Question about HP Photosmart C4280 Aio Printer
Print Cartridges Hi, Can't find the manual. Replaced the print cartridges (looks like the only way that they will fit in there) and it says "Print cartridges missing or not detected" HELP!!
  • Anonymous Sep 19, 2008
    I have the same problem and I can't seem to find a solution. Changing the print cartridges works for a while, but it always reverts to the same old problem after about a month of working! I know I'm not using ink that fast, I hardly ever print anything before it says "Print Cartridges missing or not detected" I'm really fed up with it.
  • sarajeen Sep 30, 2008
    I'm having the same problem. We haven't had the printer that long; this is only the second time we've changed cartridges. I opened the new cartridge this morning, put it in, and it won't let me print anything.
What's probably happening is there is excess ink on caked on to the contacts on the carriage (I think that's what they're called). They're pretty easy to clean and the cleaning process takes about a minute. Just remove whatever cartridges are in the printer, take a cloth that will leave a minimal amount of lint, and wipe at the dark spongey contacts located just below where the cartridges would sit (that is, on my HP C4280, as other models might have them somewhere slightly different, but they should be right around the cartridges' spot). When the caked on ink is removed and all you are wiping at is the sponge, insert the new cartridge(s) and the printer should work.
Posted on Oct 07, 2008
  • 31 Answers
My HPDeskjet says alignment failed. Cartridges are set to default quality. I just replaced the ink cartridge.
Are they refills? HP will not accept refills at all . I know from experience.
If they are HP cartridges then the print head is probably clogged. ( the big square tray that the cartridges fit into)
You'll have to remove it (just a latch or clip. Look in manual) and replace it. They can't be cleaned. I've tried on several different models.
Jul 14, 2016 | HP Deskjet 3050A e-All-in-One -...
I have an ESP2150 with an error message of printhead loose or missing. I checked print cartridges, I replaced print cartridges, I re-installed software and drivers.....I still receive the same error...
Unfortunately, trying to diagnose a printer without actually looking at the printer is a little like trying to diagnose a car engine over the phone. But, from the sound of it, the problem you are having is not exactly pertaining to the print "cartridges" but the print "head" which is the part of the printer that actually introduces the ink to the paper, and is actually part of the tray the ink cartridges fit into. Here is a picture of it:
This print head is able to be removed and replaced if needed. It may be something as trivial as being loose. You can remove it from the printer and reinstall it to make sure it is seated correctly. Here is a link for instructions on Kodak's website on how to uninstall and replace the print head:
Installing and replacing print head.
If the print head is either damaged or worn out (which can happen) you can replace the print head, which I just did a search online for one and it appears the print head is only around $35.00 to replace it. Here is a link to where I found a replacement print head:
Kodak Print Head Replacement for ESP2150
I hope this helps.
-Nathan
Sep 26, 2013 | Kodak ESP Office 2150 All-in-one Printer
Hi, i'm getting error message 1203 on the printer and we've lost the user's manual. Can you tell me what this is?
Error 1203 is a very interesting error code. Here is what I found out about error 1203
Error 1203 is a very interesting cartridge error. It means your cartridges overflow even from brand new cartridges after a several prints or right after you refilled the cartridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
I use the lint free cloth(coffee filter work great) with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
Then before you print anything, you should run aligned the cartridges a couple times then run clean cartridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of lint free cloth(coffee filter work great on those holder contact panel.
Article on refilling Dell ink cartridges
Rick
Sep 10, 2011 | Dell 926 All-In-One InkJet Printer
I have an HP D4300 printer/scanner and I can't figure out how to open a in order to change cartridges. Please advise.
Installation instructions
Always install the tri-color print cartridge in the left side of the print cartridge carriage.
Install the black or photo print cartridge in the right side of the print cartridge carriage.
To replace a print cartridge
1. Verify that the printer is turned on.
2. Load Letter or A4 plain, white paper in the paper tray.
3. Open the printer cover.
Chapter 10
64 Maintenance Maintenance
4. Wait until the print cartridge carriage moves to the right side of the printer and is idle
and quiet.
5. Press down on the print cartridge, and then slide it out of the print cartridge carriage.
6. Remove the replacement print cartridge from its packaging and carefully remove the
plastic tape. Hold the print cartridge so that the copper strips are on the bottom and
facing toward the printer.
1 Remove plastic tape
CAUTION: Do not touch the print cartridge ink nozzles or copper contacts.
Touching these parts will result in clogs, ink failure, and bad electrical connections.
Do not remove the copper strips. They are required electrical contacts.
Install print cartridges 65
Maintenance
7. Slide the print cartridge at a slight upward angle into the carriage until the cartridge
snaps into place.
8. Close the printer cover.
Align print cartridges for optimum print quality.
For information about storing print cartridges, see Maintain print cartridges.
For information about recycling empty print cartridges, see HP inkjet supplies recycling
program.
WARNING! Keep both new and used print cartridges out of the reach of children.
Download manual for proper guidance. http://h10032.www1.hp.com/ctg/Manual/c01438085.pdf
I hope this works for you. Goodluck!
Mongkey
"Understanding explains better..."
Jan 22, 2011 | HP Office Equipment & Supplies
Printing mechanism works but nothing is printed on the paper, print cartridges have been replaced with new cartridges, still no print
Hi
1.check your cartridge quility by coping an document
1a.if you have bad printing check expire date on cartridges
if cartridges have not expire try cleaning cartridges from printers menu
1b.if you have a good printing from copy
you need to reinstall printer in your pc using printers cd
if i helped you pls vote me
Sep 16, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I have a hp officejet 5510 that prints the first line and the next is light and than dark and than light again
The problem could be caused due to blocked printer nozzles or bad print head. Try cleaning the ink nozzles first.
1 Press Setup.
2 Press 5, then press 1.
This selects Tools and then selects Clean Print Cartridge.
A page of patterns is printed. The print cartridges are cleaned. Recycle or
discard the page.
If copy or print quality still seem poor after you clean the print cartridges,
replace the print cartridge that is affected. For information on replacing
print cartridges, see replace the print cartridges.
The link for the user manual can be found at
http://h10032.www1.hp.com/ctg/Manual/bpu72474.pdf
Thanks for using fixya
Proton
Apr 18, 2010 | HP Computers & Internet
Bogus message to replace print cartridge
To resolve the issue remove al the print cartridges and clean the print heads. Now insert all cartridges and try to align the printer. Click here for instructions to align the printer.
May 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
HAVE REPLACED A new BLACK CARTRIDGE SEVERAL TIMES BUT THE BLACK WILL NOT PRINT
It is very possible the black print head is clogged with dried ink.
Begin saving money for a new printer.
Clean the print heads manually:
Remove the cartridges.
There will be small extrusions where you removed the cartridges.  They are the print heads.  These need to be wiped down with cotton swabs dipped in rubbing alcohol.  Keep this up until you can see the miniscule holes in the top of them.  THE CRUCIAL STEP: Take something thin enough to fit in the holes and push it all the way through.  This will clean out the dried ink and you should be able to print now.
Aug 13, 2008 | HP Office Equipment & Supplies
Incompatible print cartridges?
just click on them to say ok, and accept the unsupported cartridges ( if applicable ) do you get the choice.
certain printers, have an option in printer prefs, to change cartridges. check the cartridges are the same ( or compatable )
if the cartridges have a chip fitted, they need to be reset if recently filled.
hope this helps mike @ Compurepair.
Feb 20, 2008 | Lexmark X2550 All-In-One Printer
IP4000 won't print anything except magenta
Hi make sure that the cartridges are fully installed and that you have taken the packaging completely off. Failing that there are two possibilities.
1 Print cartridges faulty or refills
2 Faulty Print cartridge head.
Thanks hope this is of some help
J
Dec 27, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
HP Photosmart C4280 Aio Printer Logo
162 people viewed this question
Seeker5211
Seeker5211
