have not used my ipaq for a couple of months and when i plugged it in to charge it said that the battery was too cold and would resume charging when it reached a normal temperature which seems to be never. i don't know what to do. is something wrong with the ipaq or the battery??
-   My ipaq battery is in the device but when its almost done booting up it shuts off. plz help i found a way to bypass this but then it says that the battery is too cold to charge....it was stored away in a room that was 75 degrees!!!! PLease HELP!!!!!!!!!!!!! -   allmikee
Solution #1
posted on Sep 08, 2005
adib - usenet poster
Rank: Guru
Expert
Rating: 86%, 240 votes
Was it stored in a place that has extreme temperatures? If so, some hardware might have become damaged. Try to let the battery warm up some and then try again. I would also try a hard reset if at all possible and if that still doesn't work probably call up HP and see about a repair.
I am having the same "battery temperature is too cold" error. I purchased a new battery and allowed it to become "room temperature" and it does the same error. I take it there is no way of fixing this through simply resetting, which I have tried, including a hard reset. Nothing worked. I guess the hardware must be damaged.
We use the HX 4700 with a redcat restaurant order system and the wifi seems to brownout (wireless...
(More)
We use the HX 4700 with a redcat restaurant order system and the wifi seems to brownout (wireless manager) all the time. It wont stay connected to the network. Is there a fix as our 2400's and 2700's didn't have this problem.
It works well but since yesterday, when I turn it on, only start HP screen with Rom verson on it no...
(More)
It works well but since yesterday, when I turn it on, only start HP screen with Rom verson on it no moving circul to loading rom. Can't connect with PC via Active Sys neither/
try connecting my ipaq 4700to internet via my n86 nokia they pair up ok but then ipaq disconnects...
(More)
try connecting my ipaq 4700to internet via my n86 nokia they pair up ok but then ipaq disconnects can anyone help
