Question about Quasar Heating & Cooling
Vulcan Quasar wall heater. The fan stops after 15 min .fan temp. switch has been replaced
  • dongwen1 Aug 27, 2008
    wall unit has been cleaned out. fan turns freely.fan does not seem to slow down. is running ok then just stops.Checked the temp. switch and that is still switched on.
    Master:
  • 521 Answers
Hve u got ur device serviced recently
Posted on Aug 27, 2008
  • tech expert12 Aug 27, 2008
    this problem arises due to faulty or weak motor of the fan or if its not serviced since long and the fan is jammed up.also in rare cases it happens if the ventilations are blocked.check it out plse.its not a major problem ,nothing to worry.
    pls do rate the solution
    thanks.
    regards.
    fixya expert team
  • tech expert12 Aug 28, 2008
    also check the ventilations.
  • 157 Answers
The heat sensor in faulty. It will need to be replaced
Cheers
How do you check a fan motor
You need to check the volts at the motor while it's running, to make sure some safety is not shutting it off. Then check the amps on the motor while it's running. Also you need to check your capacitor and wiring.
Apr 30, 2014 | Heating & Cooling
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
I have a vulcan compact 60 sn# 1744 cat# 38-05 aw 166 the problem is the gas burner shuts down periodically about every 4-5 min, leaving the fan still running for a further 3-4 min, blowing out...
Hi Dave, my neighbour has a Vulcan Compact 60 that is doing the same as yours, except the cycle time is even shorter, only four minutes total. The temperature in the house barely rises and never reaches the thermostat setting. Altering the thermostat anticipator does not alter the cycle time. Therefore, as you have found, the fault is not related to the thermostat. The gas technician who inspected the heater said he could see the unit was faulting, but didn't think he could fix it. WTH? To help my friendly neighbour, I have asked numerous experienced techs since and those few who actually seem to know anything have helped me piece together what is probably (I emphasise probably) happening. Current thinking is that the fan is not blowing enough air and the heat exchanger is overheating, which trips the over temp switch (limiter), cutting off the burner. Eventually the fan cools the unit down enough to switch itself off and reset the limiter, then the cycle repeats.
The remedy is to replace the fan or replace the fan bearings, if they have become tight, as is likely the case. It might also be necessary to replace the combination fan/limiter switch, because the contacts are probably arcing due to the extra current drain of the fan with tight bearings (I know this because the arcing causes TV and radio interference to myself and others in the vicinity, which interference ceases when the heater is turned off and resumes when the heater is turned on and had about 20 minutes to heat up). Important: If no action is taken, the heat exchanger can be damaged and/or cracked, especially if the limiter contacts weld closed, which will allow the heater to exceed the limit temperature and probably crack the heat exchanger. This in turn will allow carbon monoxide fumes to enter the house via the ducts. Therefore the problem should be fixed ASAP.
I am currently trying to find someone who understands this heater to the extent described above and therefore has some chance of repairing it correctly. No success as yet, similar to your own experience.
Dave, if you discover anything at all about this fault, please let me know, as I am not going to waste my money on gas techs who are unable to fix the problem because they don't understand the system to the required degree.
Parts can be obtained from many gas supply houses. The one I normally use quoted about $300 for a fan and $150 for a fan/limit switch. This seems too expensive to me. I could get a whole second-hand unit for about $300. Will try to let you know if I make any further discoveries. Anyway, best of luck. Regards, VC60.
Aug 17, 2010 | Vulcan Heating & Cooling
Problem with Vulcan Powerhouse 145 cental heating unit.
You should have a high limit switch possible on the bloiwer compartment may be man reset or just bad you do not say how old unit is I would temp jump out high limit to test operation then replace asap
Jun 11, 2010 | Broan-NuTone 9965 Coil / Ribbon Heater
Vulcan Quasar 40 wall furnace - electronic display problem
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Oct 05, 2009 | Heating & Cooling
Vulcan Quasar 40 air issue
Hi the problem you have is your heater is cutting out due to the over temp switch getting to hot the reason for this is that your fan is not working thus not enough air flow is getting through the heat exchanger to keep it cool
your heater is designed to not exceed a certain temprature so as not to become a fire risk
to solve your problem you will need to replace your fan
this will solves your problem
Jul 27, 2009 | Heating & Cooling
Vulcan quasar 40 shut down when fan starts up
Replace the fan thermal switch located at the top of the heat exchanger. Unplug the power first as the switch is 240V.
Available from any plumbing trade shops e.g. Reece & Tradelink
Jun 03, 2009 | Heating & Cooling
Need fan for vulcan gas wall heater serial no. 1003129019
found a supplier using the Google search engine. Thanks any way.
May 14, 2009 | Heating & Cooling
Vulcan quasar elite heater does not display led readout or any lights when plugged into power point the point and switched on.
this is not an air conditioner but a fan forced heater. The control unit has died and a replacement is over $170.00 !! It's going to be recycled.
Jul 23, 2008 | Heating & Cooling
Heating & Cooling Logo
457 people viewed this question
Top Quasar Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Quasar Heating and Cooling Expert? Answer questions, earn points and help others
