Question about Compaq Presario 5BW284 (202493-003) PC Desktop
Sound card how can i get my sound back on the computer?
  • don-y Oct 20, 2008
    I have installed a new windows 2000 to this computer and there is no sound. I think I need a driver but I need to know for what sound card and I donot know where to find it.
  • Anonymous Jan 03, 2009
    No audio at all. downloaded drivers; no change. computer shows no audio device.
    Problem Solver:
  • 17 Answers
What operating system and name brand/model number of computer?
Posted on Aug 28, 2008
I just got a new video card and remved all the cords then pluged it back in then the sound says no audio output detected what do i do?
Video Cards do not interact with audio, so somewhere in the process you may have dislodged or incorrectly reinstalled your sound card or wires connecting your motherboard. Check to make sure the speakers are plugged into the sound panel on the back of the PC, also open the computer and make sure that the sound card (if you have one) is securely fastened into the motherboard.
Mar 14, 2011 | Packard Bell Speaker Computer Speakers
Sound
More than likely, your sound card is hard soldered to your motherboard.  Look on the back of the computer where you plug your speakers and microphone in.  That's your sound card.
Do you have a problem, why you need to find where it is?
Oct 21, 2007 | Compaq ES1373 PCI Audio Card EURPs...
My computer has no sound..i think it is not installed..i don't know how to fix it
  1. Step 1 Shut down the computer.
  2. Step 2 Unplug machine from the surge protector.
  3. Step 3 Disconnect all peripherals from the computer.
  4. Step 4 Remove the cover of the chassis and lay computer on its side if it is a tower.
  5. Step 5 Ground yourself to the computer. If you have a grounding strap, put it on and follow its directions. Otherwise, ground yourself by touching a metal part of the chassis.
  6. Step 6 Remove the back panel, if necessary.
  7. Step 7 Locate the existing sound card if there is one already installed. If it is screwed in on the side of the slot hole, unscrew it and pull the card out firmly.
  8. Step 8 If the computer doesn't already have a sound card, find an open slot.
  9. Step 9 Knock out or unscrew the metal plate on the card's slot holder on the back panel.
  10. Step 10 Insert the sound card gently but firmly into the slot. Rock it into position if necessary, but don't force it. Don't touch any connectors on the card.
  11. Step 11 Connect cables from the CD-ROM drive to the sound card.
  12. Step 12 Replace the back panel and any removed screws. Screw sound card into slot holder if it has a screw hole.
  13. Step 13 Reconnect monitor, keyboard, and mouse. Connect speakers to the sound card's ports.
  14. Step 14 Turn on the speakers and restart the computer.
  15. Step 15 If Windows detects the sound card upon startup, follow instructions to install the card's driver and additional software. If Windows doesn't detect sound card, manually complete the installation using the Add New Hardware control panel.
  16. Step 16 Play music CD to test sound card.
  17. Step 17 Shut down computer.
  18. Step 18 Replace cover of computer. Reboot computer.
Aug 16, 2010 | Computers & Internet
How to installsound card
Assuming this is a store bought card...
Put the card into one of your computer's PCI slots
Install the driver your product came with
or
Go online to the manufacturer's website and find the driver there!
Apr 10, 2010 | Computers & Internet
I want installed sound device in my computer
Turn off your computer, unplug it from the back of the computer. Now take off the side the computer, look on the back and find your old Sound Card. Now ground out your hands by touching something metal before you reach inside your computer. Now remove the old Card and install your new one, reboot and the computer will ask you to install the new software for the Sound Card or it will find it for you.....good luck.
Mar 27, 2010 | Microsoft Windows XP Professional for PC
EMachine T2862 has no sound
If your computer does indeed have a Sound Card, then the drivers for this card are not working. Try reinstalling from the driver disk you got with your computer and see if the sound comes back.
Nov 01, 2009 | Computers & Internet
Color coded plugs for on the back of computer
Yes, in fact, you have a nicer (newer) sound card as opposed to the single channel types of the past. This type of card will work with the surround sound speakers for computers, as long as it's functioning properly.
Oct 24, 2009 | FIC REFURBISHED EVEREX IMPACT GC3500...
No sound
it is easy to find whether in your compute has sound card or not... just check backside of the computer... if there is sound port besides default port then . you also can open (unscrew) the computer and can check whether the card is inserted into the soundcard slot or not... easy way
if this didn't work you can follow thee following steps..
Step11 Check the front or back of the computer to see if there are audio jacks for speakers, microphone or audio inputs. These plugs are typically in a standard color code of green, pink, and blue. If you can find no plugs available, then it is a good bet that the computer doesn't have a sound card installed.
Step221Open the control panel, Start>Settings>Control Panel. Look for the icon that says "Sound and Audio Devices." Open the icon and look on the "Sounds" tab. The sound device used for audio appears in a box in the upper portion of the screen. There should also be entries in the last three tabs. The last tab is the "Hardware" tab. It will list all the available audio and sound devices on the computer. Step332Right-click on the "My Computer" icon and select "Properties." Click on the third tab and then select the "Device Manager." The Device Manager shows all the hardware on your computer. It displays any devices it cannot identify under "Other" with a yellow question mark. These may be the sound card. If there is nothing listed under "Sound card" and nothing under "Other", then you don't have a sound card in your computer.
Apr 26, 2009 | Computers & Internet
I was about to install a PCI sound card TM P1018 in my cpu. How will i do it?
Shut down the computer. Unplug machine Disconnect all peripherals from the computer. Remove the cover of the chassis and lay computer on its side if it is a tower. Remove the back panel, if necessary. Locate the existing sound card if there is one already installed. If it is screwed in on the side of the slot hole, unscrew it and pull the card out firmly. 8If the computer doesn't already have a sound card, find an open slot. 9Knock out or unscrew the metal plate on the card's slot holder on the back panel. Step10Insert the sound card gently but firmly into the slot. Rock it into position if necessary, but don't force it. Don't touch any connectors on the card. Step11Connect cables from the CD-ROM drive to the sound card. Step12Replace the back panel and any removed screws. Screw sound card into slot holder if it has a screw hole. Step13Reconnect monitor, keyboard, and mouse. Connect speakers to the sound card's ports. Step14Turn on the speakers and restart the computer. Step15If Windows detects the sound card upon startup, follow instructions to install the card's driver and additional software. If Windows doesn't detect sound card, manually complete the installation using the Add New Hardware control panel. Step16Play music CD to test sound card. Step17Shut down computer. Step18Replace cover of computer. Reboot computer.
Apr 24, 2009 | Computers & Internet
FoxConn SoundCard Removal
take the side off your computer to gain access to the sound card. Then look on back to see which card has the speaker plug ins then take the one screw out of the sound card on metal plate connecting it to the computer box. Then slide it out. Then put it all back together again. and restart.
Nov 03, 2008 | Creative Labs Sound Blaster Live! 5.1...
Compaq Presario 5BW284 (202493-003) PC Desktop Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
