Question about Emerson MW8107WA Microwave Oven
No power came home the other day and the breaker was tripped in the kitchen I reset the breaker and then later noticed that the Microwave never came back on tried plugging it in to different outlets with zero response anything I can do? or is it trash now? and naturally the Mircowave has screws that are an odd star shape so first I must find a driver to get the panels off, so thought I would check with you experts to see if it was even worth trying.. Thanks so much for your time and knowledge..
  • shellasmind Aug 29, 2008
    Thank you so much Rickzilla for your help.. and fortunately for me I have a friend who will be in Anchorage Saturday and will pick me up a new one... Although even if I lived somewhere, convenient for shopping I still hate throwing out what was a perfectly good microwave up until one tripped breaker.. and although I normally at least try to repair things myself.. You are most likely right Thanks again for your time...
  • nesiebug Jan 01, 2009
    The exact same thing happened to me. The breaker flipped. I reset the breaker and the microwave won't come back on.
  • 706 Answers
If your table top microwave tripped the breaker in your house.. and then when you reset it but if failed to come back on.. chances are the cost to repair would exceed the cost to replace so I would suggest you just purchase another one.. Microwave energy is not something that the novice should fool with and you or someone in your family could get seriously injured if you removed the cover and compromised the shielding in any way. Others may have differing opinions but this is just mine. hope this helps..
Posted on Aug 29, 2008
Microwave clock and panel was lit in am wasn't used but in evening when went to use it isn't lit and won't work at all
Hello Anonymous
At the risk of starting with the very basics, when you say that the clock and panel aren't lit and wont' work at all, the first place to look is the wall power. You may be missing power from the wall because:
  1. The microwave isn't plugged in. Someone may have yanked a plug to plug in a mixer, phone charger, thanksgiving animated ornament, or what have you. Trace the cord back and make sure it's plugged in.
  2. Make sure the outlet has power. Take some plug-in-able item and plug to the outlet and see if it can turn on. If not:
  1. A number of kitchen outlets may have GFI switches, especially if they are anywhere near sinks. The GFI may have been tripped. There should be a reset switch in the middle of the plug. See if it's tripped, and reset if necessary.
  2. The breaker may have been tripped. Most kitchen circuits are wired to 20Amp breakers. If this is elsewhere in the house, like in an entertainment room or such, it is likely a 15 Amp outlet. Microwaves can draw a fair amount of power. Someone using another kitchen appliance, hair dryer, or what have you, on the same circuit, may have tripped the breaker. Newer code may specify an AFI or GFI breaker for kitchen outlets. In that case, a fault with something else on the circuit may have tripped the breaker. If that is the case, and it trips again, talk to an electrician. You don't want a fault like that undiagnosed.
    3) You may also want to try plugging the microwave into another outlet, even if the normal outlet seems OK
    If there's wall power and a good plug-in, then you work back to the microwave itself. A number will have fuses. Also, there may be interlocks that kick in if, for instance, the carousel rotation is impeded - that can mean something on the carousel is hitting a wall, which can risk tipping something over and spilling, or risk mucking up the reduction gears for the carousel axle if it keeps pushing.
    At that point, looking for specifics on your microwave model will be needed. You may also try the Microsoft Support approach - i.e unplug it for 5 minutes, then plug it back in and see if it works.
    Hoping this helps, Good Luck!
Nov 18, 2015 | In Microwave Ovens
Wont work or come on
Debbie,
If nothing is coming on with no lights or anything you probably have a blown fuse. Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Mar 27, 2015 | Microwave Ovens
Used the microwave last night. Later I noticed no light display for the clock. Come to find out microwave lost all power. Model number smh9207st
If there are no fuses or circuit breakers, the unit could be down and out. Check you power box for any tripped breakers.
Dec 09, 2014 | In Microwave Ovens
On breaker 7 that runs the lights and receptacles in 2 bedrooms, the light in my crawlspace, the light in the attic, two ceiling lights in the kitchen (but no receptacles), and the outlet for the...
1) You must see if the circuit where the microwave is overload, you must use the amperimeter and see how many amperes are reading when all the load in the circuit 7 are running. if is normal about 10amp-12amps the circuit is o.k
2) test the c.breaker can be faulty, since there are NOT tripped.
3) However you must see if the lines for power in that circuit is loose?
4) Tight very well the Neutral +Ground
5) see the diagram attached, and correct if the outlet is wrong.
6) If you are NOT qualified to do this electrical job , call some electrician for to avoid danger to your home or yourself.
God bless you198ace60-27b8-4867-bf57-4b0086ba4f59.jpg5755a5d4-1228-483b-969d-82f0a795cbc3.gif
Of course you must test the microwave magnetron for faulty or short in the magnetron+diode+transformer+capacitor. ISOLATED the microwave first and then troubleshooting the circuit of your home.
God bless you
Nov 01, 2013 | Whirlpool Microwave Ovens
Samsung SMH9151 trips breaker when plugged in
You have a sort circuit inside, call a repairman or take to the repair shop
Aug 23, 2012 | Samsung SMH9151 Microwave Oven
Lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Mar 29, 2012 | LG Microwave Ovens
Microwave pops hose breakers. Microwave gets
The problem is in the microwave oven, you have a short in the power supply or it could be a defective door switch, either way the unit needs to be checked out.
Feb 27, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
I have noticed that when I have my dishwasher on, and kettle and water filter that the safety switch trips out, shutting down most of my kitchen. The dishwasher has it's own outlet and the kettle and...
all kitchen appliances should be on ground fualt outlets & breakers,If an appliance is on a g.f. outlet it should only blow that particular outlet so all you have to do is push the reset button.Outlets and lights should be on different breakers,so that if the outlet breaker blows you will still have lights
Oct 11, 2010 | Microwave Ovens
Tripped a breaker
sometime the kitchen has gfc outlets around the walls and one of them tripped. but not likely , it sounds like the microwave fried some valuable circuitry.
May 12, 2008 | Goldstar MV-1501 Microwave Oven
NO POWER, POPPED CIRCUIT
Two possible causes.
First (and most likely) the circuit is being overloaded. This kitchen circuit may be shared with another appliance (like the refrigerator) which is drawing enough power when both are running to trip the breaker. A Typical kitchen circuit is 20 amp with #12 wiring. So an 1800 watt microwave might draw 13 or 14 amps while a fridge compressor kicking in can surpass 7 amps before it levels off. If this is an older home the kitchen may have a 15 amp circuit with #14 wiring. If the circuit is a 20 amp you will have to split the appliances onto separate circuits. (Under code a kitchen must have a minimum of 2 separate appliance circuits). If it is a 15 amp you might be able to split them as well or may be looking up upgrading the breaker and the wiring from 15amp #14 to 20 amp #12 (but you could still have the same problem).
The other possibility is a short or loose connection. If splitting appliances onto their own circuits doesn't fix this you would probably want an electrician to come in and check for other underlying causes which could represent a fire hazard.
Hope this helps.
Apr 01, 2008 | Whirlpool GH6177XP Microwave Oven
Emerson MW8107WA Microwave Oven Logo
110 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
