PC wont Boot/start
My pc wont boot or start, i turn the power on and the fans spin and the HDD and power indicator lights go on but it wont boot. the screen is blank and there is no sign that the computer is doing anything. Ive looked around for a solution and couldnt find one, i returned the motherboard and they said it worked fine but it still wont work for me. specs: 256MB LEADTEK PX7600GT EXTREME - graphics Foxconn S939 NF4UK8AA-8EKRS - Mobo Corsair Tx 2GB 3200 C2 - Main memory AMD Athlon 64 3700+ 2.2GHz - Processor i dont have a clue what the problem is and anything to help wouldbe greatly apreciated! thanks When I turn on my pc it wont go past the boot up page, I've been told this may be a motherboard problem but not sure. Any suggestions would be great.
  • moluv122 May 08, 2009
    I have the same problem. I changed the power supply from 300 to 450. Now the fans come on, but will not start or boot. There are no lights & nothing on the monitor. Only the fans are working.
  • 397 Answers
The first thing you should do is swap the power supply for a known good one,
If this is a new build that hasn't worked from the start follow the instructions here:
Posted on Aug 27, 2008
Acer am1100 won't start up
Discribe what happens when push the on/off button and you try to boot, fan spin? LED's blink? HDD/DVD light blink? Sound? Any thing on screen at boot? What blue light?
Feb 26, 2013 | Acer Aspire AM1100-B1410A Refurbished AMD...
Acer Aspire 5542 wont startup
Bring it to a repair shop and have them check it out. They should at the very least be able to recover you data.
Jun 29, 2012 | Acer aspire 5542 1615
PC start up failer
  1. remove the two rear screws and remove all the cards attached to the main board
  2. unplug all the cables that connect from the drives to the board.
  3. power on the unit
  4. if the unit powers up, install one of the cards you removed and complete step 3
  5. if the system does not power up, the last card or device activated will be your culprit and will need to be replaced or left out.
if you find that your system will not show a bios splash screen with all the other components removed, then you are looking at either a video, or power supply failure. Listen to your system for spinning fans and hdd activity. touch the hdd if you cant hear it when you power up the system, paying close attention to when the drive activates. It should activate almost immediatley, pause, and then run for a short boot period. if nothing, then if may be your power supply. you will not be able to see any lights at all, no light on the motherboard, drives, or power LED is the best indicator of a shot power supply
Good luck, please rate this post
Mar 23, 2010 | Acer Aspire E500 PC Desktop
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
4600 Sluggish Boot Up
sounds to me like a failing psu, you may need to test it with a psu tester if you have one available, if not any local pc repair shop should have one
Oct 31, 2009 | Dell Dimension 4600 PC Desktop
My hp dv9000 will not boot. when power is turned on all leds light up screen stays black. hard drive and fan can not be heard. restarts after 10 seconds with no error message or flashing lights.
Remove the hdd cover from the bottom and make sure it is completely seated and connected. If the hdd is properly installed and it still will not boot, try entering the CMOS Setup. If you can enter setup you most likely have a bad hdd. If you can't you need to take or send the pc to a repair shop.
Oct 06, 2009 | HP Pavilion dv9000z Notebook
PC wont start/boot
hello...i think you need to check all socket connection on the board and you need to check the memory or try to reset the Bios.or check the ATX power supply it is good or working..thank you
May 08, 2009 | eMachines D3415 PC Desktop
Toshiba 5205-S503 Laptop- No power
- You may want to try to reseating all neccessary things on the system like optical drive,hdd,memory but before you do that disengage the power from the system like the ac and battery.
-If no..go try to remove the optical drive first and then turn the system on, then if the system boot without the optical drive shut it down and put back the optical drive and boot to bios and load the default setting and boot the system normally.
Oct 11, 2008 | Toshiba Satellite 5205-S503 Notebook
Computers & Internet Logo
547 people viewed this question
David Payne
David Payne
