Question about Toshiba SD-V392 DVD Player/VCR
Toshiba TV/VCR/DVD combo MW24F12
I want to add a Phillips surround sound speaker system with DVD player to it.
When put a DVD in the Phillips surround sound system it plays through the speakers but will not play on the TV. Do I need to diconnect something from the TV's DVD player or what do I do.....help.....I've read the manuel till I'm blue in the face but I can't see what to do.
  • marciamooma Aug 28, 2008
    Thanks for the tip, I did have them connected but it was going through a RF Modulator which I tried eliminating and then kept searching the channels and found the DVD from the Surround Sound system and got it working!
    Thanks for your help
  • Anonymous Mar 21, 2014
    advent dvd player not playing sound through car speakers anymore
  • Toshiba Master
  • 520 Answers
You did not say if you have connected the video out on the surround system to the video in on the tv. If not connect it and select that input on the tv.
Posted on Aug 28, 2008
Cannot record t.v. programmes after the changeover on video
I put the recorder channel on AV2 and then recorded it. It worked. Thank you anyway.
Dec 29, 2009 | Samsung SV-DVD55 DVD Player / VCR Combo
I'm trying to hook up a 5-speaker Dolby surround
out of tv, into the combo, out of the combo into the surround amp and this work
Sep 01, 2009 | Televison & Video
I need help hooking up my tv and dvd player to my surround sound
for your dvd player you just go from audio out on the back of the dvd played to the audio in on the surround sound. and you would do the same for the tv if it has an audio out. your surround sound shoud have more than 1 audio in. and then when you swicht from tv to dvd you might have change the channle, setting, source, or what ever it might be called on the surround sound. and if your tv does not have a audio out contact me at swinginflames@gmail.com and i try to help you. hope that works :)
Feb 22, 2009 | Durabrand 5.1 Surround Sound Computer...
Speaker hookup on back of tv
I looked up the specs on your TV and Toshiba says that all of the A/V jacks on it are inputs. It doesn't list any outputs for external speakers other than the Coax digital output jack for surround sound systems. This would explain why you don't get any sound. The website where I got this information is as follows...
http://www.tacp.toshiba.com/televisions/product.asp?model=mw24fp1
Sorry for the bad news.
Jan 02, 2009 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Umi freeview dvd tv combo to surround sound
I am not familiar with the manufacture and model of your TV set. This does appear to be a compatibility issue between the TV set and its DVD player, and the surround speaker system. The TV set may not be able to directly send the proper information to the speakers. I would consider to call the manufacture support people to have a definate answer.
Jerry G.
Dec 28, 2008 | Philips 17MD250V 17.1 in. LCD TV/DVD Combo
CONNNECTING THE DMR-EZ475V TO A TV, THEATRE SYSTEM AND CABLE BOX
noavatar_s.png jdrrwoods
Rank:wizard_s.gif Wiz
Rating: 84%, 12 votes
http://www.altex.com/product_info.php?products_id=9207 here is a link to a audio / video switch box you need one of these make sure it has several audio video in and at least one audio/video out
hook all you rca1.gif cables up to the audio/video in from the cable box, tv, and dvd/vcr combo then out to the surround sound youll also need to get some rca cable splitters for the out so you can run it back to the audio/video in to the tv as well as the surround sound here is alink to what they look like
http://www.altex.com/product_info.php?cPath=344&products_id=6201
youll need thre of these of course when hooking it up dont pay attention to the color on these just the ones from the tv and surround sound and thats it your done it will all work if you want it to were you dont have to get up and push a button everytime most of them if you push all the buttons in at one time theyll stay like that
Feb 08, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
SETTING UP TJE PANASONIC DMR TO OTHER COMPONENTS
if studio audio facility in tv there [are] hence remaining to install just input channel of output but if there is no having to suround efec,thank.........
www.modifmax.com.
I want to connect my sound system to my tv
Your television is either going to need Video Out, or if you have a VCR or VCR/DVD combo connected to your television. Assuming that you have a VCR combo, the way your tv should be set up is on the back of the vcr combo, your cable will run into the coaxial IN and then you have another cable running from Coaxial OUT to your tv. If you have it set up like this, then the DVD / VCR combo will have RCA Audio / video out ports on the back side. Run RCA cables from the DVD / VCR output to the surround sound INPUT. If you already have your inputs in use on the surround sound, Radioshack has RCA splitters for about $1.50 each, you might need to pick some of them up so you dont have to go through the trouble of reaching behind it all the time to disconnect and reconnect whatever your trying to connect. Now if you dont have the DVD / VCR combo, then your TV "MUST" have RCA Outputs. if it doesnt, then the only way that your going to have your surround sound connected to your tv is to take the TV apart and get a RCA "Line output converter" and wire it to the left / right channels of your tv. From what I've read, i think this is what your trying to do so I hope this helps
Jan 20, 2008 | Durabrand STS92 System
Cannot TV to play throught JVC TH-C50
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Dec 24, 2007 | JVC TH-C50 System
Toshiba SD-V392 DVD Player/VCR Logo
192 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
