Question about Cameras
When battery put into camera it starts to overheat and doesnt work at all
  • Anonymous Sep 08, 2008
    camera overheat warning, said to shut down
Easy Cost Me Nuthing
Posted on Aug 28, 2008
To prevent overheat camera
I don't understand. The camera should prevent itself from overheating. When the camera becomes to hot it will switch off itself. If your camera is switching off more than once, something could be wrong. But if not shooting continues of filming for a long scene in a normal environment the camera must work ok. Photo cameras are not make to capture films for more than 10 minutes. That will overheat the sensor. When shooting in full sun light we try to put the monitor on full brightness. That also will warm up the camera. And can bring it to shut down. It will also exhaust the battery quickly.
Dec 04, 2013 | Nikon COOLPIX L20 Digital Camera
I put new batteries in my camera-but doesnt do anything. I left camera on,I think and then thought batteries died so then replaced with new ones.now nothing works.
This happened to me as well. I took the batteries out and put new ones in three times (same batteries). The third time the camera started working again as soon as I closed the battery compartment and tried on "on" button.
Mar 20, 2011 | Kodak EasyShare C533 Digital Camera
I have a Carrier Gas Furnace Model # 395CAV024055ABJA, I works fine if you keep the temp low, like 68, so that it doesnt come on very often, but if you try turning it up and it needs to run for awhile, it...
It sounds like it is going into overheat mode. Check the overheat sensor, make sure the flue is clean, make sure any filters are clean, also check the gas passage inthe heat exchanger, if there is a blockage from soot the system will overheat
Feb 24, 2011 | Carrier Heating & Cooling
Sony DSC 500 doesnt start when i want to.
Have you tried cleaning the battery contacts inside the camera? The problem that you describe is frequently due to a corrosion buildup that prevents the full power of the batteries from flowing to the camera. Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, then wipe both ends of the batteries and reinsert them into the camera. This cleaning clears the problem about 90% of the time, and I hope it works for you.
Sep 19, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Camera won't work. Only shows Change Batteries,even with new ones
akaline batteries wont work
only rechargable FULLY CHARGED
if that doesnt work clean battery terminal
Apr 28, 2009 | Canon PowerShot A470 Digital Camera
Camera turns off by itself after taking a picture
A friend of mine had the same prob after putting in brand new batteries, it was i bit wierd but i tried some different batteries and it started working , try some new batteries. hope this helps.
Feb 28, 2009 | Panasonic Cameras
Pentex optio camera
Hi, Same problem. Somebody had suggested gentle tapping. With nothing to loose if it doesnt work my wife banged it more than gently onto a desk and it started working. Hurrah! Dont blame us if it breaks.
Raghu and Faye
Aug 27, 2008 | Pentax Optio S7 Digital Camera
My camera doesnt work.
i suggest that there is likely a motherboard fault or a board fuse has blown. the fuse needs to be replaced by a qualified technician, this will prevent any further damage to motherboard.
Jun 07, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
Power doesnt stay on for long on my polaroid digital camera
im gonna give an example first ( if u turn ur camera on and dont do anything it will power off) so go to ur menu were u set stuff up and c if theres a spot were u set power on\off time and if its below a minute put it on a minute or higher i recomend a minute though so if it turns on in ur purse it wont run the batteries down if that doesnt work and ur not using lithium batteries try thoughs if thoughs tips dont work send it in to the company so if it is really messed up and instead of sending it in to the company u have a electronics store work on it and the camera is like half way fried or something and you had a peron that doesnt work for your cameras company work on it the company will take it back and give u a new 1 cause on the warranty it states that if u have a person that doesnt work for the cameras company work on it and they didnt think it was ur fault the camera was messed up they would give u a new 1 but like i said if u have someone that doesnt work 4 that company they wont give u a new 1 so b careful
Apr 30, 2008 | Polaroid i733LP Digital Camera
Hp PhotoSmart R725
oh i know where it is: if you open the thing at the bottom of your camera where the battery and memory card goes, next to the memory card place to put it there is a little hole you probably need the end of a paper clip or something like that and then put it there(you hear a little click sound) and then you hold it there for 10 sec and then take the battery and memory card out and then count to ten and then put only the battery back in. and then start your camera and it should be fine. it micht have been the memory card. this happened to me and then it kept on doing it and i tryed everything even reseting it and now it doesnt even turn on! i know its not the battery because if it was the battery then it would flash that blue light to show that it needs charging but ive tried everything and it still doesnt work.=(
Dec 29, 2006 | HP Photosmart R725 Digital Camera
Cameras Logo
63 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
