Question about Toshiba e330 Pocket PC
Reset my Pocket PC
How can I reset my Pocket PC e310 and e330 should it hang or not react?
    Master:
  • 903 Answers
A Reset of your Pocket PC is equivalent to "Restart" of a desktop computer. Carry out the Reset only in such unusual cases as when a button or tapping the screen does not respond. When your Pocket PC is reset, no data will be deleted. All stored information like Addresses, Contacts, Tasks or Programs are still stored in the Pocket PC memory. To Reset the Pocket PC, the power must be on. Then press the Reset switch with the stylus, then release. Your Pocket PC should function properly thereafter. If the functions cannot be restored, even after the reset button is pressed, Initialise your Pocket PC (refer to the FAQ article: How can I initialise my Pocket PC (Factory Reset).
Posted on Sep 08, 2005
SOURCE:
My pocket pc e310 wont turn on. i only have the cradle and no ac charger. i have unplugged the battery for a reset but nothing happens after i plug it back in. when plugged in to the cradle, there are no...
The e310 can't use USB power to charge through the cradle. (It needs more than USB specs allow.) You have to supply +5v DC to the connector at the cradle or the e310 itself. Positive terminal is the center pin/hole, negative terminal is the outside barrel of the plug.
Jun 02, 2011 | Toshiba e310 Pocket PC
Tip
HARD RESET Toshiba e310 e330 e335 e350 e355 e400 e405 e570 e740 e750 ...
Make sure your device is off before performing hard reset. While holding the power button press in on the reset switch with your stylus then release the power button. When a screen appears release the reset switch.
on Mar 10, 2010 | Cell Phones
E330 crash
Use the reset button at the back side of your PDA. Keep pressing for a few seconds.
Sep 11, 2005 | Toshiba e330 Pocket PC
Reset my Pocket PC
A Reset of your Pocket PC is equivalent to "Restart" of a desktop computer. Carry out the Reset only in such unusual cases as when a button or tapping the screen does not respond. When your Pocket PC is reset, no data will be deleted. All stored information like Addresses, Contacts, Tasks or Programs are still stored in the Pocket PC memory. To Reset the Pocket PC, the power must be on. Then press the Reset switch with the stylus, then release. Your Pocket PC should function properly thereafter. If the functions cannot be restored, even after the reset button is pressed, Initialise your Pocket PC (refer to the FAQ article: How can I initialise my Pocket PC (Factory Reset). If you have further questions, please refer to the Instruction Manual page 12-4 (172 of 182).
Sep 08, 2005 | Toshiba e740 Pocket PC
Initialize my Pocket PC
When you initialize your Pocket PC, the factory default values are reset to the status as when you originally purchased the Pocket PC e330 or e310. NOTE: When you initialise your Pocket PC, all data stored in the memory is deleted. Your Pocket PC's initially installed programs are not deleted. Before initialization your Pocket PC, remove all storage cards. To initialize your Pocket PC, please follow the steps: Turn off the power Press the power button while pressing and holding the reset switch with the stylus. Then release the power button When a screen appears, release the reset switch When initialization is completed, the Welcome screen appears. Set up the system according to the screen as in the case of startup procedure.
Sep 08, 2005 | Toshiba e330 Pocket PC
Reset my Pocket PC
Sep 08, 2005 | Toshiba e310 Pocket PC
PDA e310, e330 or e740 together with Windows NT 4.0
The Toshiba Pocket PC's e310, e330 and e740 are designed to work together with Microsoft Windows 98, Windows 98SE, Millennium, Windows 2000 and Windows XP. Microsoft Windows NT4.0 is an older operating system, which does not work together with the Toshiba Pocket PC's e310,e330 and e740. Technical background: The Toshiba Pocket PC's have a USB and a Infrared interface to communicate with a Computer. Unfortunately, Microsoft Windows NT4.0 does not support USB nor Infrared. Windows NT supports a serial connection, but the serial interface is not available for the Pocket PC's e310,e330 and e740. Note: There is the possibility to synchronize a PDA over Network or Modem but the ActiveSync Software, which is responsible for the synchronization, will need a "first sync" to establish a "partnership" with the PDA. This "first sync" can only be done via USB.
Sep 07, 2005 | Toshiba e330 Pocket PC
Sep 07, 2005 | Toshiba e310 Pocket PC
Sep 07, 2005 | Toshiba e740 Pocket PC
Toshiba e330 Pocket PC Logo
166 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
