Question about HP Office Equipment & Supplies
Recevied an error that said there was a problem with the "lamp" on my HP 5570 Scanjet
  • 31 Answers
Its the lamp of your printer
Posted on Aug 28, 2008
Lamp error
Yup!
The lamps have a limited lifetime (or it could have just failed prematurely due to some other reason).
For the cost of parts, it would be cheaper to buy another scanner.
Nov 01, 2013 | HP ScanJet 2400 Flatbed Scanner
HP Scanjet 5300C Light flashing 6 times.
At the bottom of this article see http://www.computerhope.com/forum/index.php?topic=34583.0 it appears to indicate what the error code is and a potential solution. Look for "By the way, the POST error 6" in the article
Jan 14, 2012 | HP ScanJet 5300C Flatbed Scanner
HP imaging device could not be initialized because of lamp error.
Does the lamp in the scanner come on at all? If not, then it is most likely bad. You can try disassembling the scanner and check that the lamp connectors are not loose.
Jun 21, 2011 | HP Scanjet G4050 Flatbed Scanner
Scanjet hp 3800 lamp error: what means? which part doesn't work?
the scan lamp is defective cahnge to a new one
Mar 30, 2011 | HP Scanjet 3800
My hp sacanjet 3970 doesn't work
Most likely cause of the "Scanner could not be initialized" error on the HP Scanjet 3970 is due to using an incorrect power adapter and cord -- the only power module and cord that work for the HP Scanjet 3970 are these part numbers: 8120-6260 for the power cord and L1970-80003 for the power module / AC adapter I hope this info helps you.
May 23, 2010 | HP ScanJet 3970 Flatbed Scanner
Lamp error in HP Scanner
It would cost more to replace the scanner assy than a new machine would cost you.
Nov 17, 2009 | HP Scanjet G2410 Flatbed Scanner
HP Scanjet 5590 Lamp Error "Bad or fading lamp (error -4430)" Fixable? Can I do it? Best source to purchase?
From HP forums:
The first thing I would do is to make sure your TMA is properly attached. Next, make sure your software is up to date and that any applicable patches have been applied.
Next, what OS are you using? What application are you trying to use to scan with? Can you scan from any other application such as word or another graphics program?
Oct 06, 2009 | HP Scanjet 5590 Flatbed Scanner
Hp scanjet 3970 on Mac: lamp error
Normally this error means that your lamp will no longer come on to scan anything. The only way to fix this is to replace the bulb. If your bulb is coming on, but you still receive the message, their is an internal error that must be checked by a repair center. You might want to check into the cost of repair as it is often cheaper to replace than repair.
Jul 10, 2009 | HP ScanJet 3970 Flatbed Scanner
I have an HP flatbed scanner 5590 - "lamp error"
I had the same problem and I finally unplugged for a few days
and when I replugged it worked !?
Nov 30, 2008 | HP Scanjet 5590 Flatbed Scanner
13 people viewed this question
Ben Johnson
