My TV was working fine and I pushed what I thought was the Volume on the side of it, but instead i changed the channel and now the TV is saying " no Signal" I think its as easy as changing the channel back, but when I flip through the options it does not get a single on any of the channels and I can not punch in any numbers with my remote, it does not respond to the TV, just the cable. What Should I do?
  • 520 Answers
It sounds like you are on one of the video inputs of the tv. Look for a button that says input, aux, video, etc. on the set or remote.
Posted on Aug 28, 2008
I hit the Channel button on the side if the tv instead of volume and now I have no picture can't change the channels just says no signal ... What did I do?
Sounds like you may have set it to an "input" channel. You may have to go into your menu to change it back!
Mar 23, 2012 | Televison & Video
I have lost my remote and the kids pushed the side buttons on the TV to raise the volume but instead changed the channel. Now I can't get back to the channel that works with my AT&T uverse box.
Instead of changing the channels, press the "INPUT" button on the side of the TV slowly and repeatedly. The TV will cycle through all of the available external inputs one of which will be for your Uverse box. If this doesn't work, try switching to channel 3 or 4. I can't say which will be correct as it depends how the equipment is setup.
Hope this helps.
Regards,
BElectric
Jan 07, 2011 | Vizio VX32LHDTV10A 32 in. LCD HDTV
"No Signal" on the TV
have you try to reprogram using menu setup/auto channel /before programming in tunner set upcoose cable
after reprogram select channel 3
hope that will helps
regards Alan
May 11, 2010 | Vizio L37 Television
Hi, remote not working and unable to change channels using tv buttons. other buttons on tv - volume etc are working fine
if your remote is for cable, then you have to push the cable button, then change channels. volume will work only on tv mode.
Oct 06, 2009 | Sampo PME-50X7 50 in. HD-Ready Plasma...
Up and down arrows on channel or menu selections not working.
All the functions of in putting and selections channel are done by one stage of a tv. take your tv to a w/shop, it wll require change of components,
get a diagram from
www.universal.remote.net/zenith.html
further help will be provided
Dec 06, 2008 | Zenith B25A02Z TV
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Can change the sound with my remotes
I recently bought a GE universal remote control, SKU: 24950, that has a control code for the AOC A17W221 TV. I bought mine at Target. You can check online to see if your local store has one before you go there. It's also listed on the GE site under consumer electronics accessories with a price. Don't know if they sell it online, though.
Mar 15, 2008 | AOC A17W221 17 in. HD-Ready LCD Television
Volume and channel control on TV not working
The control board is defective. Is in warranty so call Sharp to have it fixed.
Dec 29, 2007 | Sharp LC 37D62U 37 in. LCD HDTV
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
