Question about GE DCSR483EA Electric Dryer
Ge dryer I need to get into my GE dryer to check the drum and bearings
  • 943 Answers
Hi Thanks for the question .Open the door,screws under top. remove screws. lift up top. 2 screws on the inside of front , remove. pull front away front bearings on the front support. . thanks the appliance doc. Please rate my answer thanks
Posted on Oct 06, 2008
How do I stop my GE dryer from squeaking
Check belt look for location of noise and look for items in that area you should locate with process of elimination .
Mar 03, 2016 | GE Dryers
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Sep 02, 2015 | Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Axial play in dryer drum
There is a bearing at the back middle of drum, and the socket in which it rides. (made of plastic].
Often when the exhaust is clogged or not venting properly it causes the plastic to melt wearing out the bearing.
There is a bearing kit with the complete beareing and socket but you will need to basically take the whole machine apart to rteplace these parts.
Jul 12, 2010 | GE Dryers
Squeeks when drying.
GE dryers have a drum bearing at the back of the drum in the center. Most likely the bearing is worn out and needs replacing.
Mar 20, 2010 | GE Dryers
Clothes dryer is squealing when turned on. suspect drum bearing. looking for a diagram for dismantling can i take the top off without removing the back panel( GE 5 cycle dryer)
You dont need a bearing you need the DRYER DRUM SLIDE Part number AP2041815 which is under $6.50 a piece. Take the top of the dryer off and look on the front of the drum. Some GE dryers have 2 and some have 4.Go to it item 316 they also have a diaphram.
Oct 10, 2009 | GE Dryers
My electric clothes dryer has started to occasionally make noise. could it be a bearing or a belt this is slipping. It's a GE machine about 12 years old.
could be the belt,drum glides,rear drum bearing or the idler pulley is weakening and letting the glazed belt slip on the drum
Sep 13, 2009 | GE DCL333EA Dryer
Dryer Drum bearing designs
these drum glides look cheap,but they last for a long time
Jul 26, 2009 | GE DVLR223 Dryers
Iam hearing scraping sounds from my dryer.
Hello Friend, Your solution is simple. You need to replace the front drum bearing and glider pads. It's actually pretty simple to do. Just remove front of dryer cabinet. After removal just look at backside of dryer front around the inner door. You will see where the dryer drum has turned and wore a hole in the plastic piece above the dryer door. This piece is called the front drum bearing. Just unsnap this piece and snap in a new one. Be sure to replace the little plastic glide pads onto the top of the drum bearing before re-installing the dryer cabinet front. The front drum bearing and glider pads are sold seperately so make sure you have everything you need before you begin. This should solve your problem. Happy to help, Tim.
Jun 25, 2009 | GE DBSR453EBWW Electric Dryer
GE DCSR483EA Electric Dryer Logo
128 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
