one remote.If you have any further questions, don't hesitate to ask. If I answered your question please give 4 thumbs up. And thanks for using FixYa.
Jeff
Nov 23, 2010 | Samsung BD-P1500 Blu-Ray Player
Wi fi connectivity
Refer to
http://www.fixya.com/support/t189947-ipaq_rx_3715_internet_settings
for a potential solution, as someone else had the same problem.
Jul 02, 2007 | HP iPAQ RX3715 Pocket PC
Connecting a Ipaq RX3715 to a wireless router
First, you have to be sure your ipaq has wi-fi feature is on and you can check on network connectivity option for any wrong setup there. According to your information, your ipaq is not recognized by your router and I agreed that your router is working normally. Try to reboot your ipaq and be sure to get wi-fi to turn on and try to connect it again. I have my Dell Axim also used Windows Mobile like Ipaq and it connected easily with no issue. The message in your to show me that you need first to identify your ipaq before you you can get it to connect to your network. I hope this help.
Mar 05, 2007 | HP iPAQ RX3715 Pocket PC
Hx2410 general wi-fi questions
Have you been able to connect through your router at home? I'd get that set up and running first. Then doing it on the road will merely be variations on a familiar theme. If you've tried at home but it hasn't worked, let us know something about your home network (what kind of router? using security/encryption?), and about what you've already tried so we can try to help.
Sep 08, 2005 | HP iPAQ hx2410 Pocket PC
Connect to the Internet
There are many things to look at when setting up WI-FI to work with your iPAQ. Here is a good link that walks you through the WI-FI setup, with helpful screenshots. Its a good place to start, hope it helps! http://wifi.aximsite.com
Sep 08, 2005 | HP iPAQ HX4700 Pocket PC
HP iPAQ HX4705 Pocket PC Logo
165 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
