Toshiba e310 Pocket PC
Problem for Toshiba e310 Pocket PC
Windows CE Program's
By Guest on Sep 08, 2005
Can I run Windows CE Program's on my new Pocket PC?
Best Solution
posted on Sep 08, 2005
Helpful)
Maya
Rank: Wiz  Toshiba Expert
Rating: 83%, 342 votes
On the new Toshiba e310, e570 and e740 Pocket PCs, Microsoft's new operation system Pocket PC 2002 is installed.
The question whether Windows CE programs run under Pocket PC 2002 has no definite answer. Most Windows CE Program will run under Pocket PC 2002.
Pocket PC 2002 is an improved version of Windows CE, or rather, the next generation of Microsoft PDA operating systems. Some parts of the internal architecture of the operating system, like the e-Mail system, are of a complete new design and in fact, quite different.
So if you run older Windows CE programs using "old and possibly, changed parts of Window CE system", it is quite possible that the Windows CE program will not run or will not operate correctly.
Tip:
To avoid problems or data loss, we suggest using Pocket PC 2002 programs only.
Please note:
Pocket PC 2002 is only available for Intel "Strong ARM" processors.
This is different to Windows CE, where several CPU's types were supported.
Only Windows CE Programs for Intel Strong ARM" processors may run an Pocket PC 2002.
You rated this solution as "Helpful".
Popular Solutions for Toshiba e310 Pocket PC
Questions and Unsolved Problems for Toshiba e310 Pocket PC
Do you recommend Toshiba e310 Pocket PC?
Answer
Answer
How do I change the battery in the Toshiba Pocket PC e310? I can't find it in the manual.
Answer
I cannot make first connection. I have installed the latest Active Sync but cannot complete... (More)
Answer
How do you connect a toshiba e310 to the internet? I heard you need an SD wireless card but i do not... (More)
Answer
i try to charge it through the usb port but it wont charge is there a different way to do it?
Answer
when i charge the Toshiba Pocket pc e310, it appears to be charging, but when i unplug it, it does... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba e310 Pocket PC:
Top PDA Experts
Rank: Guru Guru
Solutions: 567
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
