Question about HP iPAQ HX4700 Pocket PC
Connect to the Internet
I just bought my new HX 4700 and try to connect to my internet. Home set up to connect to internet is via wireless speedtouch modem. Who can help me connecting to the internet using WIFI?
  • Anonymous Mar 30, 2014
    I put 194.168.1.254 in the address line and the error comes up saying that the site exists but can not connect. What I am trying to do is turn on the WiFi component of the modem. The wired connection works fine.
    Master:
  • 450 Answers
There are many things to look at when setting up WI-FI to work with your iPAQ. Here is a good link that walks you through the WI-FI setup, with helpful screenshots. Its a good place to start, hope it helps! http://wifi.aximsite.com
Posted on Sep 08, 2005
SOURCE:
Where is the WPS Button on my Thomson Speedtouch Router
Does the speedtouch 585v6 router have WPS and if so where is the ...
www.askmefast.com > Computers & Internet > Computer Networking > Router
  1. Cached
  2. Similar
Jump to The WPS button is located either at the back or top of your router.If ... - source: Trying to connect my wireless printer with the router at my new ... Router thomson speedtouch tasto wps ... Wps button speedtouch 585.
IS THERE A WPS BUTTON ON A SPEEDTOUCH ROUTER - Fixya
www.fixya.com/support/t20444391-wps_button_speedtouch_router
  1. Cached
Oct 1, 2013 - Question about Thomson Speedtouch St585 V6 Sl Wireless Modem ... do i find my password for my wireless speedtouch 585v6 router? my ...
Page 17 of the manual
https://www.cosmote.gr/fixed/documents/10280/652016/TG585_SetupUserGuide_en_v8.pdf/0878a24f-0922-408c-bd51-fff55a07f53a
Feb 02, 2017 | Thomson Computers & Internet
No internet connection
Check if you can , by pass the wizard and set the connection manually. Let me find more details for you
Thanks
proton
Jul 24, 2008 | NetGear RangeMax WPN824 Router
Hi all I have a Thomson Router ST585v6sl. I can connect to internet via cable but not wireless. Wireless light when you turn router on is red then goes out. I can't find an option in the routers...
i have one try using an ethernet cable and put in on internet explorer
192.168.1.254 That should be the speedtouch routers page
don't click the tabs on the right scroll down and find home networks there should be two options wireless and ethernet along with all the connections click wireless (if you cant click it click the home network tab then interfaces then click your router) then in the top right there should be something called configure now this is how it should be
Interface Enabled : Ticked
Network Name (Your Routers Name)
Interface Type: 802.11b/g
Channel Selection: Manual
Allow Multicast from broadband network: ticked
Broadcast Network name: Ticked
Allow New Devices: New Stations allowed automatically
Encryption : Use WPA-PSK Encryption
WPA-PSK Encryption Key: (Any Password thats memorable)
WPA-PSK Version: WPA
Apply if theres any changes (hopefully) try that if fails try one of these three steps:
1. go on 192.168.1.254 then click the speedtouch tab then click return to factory default settings to return it to the way you had it when you first got it. (WARNING: If you dont have your internet password you will have to call AOL for it)
2. Buy a HomePlug which is an ethernet cable that uses the electric wires in your house (example. http://www.amazon.co.uk/D-Link-DHP-307AV-PowerLine-Homeplug-Network/dp/B003L78F6U/ref=sr_1_11?ie=UTF8&qid=1298768566&sr=8-11)
3. Scrap the router and try a different one thats what i did well.. my speedtouch kept crashing and i couldnt hack it anymore now i have a new router and it was the best move i did.
Hope it works for you!
Ryan
2.
Feb 09, 2011 | General Computers & Internet
Just brought a Sony Bravia HX 800 and added a wireless LAN adapter (UWA-BR100) to get Internet TV. After network set up NOT able to access internet. Message reads Wireless device OK Local Access FAILED...
Hi
I got the Bravia KDL-40EX713 and the uwa-br100 I had massive problems getting it to work with a BT home hub. Eventually I found manual setting that work. Firstly I logged on to the router and went the the advanced settings bit, then I went to the DHCP table that shows all the devices connected. I picked an unused Ip address from the range of existing ones being used (this sort of thing 192.168.1.73)
I then used the following settings for the other fields (I don't think the secondary dns setting is right but it still works)
ip 192.168.1.73
sn mask 255.255.255.0
default gateway 192.168.1.254
primary dns 192.168.1.254
secondary dns 192.168.22.23
If the DNS server ip is wrong then you get local access OK but internet access failed.
Hope this helps.
Ian
Jan 30, 2011 | Apple AirPort Extreme Base Station
When I connect my wireless router to my computer the speedtouch cannot be detected by my computer therefore I have no internet on my computer but I have wireless on both laptops which are directed through...
you probably have the router set to static ip so first you have to assign your pc with an ip range of the router , then log in the router set to dynamic ip and make sure you connect cables as per router manual. if it does not work then disable firewall , enable upnp devices . After configuration of wireless router you can enable firewall again. If you are using vpn with speedtouch then you should configure speedtouch to store username and password to connect to isp
Sep 11, 2009 | Computers & Internet
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect to internet via wireless
my phone dont want to connect to intrnet
Jul 31, 2008 | i-mate K-jam Smartphone
Wireless router does not connect to the internet
While you have the router connected to your modem, try unplugging the modem and plugging it back in. This will force the modem to redetect network connections.
Apr 15, 2008 | D-Link Air DWL-122 802.11b Wireless...
Speedtouch st536 v6 to a wireless WAP54G
The wireless is not picking up the speedtouch. So its either the speedtouch wireless connection not working or the laptop one.
But if ur getting internet thru the wireless on the laptop then its definately the speedtouch.
Jus try powering off and on the speedtouch. That way the laptop should connect to it as it comes on.
KJ
Apr 14, 2008 | Computers & Internet
CF GPRS Modems for PDA??
Update to Window Mobile 5 and it should fix it. You would also need a GPS update from HP website for the PDA.
Sep 08, 2005 | HP iPAQ HX4700 Pocket PC
HP iPAQ HX4700 Pocket PC Logo
658 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
