Question about Carrier 38BRC048 Air Conditioner
Replacing a blower motor on a TRANE unit
Need to know the proper way to wire motor and capacitor.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Look on the motor it self or website that motor.! Thank -you-very-much!
Posted on Aug 28, 2008
HVAC Problem: Trane 1400XL furnace 'microcycling' every minute. blower 25s on, 10s off
Check the fan relay, the limit switches(Klixons) on the heat exchanger and the electronics that control the fan relay.
Oct 30, 2017 | Heating & Cooling
Trane twe036c140a1 blower motor kicks off and on and is hot to touch
if it has a capacitor id try replacing that first.
Jul 11, 2017 | Heating & Cooling
Trane xl80 blower working intermittently
hello Miss/Mrs/Mr,
I have the furnace trane xl 80, when I turned for heat everything working but only blower motor was not running, I wait for 1 minute all system suck down? I guess the capacitor blow out, that the reason why blower motor was not running
Please email me that is the
Jun 24, 2012 | Heating & Cooling
My trane xe 1000 central air conditioning unit turns on and the fan os working, but no air is coming into tue house. The lines get ice on them outside. I left it off all night with no change in status
If you left it off all night and no air is coming out of supply registers then the blower motor is not running. If the system is getting frost on the suction line(the big copper line coming out of the outside condensing unit with rubber insulation on it) within minutes of turning the system on then that will confirm that the blower motor is not running properly.
Unless you are very experienced in working on air conditioning, i would call a professional to do the repair.
If the motor has to be replaced its takes an experienced technician to do it correctly.
It could simply be the run capacitor on the blower motor.
This is probably going to be a 5 mfd capacitor.
Turn off all power to air handler, remove service panel, set your multi-meter to mfd (microfarads),
place the leads on the connections on top of the capacitors securely for 5 seconds. You should read about 4.8 to 5, if not the capacitor is bad.
There are other possible problems that could cause your symptoms, but ultimately your blower fan is not blowing air.
Sep 01, 2011 | Heating & Cooling
Outdoor fan dont start i give it help to starte them the motor start and run.? i think is a bad motor ? ( trane XL 13i ) thanks for help.
Yes could possibly be the fan motor, but before you change the motor, check the capacitor. It looks like a battery and is located in the electrical section of the unit. It may have one capacitor for both the fan and compressor. If the capacitor looks swollen or pregnant it is bad. If you have a ohm meter you can also check to see if the capacitor is open. Take the capacitor out of the unit after shutting off power. Note where the wires go before you take them off. Check across the capacitor with an ohm meter. (turned on to highest ohm setting) If the needle jumps up and then quickly back down, the capacitor is good. If the needle on the meter jumps up and stays up its shorted and needs replacing. If the needle doesn't move at all , the capacitor is open and needs replacing. NOTE : If the fan motor is whining when it is running, the bearings are worn and the motor will need replacing.
Aug 04, 2011 | Heating & Cooling
Trane xe 1000 - 1/4 fan motor went bad - I replaced it with a used 1/3 from another trane unit - it had same wiring harness etc everything starts, runs, cools -cold air - but only for about 5...
Did the 2 fans have the same rpm. If there is not enough airflow through the outside unit the compressor will shutdown on high discharge pressure. Also make sure the fan blades are positioned right if there is a shroud for them. Did the other motor have a capacitor with it or did you use the 1 from the smaller motor. Sometimes the motor data plate will tell you what size capacitor you need. Let me know what you find.
Aug 24, 2010 | Heating & Cooling
Outdoor fan does not come on
most likely it the the cap that is bad. Is this in heating or cooling mode?
Jun 03, 2010 | Heating & Cooling
Trane XE1200 Fan Motor
Most likely problem with a not-so-old motor is the run capacitor for the fan.
Some units have fan & compressor capacitor combined into one -- others are separate.
The capacitor can be tested with a multi-meter with an MFD setting -- it should read reasonably close to the specs marked on the capacitor.
Charlie
Aug 19, 2009 | Heating & Cooling
Compressor fan motor runs backwards
Most likely a bad motor or bad capacitor. I would check the capacitor first as this is probably a $20 fix. The fact that it runs in the correct direction but at a reduced speed really leans hard to the capacitor.
Good Luck and hope this resolves things for you. Let me know.
May 09, 2009 | Goodman CKL24AR24 Air Conditioner
Carrier 38BRC048 Air Conditioner Logo
300 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
