Question about Canon FAX-JX200
FAX-JX200 Canon "Clear paper jam" cleaned code strip and tried unblocking it dont know if its a sensor issue.. Please help?
Check for paper jam, unplug from power if same servie=ce
Posted on Oct 23, 2008
My Canon ip 2772 Printer does not works. It says Error 6000. What Can i do? there is no paper jam in my printer. Plz Help
Try these:
Solution 1:
  • Verify that the paper tray is correctly set.
  • If any object is placed in front of the machine, remove it.
Solution 2:
  • Search for any small pieces of paper in the printer, or a tiny object.
Solution 3:
  • Power off the printer
  • Wait 5 minute
  • Power on.
Solution 4:
  • Clean the encoder strip with a soft cloth
Solution 4a:
Jun 01, 2015 | Canon Pg40 Ink Cartridge for Fax Jx200,...
I tried to print something and the paper got jammed and now I have an error code 5100. What does this mean and how can I clear it? I have removed the jammed paper. please help me
the solution is to clean the strip film,look for the paper sensor is not broken or blocked
5100 means
- Carriage unit
- Timing **** film
- Logic board
- Carriage motor all this
Feb 24, 2011 | Canon PIXMA MP830 All-In-One InkJet...
My canon fax-JX200 indicating check 5100
1. Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2. After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jul 05, 2010 | Canon FAX-JX200
Canon JX200 wont work.
Have you checked if all paper has been cleared?
If yes, then may be a sensor got blocked through the paper path.
With the help of a small brush, have the paper path cleared.
I think this should be able to solve out the problem.
Mar 30, 2010 | Canon FAX JX200 Fax / copier Plain Paper...
Clear paper jam
may be there is small pice of paper inside just remove that.
Jan 20, 2010 | Canon FAX JX200 - Fax / copier - ink-jet...
Manual for canon fax jx200 Problem Not faxing or copying Green light blinking? showing"!! 6000!!" which is number code of problem
This is a link to Canon for your Fax JX200 Users Guide.
http://gdlp01.c-wss.com/gds/0900007827/FAX-JX200_JX201_Users_Guide_EN_US.pdf
CHECK 6000 code:
LineFeed signal is not detected.
The paper feed in the printer is not detected, the motor may be defective, or the transparent plastic disc on the motor, respectively, the corresponding sensor.
Nov 20, 2009 | Canon FAX-JX200
Hi my fax displays the message CHECK 5100
my fax Canon JX201 displays the message CHECK 5100
Jun 26, 2009 | Canon FAX-JX200
I have an Intellifax 2820 and there is an error message of paper jam inside... I have cleaned all paper out of machine... please help me
A jam sensor may be stuck by a paper scrap. Try manually pushing a sheet of paper through the machine IN THE DIRECTION IT IS NORMALLY FED. This may force out any stuck scraps. The jam sensors are usually located where the paper feeds and where it exits the machine. Also, make sure ALL ACCESS PANELS YOU OPENED TO CLEAR JAMS ARE CLOSED PROPERLY. Otherwise, the jam code will not clear.
Nov 25, 2008 | Brother IntelliFax-2820 Laser Fax
Canon Fax-JX200
First, you may be dealing with two separate and distinct problems - or did they both start happening at the same time? In regard to the beep on scanning of faxes, the first thing to check is the machine memory. If you are storing documents, there is a limit of 30 documents (60 pages maximum). If the memory is not sufficient to allow for scanning the material you are attempting to fax, this will create that error. You should still be able to send the fax manually (directly) rather than through memory, if you need to retain all the documents in memory.
Regarding the paper jam, make sure you have checked every area of the machine for any little scrap of paper or other residual that may have been left in the machine along the way. As you have the manual, follow the cleaning and maintenance instructions to make sure everything is clean and in proper working order.
Then, I would also suggest that you physically unplug the unit from the power source for at least five minutes, if the problem has not been solved. Then plug it back in and see if this has cleared the internal error. If it is not cleared, your FINE cartridge should be checked and/or changed, and the manual gives good instruction on this as well. Make sure your paper is of proper quality and is not bent or sticking together, etc. According to Canon, if these things do not solve the problem, the unit may need service. However, please let me know where we stand and we'll see what else we might try if this does not resolve your issues.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Jul 21, 2008 | Canon FAX-JX200
Fax jx200 memory full and i dont know how to clear
You press "Menu" button and use arrow key to select "Memory Reference" --> press "Start" button --> and now you can see your documents in memory ---> You can print out or delete. If you have any problem with Canon products you can email to me.
Apr 07, 2008 | Canon FAX-JX200
Canon FAX-JX200 Logo
122 people viewed this question
old marine
old marine
