Question about Toshiba e740 Pocket PC
Can't remove programs
Why can I not remove some programs on my Toshiba Pocket PC?
    Master:
  • 903 Answers
When you try to remove certain programs on the PDA the following message may appear and in some cases the program will remain no matter how many times you try to remove it: Due to the nature of the PDA and the fact that the operating system is resident in memory at all times, some .DLL files cannot be stopped and removed. For example, the program below uses a .DLL file to run a program on the Start screen and is therefore always running. The only way around this is to rename the file via Active Sync. In Active Sync on the computer, click on Explore. You may have to wait a short while until Mobile Device is displayed, then follow the program file to where the uninstall file is located, i.e. \Program Files\OmegaOne\BattPack\BatBar.dll. If you try and delete the .DLL file the following message will appear because the file is in use at the time: Select BattBar.dll file and rename this, making sure the file format has the .*** suffix and is different from any other valid format, for example, do not choose .jpeg / .mpeg. In this case we have renamed the file Aaa.aaa. Once the file is renamed and saved, remove the PDA and soft reset. The program linked to the .DLL will no longer be present on the PDA. You can now re-dock the PDA, synchronise and go back to Remove Programs and successfully delete the file.
Posted on Sep 08, 2005
Toshiba Pocket Pc e335
The are no drivers all you need is the activesync program from Microsoft. Activesync is the program that comes with all windows mobile devices for transferring data between your PC and mobile device.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 01, 2009 | Toshiba e335 Pocket PC
Can't sync Toshiba Pocket OC e335 with Outlook 2000 in Vista
I installed outlook 2003 instead of outlook 2000 that came with the pocket pc
Mar 25, 2009 | Toshiba e335 Pocket PC
Initialize my Pocket PC
When you initialize your Pocket PC, the factory default values are reset to the status as when you originally purchased the Pocket PC e570. NOTE: When you initialise your Pocket PC, all data stored in the memory is deleted. Personal programs and data are permanently deleted from your Pocket PC’s. The factory pre-installed operating system Pocket PC 2002 remains intact. Before initialization your Pocket PC, remove all storage cards. To initialize your Pocket PC, please follow these steps: Turn off the power to the unit. Then press the power button while pressing and holding the reset switch with the stylus. Release the power button. When a screen appears, release the reset switch When initialization is completed, the "Welcome Screen" will appear. Set up the system according to the startup procedure as indicated by the on screen instructions.
Sep 08, 2005 | Toshiba e570
When you initialize your Pocket PC, the factory default values are reset to the status as when you originally purchased the Pocket PC e330 or e310. NOTE: When you initialise your Pocket PC, all data stored in the memory is deleted. Your Pocket PC's initially installed programs are not deleted. Before initialization your Pocket PC, remove all storage cards. To initialize your Pocket PC, please follow the steps: Turn off the power Press the power button while pressing and holding the reset switch with the stylus. Then release the power button When a screen appears, release the reset switch When initialization is completed, the Welcome screen appears. Set up the system according to the screen as in the case of startup procedure.
Sep 08, 2005 | Toshiba e330 Pocket PC
When you initialize your Pocket PC, the factory default values are reset to the status as when you originally purchased the Pocket PC e740. NOTE: When you initialise your Pocket PC, all data stored in the memory is deleted. Your Pocket PC's initially installed programs are not deleted. Before initialization your Pocket PC, remove all storage cards. To initialize your Pocket PC, please follow the steps: Turn off the power Press the power button while pressing and holding the reset switch with the stylus. Then release the power button When a screen appears, release the reset switch When initialization is completed, the Welcome screen appears. Set up the system according to the screen as in the case of startup procedure.
Sep 08, 2005 | Toshiba e740 Pocket PC
Windows CE Program's
On the new Toshiba e310, e570 and e740 Pocket PCs, Microsoft's new operation system Pocket PC 2002 is installed. The question whether Windows CE programs run under Pocket PC 2002 has no definite answer. Most Windows CE Program will run under Pocket PC 2002. Pocket PC 2002 is an improved version of Windows CE, or rather, the next generation of Microsoft PDA operating systems. Some parts of the internal architecture of the operating system, like the e-Mail system, are of a complete new design and in fact, quite different. So if you run older Windows CE programs using "old and possibly, changed parts of Window CE system", it is quite possible that the Windows CE program will not run or will not operate correctly. Tip: To avoid problems or data loss, we suggest using Pocket PC 2002 programs only. Please note: Pocket PC 2002 is only available for Intel "Strong ARM" processors. This is different to Windows CE, where several CPU's types were supported. Only Windows CE Programs for Intel Strong ARM" processors may run an Pocket PC 2002.
Sep 08, 2005 | Toshiba e310 Pocket PC
Sep 07, 2005 | Toshiba e330 Pocket PC
"Communications Error 608"
If you put the Toshiba Pocket PC e740 in your USB Cradle you may receive a "Communication Error 608". This is not a serious error, it is just a false setting in the ActiveSync Program. Please follow these steps below to correct this problem: "Tap" on start and choose the ActiveSync program Then "tap" on "Tools" and choose "Options" in the ActiveSync Program Check under "Enable synchronization when cradled using" to see if the setting is on "USB" If it is set on "Bluetooth", please change it to "USB". Now you can close the application window Important: Please remove the Pocket PC from the cradle and then return it to the cradle. This activates the new setting Important to note: This above described issue occurs if you "tap" accidently on the Bluetooth Icon in the Program Group or activate Bluetooth of any other reason, the ActiveSync Option will be set to "Bluetooth" instead of "USB". This setting will cause the "error 608" if you put in the Pocket PC e740 in the Cradle and start to synchronize over USB.
Sep 07, 2005 | Toshiba e310 Pocket PC
Backup and restore data
Section A - How to use a Toshiba Pocket PC e740 without loss of data: Never let the battery fully discharge. Never disconnect the battery from the e740. Regularly backup your stored data. Always connect the product to an external power source before changing the battery. Section B – How to backup your data: B1 – Using Activesync You can make a backup of the Toshiba Pocket PC e740 data to your notebook or desktop computer. If you have backed up your data to your notebook or desktop you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data please DO NOT remove the Pocket PC e740 from the USB cradle and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instructions: Insert the Toshiba Pocket PC e740 into the USB cradle. A connection between the e740 and your notebook or desktop will be established. Please close all active applications on the e740. On your notebook or desktop start Activesync and select Tools and then Backup/Restore. Select Full Backup. Select Back Up Now to start the backup process. B2 – Using a Compact Flash (CF) or Secure Digital (SD) Memory Card: a) How to insert a Compact Flash Memory Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Confirm the direction of the Compact Flash memory card by lining up the side grooves of the card and groove edge of the card slot. Insert the card smoothly and completely. b) How to insert a Secure Digital Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Insert the Secure Digital card with it’s contact surface (the metal contacts) facing the back of Toshiba Pocket PC e740. Press the card down until it clicks. You can make a backup of the Toshiba Pocket PC e740 data to your Compact Flash or Secure Digital memory card. If you have backed up your data to your Compact Flash or Secure Digital memory card you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data using the DataBackup program please DO NOT remove the Compact Flash or Secure Digital card from the Pocket PC e740 and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instr
Sep 07, 2005 | Toshiba e740 Pocket PC
Toshiba e740 Pocket PC Logo
109 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
