Question about iLO MP3 Player
Sylvania 2GB SBL2080603863
How long does the player need to charge the first time in order to be fully charged?
  • Anonymous Dec 05, 2008
    tengo un mp3 player pero no se como recargarlo no funciona es un silvania de 2 gb.
  • 8,596 Answers
3-4 hrs
Posted on Sep 07, 2008
Mp3 wont turn on or hold a charge what do i do?
If you have fully charged the device with the power cable and it still will not turn on, it is likely that the battery is no longer holding a charge. You would have to contact Sylvania to ask about battery replaement, but it may be cheaper to purchase a new device.
Apr 17, 2011 | Sylvania SMPK2062 MP3 Player
Do i charge my mp3 with the power on or off
you can charge it either way, but from my experience you get a better charge when the power is off.
Nov 09, 2010 | Sylvania SMP2012SL 2GB MP3 Player
Any idea how long it takes to charge the Sylvania SMP2012? How do you tell when it is fully charged?
The Sylvania SMP2012 charges fully in under 15 minutes on a regular USB port. Sometimes it's much quicker.
When the device is charging, both the red and green LEDs are lit (not flashing). When the device is fully charged, the green LED turns off, and only the red LED is on.
Sep 12, 2010 | Sylvania SMP2012SL 2GB MP3 Player
Silver Sylvania smp2012 2gb what kind of charger do I need for this mp3 player
No separate charger is required. Use a USB cable to connect it to any computer (desktop or portable), or to any powered USB hub. It should charge in about 5-20 minutes. While charging, both the red and green LEDs are lit. When fully charged, the green LED turns off and only the red LED is on.
This device should also be possible to charge using a stand-alone USB power source, such as those used to charge Blackberries.
Aug 14, 2010 | Sylvania SMP2012SL 2GB MP3 Player
Does a sylvania 8gb mp3 have to be fully charged
No it doesn't have to be fully charged as long as there is enough battery to turn on and play music it'll turn on it'll also remind you if the battery is low
May 30, 2010 | Sylvania SMPK8858 MP3 Player
I get a message that the battery needs charging even thou its fully charged
How do you know it's fully charged? Is there a battery level indicator?
Feb 02, 2010 | Sylvania Audio Players & Recorders
Mp3player 2gb smp2012 sylvania not rca
leave it plugged into the pc for a few hours and it will charge
Sep 15, 2009 | RCA M4204 MP3 Player
HOW LONG DOES IT TAKE TO CHARGE
Is it new and you are trying to charge for the first time?
First time charges can take up to 12-24 hrs. depending on the device.
Apr 20, 2009 | Sylvania Audio Players & Recorders
When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
Check for the following:
USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
USB Port 2.0
Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged.  It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater
Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
242 people viewed this question
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
Allen Benge
Level 1 Expert
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
