Question about Lexmark Z735 InkJet Printer
Paper detection printer says load paper even though it has some loaded......won't feed also
    Problem Solver:
  • 33 Answers
The same thing happened to me once. Try looking near the cartridges and where you input the paper, there might be an item stuck which makes it hard to print or load the paper. When that happened to me, i noticed that there was a pencil stuck in mine. I ended taking it all apart in the end, but that is only because someone forced it in there. In the end, it worked!
Hope you get your working soon! =]
Posted on Dec 14, 2008
Keeps saying paper out cassette 1
Sometimes the rollers that take the top paper into the printer get a little worn or shiny and doesn't grip so well try helping it at the point when you hear it start to try and take the feed in by holding the top piece of paper and easing into the printer feed.
Mar 22, 2015 | Epson Expression Premium XP 820 Wireless
My Polaroid z300 stopped printing pictures and keeps telling me to load it even though there's paper inside. How can I get it to print again?
It could be that the paper supply sensor isn't properly activated, or a new sheet isn't being picked up. Try removing all sheets of paper and inspecting with a flashlight.
I once assisted a frustrated elderly friend with a similar situation, and discovered that a white kleenex tissue had found its way into the paper loading mechanism! Her initial inspection had not detected it because it was camouflaged!
On another occasion, the rubber feed rollers didn't have enough friction to pick up a sheet of paper until they were cleaned with rubbing alcohol.
Dec 25, 2014 | Office Equipment & Supplies
The "add paper light" is on even though the paper
The light means that the printer is out of media, or the media did not feed properly
What you can do
-Load media into tray and press Continue button to resume printing.
-Check that the media is loaded correctly in tray
-Press Cancel button to cancel the print job.
Jun 29, 2011 | Lexmark E232 Laser Printer
Load Paper light
You need to clean the feed roller, if you take out the paper tray and tip the printer on it's back you can see the roller and clean with just a damp cloth and try printing again...
Sep 15, 2009 | Dell 1720dn Laser Printer
My Dell AIO Photo 926 Printer feeds the paper crooked and jams then says to load paper even though there is paper in it. How do I fix this problem?
Try cleaning the paper feed rollers with a cloth dampened with alcohol. Also check for a piece of paper that may be stuck at the place where the paper goes crooked.
Jul 25, 2009 | Office Equipment & Supplies
Machine flashing load paper message even though paper is loaded
Hi ...
Most of the time this problem comes when the paper is not loaded correctly. Follow the below instructions to load papers to the cassette and I am sure this will resolve your problem. I will keep monitoring your responce and if required, i'll look for a work arround.
Follow this procedure to load paper / envelope in the cassette:
  1. Pull out the cassette from the machine.
  2. Remove the cover from the cassette.
  3. Fan out the sheets of paper so that they do not stick together.
  4. Align the edges of the paper.
  5. If the cassette is not yet extended, use your thumb to press the tab (indicated by the pink circular outline) and release the latch.
  6. After the latch is released, remove your thumb from the tab. Then extend the cassette until a click is heard.
  7. Load paper on the upper-right corner of the cassette with the print side facing down.
    Note:
    * Since the Credit Card sized paper, Canon Photo Stickers, and Legal sized paper cannot be fed from the cassette, load them in the auto sheet feeder (ASF).
    * When loading A5 or larger sized paper (nonstandard-size paper: 203mm / 8inches or more in length), extend the cassette by pinching the tab.
  8. Grasp the paper guide (A) and align it to the long edge of the envelope stack (2). Align the front edge of the paper stack in the same way (3).
  9. Close the lid and push the cassette all the way into the printer.
  10. Press the <Open> button and pull out the extension completely.
  11. Press the <Feed Switch> button to turn on the Cassette light.
    *MP500 shown.
    Note:
    If the Auto Sheet Feeder lamp lights, press the Feed Switch button to light the Cassette lamp.
    If the Cassette lamp does not light even after pressing the Feed Switch button, Paper Source in the printer driver may be set to the setting other than the Feed Switch button.
Loading on envelopes
Paper Type
Precaution
Envelope (DL / #10 )
Set paper with the flap closed.
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
  5. Load envelopes in the cassette with the print side facing down and the flap towards the left.
  6. Close the lid and push the cassette all the way into the printer.
  7. Press the <Open> button and pull out the extension completely.
  8. Press the <Feed Switch> button to turn on the Cassette light.
    Note:
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Mp780 - Paper attempts to feed and fails Message: Load paper
Your paper feed source is wrong .Go to the printers control panel and change the feed source.
If all you do is 8.5X11 you can go into the maintenance tab and choose it to automatically change paper trays by selectin auto continuous feed.Make sure paper is in both trays of the same type and size.You will hear the printer try and grab the paper three times then it will automatically switch to the next tray.
Jun 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Papaer out error
Paper detection switch on tractor feed unit is probably faulty. Replace the tractor feeds.
Jul 15, 2008 | Epson DFX-9000 Matrix Printer
MFC 440CN fax machine
Is this through the ADF (top feeder) or from the paper tray? Either one can have some build-up on the paper feed rollers and would have to be cleaned.
Jan 08, 2008 | Brother MultiFunction Center MFC-440CN...
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
Lexmark Z735 InkJet Printer Logo
85 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
