Notice when using 3rd party Today plug-in's, there is a very high probability that the OPTION screen for the phone cannot be launched. This happens with SPB PocketPlus 3.x, SBSH's PocketBreeze, etc. I have also noticed that even I set auto answer after 3 rings, it has never worked. Any work around?
Sounds like it might be time to test things in a vanilla fresh setup.......... -Backup your system via iPAQ backup to an SD card (or ipaq file store if you have room) Warning, following will delete all main memory and set back to factory default! -do a hard reset (hold in power and reset for 20 seconds) -Test programs again, see if it acts the same. You can then restore your setup via iPAQ backup again if needed. You can also poke around the following site for suggestions on tested task managers and today screen apps. (I use HandySwitcher)
