Question about Funai PY90VG DVD Player/VCR
FUNAI B2735 DVD/VCR COMBO
WHEN DVD DISC INSERTED INTO PLAYER (RECORD MODE)ERROR
CODE DISPLAYED ON SCREEN AFTER 30 SECONDS, CODE 03-51
(8 SPEED DISC) USED.WOULD APPRECIATE HELP
THANKING YOU
  • ldeanuk Aug 28, 2008
    on insertion of dvd disc I press the record
    button, the counter on the machine goes up to
    000030 and it is then ,the error code 03-51
    appears on the screen.Model is Funai B2735,I
    have tried the previous answer,but still the
    same problem !.
    LAURIE
  • ldeanuk Aug 30, 2008
    good work, it works fine using the Mitsubushi
    DVD-R (8 SPEED)
    Thanks for the help
    L.DEAN
    Master:
  • 521 Answers
Try using another disc in the recording device. if it works then the device is proper.if it does not work then the device is faulty.these errors occurs due to following reasons.
1)some where loose connection(that can be repaired)
2)the reading lens is weak (lens can be cleaned but not be repaired .it can be replaced.)but replacing would be very much costly.buying the new device is very much advisable.
still for the last try take it to the repair shop.hope that helps...
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Aug 28, 2008
  • 1,879 Answers
The player detected that the recordable disc inserted is for 8x speed. check the disc speed requirement of the player before purchasing another blank cd.
  • 6,487 Answers
It only means that the dvd cannot record on the Disc , possible reasons are the disc is not good that why the dvd canot record to it, or the dvd itself is not working fine to the recording part, Try using a different Disc to record with and see if it will record fine, beucase if it record fine on another disc it only mean onething the first dics is not good..
Hope that helps.....
    Master:
  • 763 Answers
Turn off first your about 10 secs then turn it on. be sure to check what disc youve inserted and see if its compatible with it.
CHARCOIS
    Brigadier General:
  • 6,966 Answers
Have you tried a blank DVD with lower speed say 4X? Or for that matter, some other brand of blank DVDs?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Aug 28, 2008
    Other things you can try are:
    • clean the optics/lens, initially with a CD ROM disc cleaner, otherwise, have to open it up;
    • Reset the unit by unplugging from the mains for an extended period in the hope that is is a systems glitch;
    • try playing first a known good DVD disc before recording.
    Cheers.
Record tv to dvd on Funai recorder
The Funai ZV427FX4 doesn't have a tuner. You'll need a set-top box (either a digital tuner or a cable box) that has a composite A/V out. Make sure to use a compatible DVD-R or DVD-RW disc (see page 27 of the manual given below). For basic recording, insert a DVD and press DVD to make sure that the recorder is ready to record to disc instead of video tape. (You may need to format the disc for DVD-RW.) Press Rec Mode until the correct mode is chosen. Then press Input to select composite input 1 or 2 (L1/L2). Set this source to the desired channel. Then press Rec. (For scheduled recording, make sure that the unit is set to DVD. Then press Timer. Follow the on-screen cues to set the time to start and end the recording. Otherwise the steps are the same. Then press Timer Set.) See the manual for screen-shots of the procedure.
The manual for this model is available on the product page: http://www.funaiamerica.com/product/product.php?id=877 . Click on the Downloads tab. The direct link is currently http://www.funaiport.com/download/download.php?id=3361&brand=FUNAI . For older Funai units with an NTSC tuner, you will probably still need the set-top box. However, you can either connect the box to the composite video or RF input. (If you want to record a program from a low-power analog station, you would skip the set-top box.)
I hope this helps.
Aug 28, 2016 | Funai ZV427FX4 DVD Recorder/VCR Combo
Funai VCR/DVD recorder DVR 2737. My -R discs record ok but during finalising I get disc error - cannot record on this disc Error code E22. Can you help?
I was advised to try another make of blank discs. I bought Sony discs & they worked ok. I had been using supermarket own brand.
Oct 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Will not record all I get is Error 3-51
I had a similar problem, it turned out the first time I tried it I didn't have a DVD in the tray! Then I found I was using a DVD+R blank DVD and this machine needs DVD-R DVD's. It certainly solved my problem using the right blank disc
Jul 13, 2009 | Funai PY90DG DVD Recorder
Funai DVD/VCR Combo (Model HDR B2735). Error message '03-56 Recording Error' Am unable to format DVD's
I had this error and fixed it by cleaning the lens and blowing all dust from the circuitry.
Paul
Aug 09, 2008 | Televison & Video
Plz help!!...i have recorded a home video,and transfered it from vhs to dvd using the funai HDR-B2735 and dvd-R discs,but they wont play on any other machine?
Hi have you finalised the discs on the dvd part of combi? If you do this they will play in other machines that accept dvd-r
Jul 01, 2008 | Funai DV-220SL8
Funai HDR-D2835 or HDR-B2735 region unlock
i think the codes from phillips machines work.
try at your own risks tho
Jan 29, 2008 | Funai PY90VG DVD Player/VCR
Transfer VHS to DVD
The illustrations within the PDF is very help!
To play disc in other DVD players…
The disc needs to be finalized.
Page 37 of the manual has “Finalizing a disc”.
Recording from DVD to VCR…
Page 39 “Dubbing Mode”
http://www.funai-corp.com/support/manuals.aspx
Type in the box: MWR20V6
Nov 09, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Funai PY90VG DVD Player/VCR Logo
270 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
