Question about Toshiba e310 Pocket PC
Dialing properties (prefix)
How can one set up the dialing properties (prefix) on the Toshiba PocketPC?
    Master:
  • 903 Answers
Download file
Posted on Sep 08, 2005
    Master:
  • 903 Answers
Please find a PDF file for download with all this information, above. Download and unpacking instructions: To download the file, simply "click" the desired file or link and select save to disk. Download the file to a known directory on your hard disk drive. For example: c:\Temp Open Windows Explorer and locate the "downloaded file" on your hard disk drive. Use an unpacker program to extract the files to a known location on your hard drive. The shareware WinZip unpacker can be downloaded from http://www.winzip.com To setup the dialing properties on the Toshiba Pocket PC, please do the following steps: Tip on start -> settings choose the "tab" connections tip on connections choose the "tab" dialing Locations tip on the button "Dialing patterns" enter your necessary field parameters Please note: disable the "keyboard" in the dialing Locations screen, otherwise the button Dialing patterns is not visible. Tip: Due to the fact that a prefix to dial with a Handy is not necessary, it is a good idea to set all dialing pattern to "G" , which indicates a local number. If one want to use HCSD or GPRS it is recomended to set this parameters to "G", otherwise dealing will not work.
Why i cannot send a fax from my kyocera ecosys fs-1135 mfp?
If you can receive but not send, maybe the number you are sending to should include some pauses, especially at the end of the number. If you have a good dial-tone when you do "On-Hook" then there is nothing preventing you from sending on the machine end. Has the phone system just gone digital? You may need a filter to translate pulses properly. Can you call your cell-phone using On-Hook dialing? I would say there's nothing wrong with the machine. But you'll get blamed for the communication problem in any case. Try manually dialing using On-Hook dialing (turn your Monitor sound up high) and listen for some kind of message. It's a number or line problem. Did they just start requiring an 8 or 9 to be prefix-dialed to get "out?" Or stop requiring it? Maybe there is a prefix number programmed through the default menus that you don't need anymore.
Sep 06, 2014 | Copystar Kyocera FS-1135 MFP/DP Printer
How to closed zero dial in this phone set
phone circuits included electromechanical relays which imposed limitation on the speed of dialing a digit, and therefore dialing a complete 10-digit telephone number could take up to ten seconds, during which hardware resources had to be dedicated to a circuit. The Bell System organized the numbering plan to minimize the cost of providing automatic dialing to large population centers. The second digit of all area codes was 0 or 1, while the second digit of the exchange triplet was never 0 or 1, thus facilitating the recognition of whether a user was dialing a full 10-digit number or merely dialing within the local area code. In this coding scheme it was not yet necessary to dial a leading 1 for access to long distance circuits to other area codes. In some regions, local numbers were 7 digits, or occasionally less, but a toll call within the area code required a preceding 1. Area code 617 in eastern Massachusetts used this system in the early 1970s, while the Chicago area (312) did not. In the Chicago area, one could call the Boston area by dialing only 10 digits, while in Boston, to call Chicago, one would be required to use 11 digits, including the prefix 1.
Dec 19, 2013 | NEC Lands Phones
Hello, We can receive faxes but can no longer send faxes from our HP laserjet 3390. The display window shows a 9 infront of the number we are trying to fax, dials that number and then does not complete...
You have to go into the settings on the fax machine. There will be an option for a prefix number. Someone put a 9 in there. Having the 9 in there will make it dial a 9 then the number you are trying to faxt too. Remove the 9.
Mar 03, 2011 | HEWLETT-PACKARD Office Equipment &...
I am trying to call a french cell phone in Denmark. I am using a french cell phone in France. I have no idea what prefixes to add. Melanie
For dialing the number in the same country you need not to add any prefix just dial the correct number.
Aug 01, 2009 | Lands Phones
Cannot fax because i dont know what to put in the set up under prefix
I believe the "Dialing Prefix" refers to a number that you put in that will allow you to access an outside line or get a dial tone. So in an office environment e.g if you dial '99' before you can dial a number. You can probably leave it blank in an home setup.
Anyway here's a link to the user guide:
http://images.lexmark.com/publications/pdfs/2007/5400/v3421438_en.pdf
Let me know if you still have problems.
May 27, 2009 | Lexmark X5470 All-In-One InkJet Printer
How can i download users' manual. I need to get the automatic "9" out of the outgoing fax number.
Inserting a dial prefix A dial prefix is a number or group of numbers that are automatically added to the beginning of every fax number you enter at the control panel or from the software. The maximum number of characters for a dial prefix is 50.
The default setting is Off . You might want to turn this setting on and enter a prefix if, for example, you have to dial a number such as 9 to get a telephone line outside of your company telephone system. While this setting is activated, you can dial a fax number without the dial prefix by using manual dial. For instructions, see Using manual dial .
To set the dial prefix
  1. On the all-in-one control panel, press Menu .
  2. Use the < or the > button to select Fax setup , and then press c00597634.gif .
  3. Press the > button once to select Fax Send setup , and then press c00597634.gif .
  4. Use the < or the > button to select Dial Prefix , and then press c00597634.gif .
  5. Use the < or the > button to select On or Off , and then press c00597634.gif .
  6. If you selected On , use the alphanumeric buttons to enter the prefix, and then press c00597634.gif . You can use numbers, pauses, and dialing symbols.
To get the manuals visit the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=135&prodTypeId=18972&prodSeriesId=1140783
Regards,
Nikhil Gedam
Dec 16, 2008 | HP LaserJet 3050 All-In-One Printer
I have a lexmark x4270. Having problem sending fax. Sending local number, it's OK, but sending a different area code, it uses the local area code then the first 7 number of that number. Because someone...
Hi zoaj,
More then likely you have the fax set up to USE A DIALING PREFIX.
Therefore it is automatically doing this, regardless of what you input.
Follow the proceedure below ( which comes directly from the users manual for your printer type ) to change this. Delete the " USE A DIALING PREFIX " information.
once that is done, it will no longer automatically add the prefix for you. :)
I have BOLDED the relevant information below that pertains to this.
Please take a moment to evaluate my solution. Your appropriate rating of my solution would be greatly appreciated.
Thank you,
Using the Fax Setup Utility Use this utility to adjust the fax send and receive settings. When you save these settings, they apply to every fax you send or receive. You can also use this utility to create and edit your speed dial list.
  • Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Fax Setup Utility.
  • From Lexmark All-In-One Center All-In-One Main Page, click Fax Setup Utility.
The following table describes the Fax Setup Utility tabs:
On this tab:
You can:
Send
  • Enter your name and fax number.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Choose whether to use error correction.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report.
Receive
  • Choose whether you want to print a footer (date, time, and page number) on each page.
  • Automatically reduce an incoming fax to fit to the paper size loaded or print it on two sheets of paper.
  • Select whether you want to forward a fax or print it, and then forward it.
Connection/Dialing
  • Select the number of times you want the machine to redial and the time between those attempts if the fax cannot be sent on the first try.
  • Select the phone line format you want to use (Pulse, Touch-tone, Behind a PBX).
  • Enter a dialing prefix.
  • Choose how (manually, if fax tones are detected, or after a certain amount of rings) you want to answer incoming calls.
  • Select a distinctive ring.
Speed Dial
Add to, create, or edit the speed dial list.
Group Speed Dial
Create a group number and name, and then add phone numbers to the group.
Oct 11, 2008 | Lexmark Office Equipment & Supplies
No dial tone
and does your line to your computer have one of the filters installed going to your modem line?
check your computers warranty here 4 FREE
Mar 18, 2008 | Symantec WinFax Pro 10.0 for PC
Removing fax prefix
it's in your settings..usually, it will say 9,,1 etc...just remove the 9 and commas..
this link might be of some help to you
Feb 28, 2008 | Office Equipment & Supplies
Toshiba e310 Pocket PC Logo
370 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
