Question about Texas Instruments TI-84 Plus Calculator
TI 84 Plus Silver Edition
When I turn it on I get a solid cursor then no other buttons respond. Is there a way to give this thing a hard restart to factory config??
  • 9 Answers
I actually fixed mine!!!! Mine was acting up too. I found somewhere that the no/slow key response could be due to a short in the I/O socket. I blew into it really hard (you may want to use compressed air, but I didn't have any onhand), and it works perfectly now!!!!!!!!!! I hope this helps.
Posted on Sep 13, 2008
Here's how I fixed this problem. BTW, I had exactly the same problem: I could turn the calculator on and a black cursor would appear in the upper left but no keys would respond. I tried all solutions that TI suggested and others I read about, including upgrading the OS, resetting the calculator by removing all the batteries, etc. Nothing worked. Occasionally, if I started the calculator with the Del key depressed, it would display: "log(". But still no keys would respond.
I was about ready to give up but being a tinkerer, I decided I would take the calculator apart to see if anything obvious was wrong. I followed the instructions on disassembling the TI-84 here: http://www.instructables.com/id/Ti-84-Basic-Disassembly/
First time I disassembled it, I tried blowing on all the parts to remove dust. Then I reassembled it but the calculator still did not work. I then disassembled a second time and looked more closely at the main circuit board on the side against which the buttons are pressed. For each button, there is a gold colored star shaped pattern on the circuit board. I assume that the when a button is pushed, the pressure is detected by this electronic device. I looked closely at the log key because that was the function that appeared occasionally on the screen. I detected a very slight discoloration in the circuit board for this key. I want to emphasize extremely slight - in fact, my daughter, to whom I showed the circuit board, said she did not see it. I dunked a cotton swab into some rubbing alcohol and then rubbed the entire surface of the circuit board (side with the gold star shaped regions corresponding to the buttons). Then I rubbed the entire board with a dry end of a cotton swab. Then, I let the board dry for at least 30 minutes. I then reassembled the calculator and it worked like new.
My theory: the electronics that sense the depression of a key are very sensitive to the presence of dirt or dust. Somehow, some dirt or dust made its way under the keyboard and got lodged near the log key (it could have been any other key). It was a very minuscule amount of dust but enough to disrupt the electronics. The electronics then wrongly sensed that the log key was being continously depressed and with one key depressed, the calculator wasn't responding to any other keys, including the off key. When I cleaned the board with the rubbing alcohol, the offending dust was removed and the keyboard began to function normally again.
BTW: For those who are worried about taking the calculator apart, I say: what do you have to lose if the calculator is out of warranty? I am not an electronics genius by any means and I took the calculator apart in about 5 minutes. There are all of 12 screws to remove.
Posted on Jun 07, 2011
TI-84 Silver Edition blank screen with cursor in top left hand corner blinking. Keys not responding
The command line is full. Use the left arrow key to clear the command line. Then erase all previous entries, or reset the RAM
Sep 07, 2014 | Texas Instruments TI-84 Plus Silver...
None of the buttons on my TI-84 Plus Silver Edition will work
Does it turn on with a cursor, Have you tried a fresh set (all four) of batteries, Is there any corrosion/dirt on the battery contacts and the I/O port that you can see, Have you tried any resets?
Jun 09, 2014 | Texas Instruments TI-84 Plus Silver...
Cant find ! button
There is no such thing as a TI89 Plus Silver Edition.
If you mean the TI-89 or TI-89 Titanium, press diamond / (the diamond key below the 2ND key, then the divide key).
If you mean the TI-83 Plus Silver Edition or the TI-84 Plus Silver Edition, press MATH left-arrow 4 .
Dec 15, 2013 | Texas Instruments TI-84 Plus Silver...
TI 84 plus silver edition not responding keys not working
Remove all four AAA batteries. Press and hold the ON key for at least fifteen seconds then release it. Replace the batteries.
May 09, 2012 | Texas Instruments TI-84 Plus Calculator
TI-84 Plus Silver Edition not responding!
what helped for me is leaving it w/h any battery's (no backup battery either) for a few days. Now miraculously it works!
May 06, 2010 | Texas Instruments TI-84 Plus Silver...
Number 6 and dark box beside it on screen ti-84 plus silver edition, it will not let me do anything !!
Press [ENTER]. It will display 6 on the next line. Whenever a cursor is blinking it is waiting for you to do SOMETHING.
Hope it helps.
Sep 27, 2009 | Texas Instruments TI-84 Plus Silver...
Ti84 Plus Turns on, and turns off right away.
I had the same problem like yours. First, I reset the RAM and then it no longer turned off right away; but it responded extremely slowly. Second, I tried to install the new OS for it, but unsuccessful until I blowed really hard several times into the round connector. After that, the cursor started blinking. Finally, I downloaded the new OS into it and hoped that the problem never happen again.
You go to http://education.ti.com and follow their procedures to reset the RAM.
Sep 17, 2009 | Texas Instruments TI-84 Plus Silver...
Where do I find the comma button on the TI-84 siver edition?
The comma is located on top of number 7 key.
See page 5 on teh user manual to learn how to operate the keyboard on a TI 84 Plus:
TI-84 Plus TI-84 Plus Silver Edition Guidebook
Mar 16, 2009 | Texas Instruments TI-84 Plus Silver...
ON button broken!
Maybe because the batteries are out of powwer
Feb 12, 2009 | Texas Instruments TI-84 Plus Silver...
Won't stay on.
have you tried manually resetting like the manual suggests? Take out the AAA's only, hold the ON button for 10 seconds and then re-install the batteries and turn it on. If that doesn't work, I have no other suggestions.
Apr 07, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
345 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
