Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Green horizontal moving kines
My tv has green lines that move from horizontal to diagonal and sometimes vertical. What can I do?
I called a repairman, from the store where we bought it.
Posted on Aug 29, 2008
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
Tv repair
A vertical line means the line is up and down in the middle of the screen. That would indicate that the vertical IC and the surrounding components are working perfectly. A vertical line as described is the result of a lack of horizontal deflection (to move the beam from side to side) Since the high voltage is obviously OK, the problem is most likely a bad solder connection in the horizontal yoke circuit. Examine the bottom of the PC board in the area of the flyback transformer, and yoke connector (has four wires Red, Blue, Green, Yellow).and the pincousion coils, capacitors, etc in between. Flexing the board in that area may cause the problem to come and go. Resulting arcing should also be visible. BE CAREFUL, as hazardous voltages are present in the circuit!
Nov 29, 2009 | Sharp 19R-M100 19" TV
The tv comes on and then goes completely out after about 20 sceonds. While it is on there are diagonal lines on a lime green field that do not move.
yes. if you have a black bright screen with about 16 to 20 horizontal lines going across, you have no video. suggest local service center. if it is a magnavox, this is easy. you have an open 1 ohm(approx. value) resistor on the crt board.
Nov 12, 2009 | RCA Televison & Video
I have lines going through my TV. It hasn't been moved not hit and when cleaning it I used a computer screen cleaner with the tool it came with. It is over a year. Now what?
are they vertical or horizontal ? in a samsung if the screen is not broke or cracked the problem is the screen video processing board
Sep 29, 2009 | Sylvania 32 in. Diagonal LCD HDTV
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Convergence
you need to replace both convergence ICs they are STK392-110 you can get replacements at the following link with free installation instructions so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Aug 23, 2008 | Mitsubishi WT-42311 42" Rear Projection...
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
POP and noothiing
yes it can still be fixed! the pop sound you've heard maybe came from a blown capacitor in the vertical deflection circuits. this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 10, 2007 | RCA E13309 13-Inch Diagonal XL-100 Color...
Black screen with green smiley face
If your tv has a picture tube,your problem is in it. If you have only one line now,the vertical circuit is not working. You could have jarred something loose around the picture tube.Maybe a yoke lead ???
Jan 13, 2007 | Mitsubishi VS-60607 TV
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
70 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
