Samsung HC-P4241W Convergance problem
I have a Samsung HC-P4241W with a big convergance problem. I changed both STK 394-250 ic's and the convergance is still off. I tried the "self focus" button and still the same problem. I would like to do a manual convergance and align everything my self but I can not figure out how to do so. Can anyone help me with this problem? Thank you
Press mute 183, if it isn't 183 it's 138.   You will see a large grid which you get the fun of adjusting, it's tedious as all get out! Enjoy!
Posted on Jan 18, 2009
When i turned on my Hc-p4241w i smelled a burning smell then the color started looking 3d, i took a flashlight & looked through the left side of the tv and saw a orange glowing inside and i shut the tv...
Your Convergence output is burnt.DONT turn that TV on until convergence IC's are replaced,orange glowing inside that you see it is resistors that overheating and burning.Unplug TV from outlet before more damage is done
Aug 23, 2011 | Samsung HC-P4241W 42" Rear Projection...
The colors are all messed up. Everything is yellowed with a blue double behind it. The screen is preaty dark on the sides and lighter in the middle?
Hi
Thanks for using FixYa.The issue is with the failed convergence (STK) ICs which needs to be replaced. It's not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you'll have to open the back of the unit and then replace the ICs (STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime.
There are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 26, 2010 | Samsung HC-P4241W 42" Rear Projection...
Self focus stop working on my samsung 42 in tv does any one knows what to do before call out!!!!!!
Convergence ICs need to be replaced.
Go to Encompass Parts Distribution 1-800-638-3328
Type in your Model # for Parts List Just replace the whole convergence board ,if you can solder just order STKs big black ICs will have PN# on them. 1-800-628-1118 and sometimes its Faster,Cheaper in the long run.just to replace the whole board.
Sep 28, 2010 | Samsung HC-P4241W 42" Rear Projection...
Samsung hc-p4241w problem
Look for 2 Big black chips they will be together on convergence broad STK-392-110s,120s replace both ics.Use STK-392-180s
Mar 29, 2008 | Samsung HC-P4241W 42" Rear Projection...
Samsung HC-P4252W convergence problem
You need to change the convergence ICs. This is an inexpensive repair if you do the repair yourself. The ICs are located on the big heatsink they should Be STK392-110 or 120 or else they could be STK 392-010 or 020 . But what ever STK number you have you will need to replace both. Here is a link where you can get replacement ICs and they include step by step installation instructions with the new ICs. Here is their link.
Mw-60sz12
Mar 29, 2008 | Televison & Video
Samsung HCP4363WX/XAA
Was wondering if you got set fixed yet? STK-392-180s are the ics I use when repairing convergence.Replace both chips.
Jan 31, 2008 | Samsung HC-P4241W 42" Rear Projection...
HC-P4241W
you need to replace STK 392-110s these are your convergence chips and will cause this problem some are stk 120s 150s,up grade to 180s.
Jan 08, 2008 | Samsung HC-P4241W 42" Rear Projection...
Samsung HC-P4241W 42 in. Rear Projection CRT aging
First off, do you not know Internet etiquette? Caps are considered yelling or shouting! So please! head You have the typical convergence failure of the convergence correction IC's. They BOTH need to be replaced. If you have no solid state printed circuit board experience, play it safe and call in a pro to assist you in this repair. Good Luck
Jul 28, 2007 | Samsung HC-P4241W 42" Rear Projection...
Blue haze around image, yellow streak
the tv color circuit is off frequency change the color ic take a look on the crystal that gives the 4.8.mhz burst could be that it needs to be replace dont rule out the video IF change the two ICs you mention.good luck.from the look of your tv screen that is my conclusion.good luck.email me at nicodhem@yahoo.com
Apr 04, 2007 | Samsung HC-P4241W 42" Rear Projection...
Televison & Video Logo
210 people viewed this question
Top Televison & Video Experts
