Question about Mitsubishi WD-52525 52" Rear Projection HDTV
60" Mitsubishi TV - Approximately 6 years old
I came home from vacation to find that apparently the electricity had gone off while I was gone.
I turned on my TV and I have sound but only a large ball bouncing around the screen.
Any idea what I can do before I call a serviceman?
  • 927 Answers
Good Day;
Try resetting the TV and any BOX by unplugging both for @ to 5 minutes then plug back in.
Good Luck, big IRISH.
Posted on Sep 28, 2008
My mitsubishi tv is almost 3 years old and it has no picture but it has sound
Video board malfunctioning....Get a honest TV tech. Only three years old? It is worth repairing, will deliver several more years of excellent service. A quality television.
Mar 31, 2013 | Mitsubishi WD-62526 Projection TV
The picture on my Mitsubishi WD62725 is starting to show some wavy lines and snow. We had a repairman come and he said that it needs a new chassis which would run around $550 and he said that it was not...
If the set is 6 years old I would not put $550 into it, but a new 60-65 DLP should only run you from 1200-1800. If you check around you will find alot of Mits DLPs on the internet for even less.
Jan 08, 2011 | Mitsubishi WD-62725 62" Rear Projection...
I have a 9 year old mitsubishi projection tv
Could be a problem in the high voltage section or a bad signal board. Let the TV tech do it.
Good luck
N Sabre
Nov 08, 2009 | Mitsubishi VS-60607 TV
Mitsubishi VS-60609 60 in. no pix /has sound
My Mitsubishi TV model VS 60609 is showing double vision on the screen.
Feb 24, 2009 | Mitsubishi VS-60609 60" Rear Projection...
I have a tru tech 17 in with DVD player. I HAVE NO SOUND.
I'd replace the power cable before replacing the tv. Ebay.
Feb 11, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Mitsubitshi wd 52725
Good Day;
From you said you should call a Factory Authorized Service Center, toooo many problems with TV for non-tech person.
Sep 13, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Autoprograming
get the original remote.....i had to. it costs $95 thru best buy(special order it takes 5 days)
Sep 15, 2007 | Mitsubishi VS-60603 60" Rear Projection...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi vs 60719 - Wavy bow in picture
Either a bad solder connection on your convergence module or a bad convergence IC. Repair costs will probably be in the $350-$500 range.
Jan 28, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
29 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
