Question about Canon PIXMA MP160 All-In-One InkJet Printer
How do I install a new ink cartridge, and remove the old one?
I can't access the ink cartridge - and the manual doesn't give me this info.
  • 2,036 Answers
Go to this link. In the search window in the center of the screen, type "replace ink" and click on the Search button. You will get a list of answers that show you step-by-step illustrations on how to replace the cartridges.
Posted on Aug 28, 2008
I just purshased a lexmart pro 705..How do you install the ink???please help
Replacing ink cartridges
Make sure you have a new ink cartridge or cartridges before you begin. You must install new cartridges immediately
after removing the old ones or the ink remaining in the printhead nozzles may dry out.
1 Turn on your printer.
2 Open the printer.
Note: The printhead moves to the cartridge installation position.
3 Press the release tab, and then remove the used ink cartridge or cartridges.
4 Install each ink cartridge. Use two hands to install the black cartridge.
Note: Install the new ink cartridges immediately after removing the protective cap to avoid exposing the ink to air.
5 Close the printer.
The setup guide is on theCD you received with the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 23, 2011 | Lexmark Office Equipment & Supplies
How to change the ink cartridge in a Canon iP1900 printer please
1•Protect your desk, printer stand or work surface by placing an old newspaper in front of or next to the printer. The newspaper will provide you with a place to work without getting ink anywhere you don't want it. It seems as though no matter how careful or neat you are, a little bit of ink always manages to escape when replacing an ink cartridge.
•2
Prepare the new ink cartridge for installation. Remove the replacement cartridge for your Canon printer from all of its packaging. You may need scissors to remove the heavy wrapper. Leave the protective orange cap or tape in place for now. Set the new cartridge aside on the newspaper.
•3
Remove the old ink cartridge from the Canon printer. With the printer on, open the front door or panel of the printer. Wait a second or two and the ink cartridge holder should move to the opening where it is accessible. If it does not move, shut the door, turn the printer off for a moment, turn it back on and try again. Lift the small lever that secures the ink cartridges within their holder. On most Canon printers, it is colored green and located on the right side of the ink cartridge holder. Gently lift the old ink cartridge out of the printer.
•4
Place the new ink cartridge in the printer. Remove the plastic cap or tape protecting the ink cartridge, being careful not to touch the black and gold "sensor" area of the cartridge. Gently but firmly push the new cartridge into the empty slot left where you removed the old ink cartridge. The label should be facing outward. You should feel the cartridge pop into place. Then push the lever back down that you lifted in Step 3. Close the printer door. Use paper towel or wet wipes to clean any ink from your hands.
Aug 18, 2010 | Canon Office Equipment & Supplies
How do I change the ink cartridges in my Canon MP480? rn_bluediamond@yahoo.com
Step 1
Step 2
Step 3
Step 4
Aug 11, 2010 | Canon Pixma MP480 All-In-One InkJet...
Lost my manual, need to change the ink cartridge, help
  1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
  2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
How do i remove old printhead and install new one
Replacing the printhead If your printhead is damaged or broken, you may replace it yourself.
  1. Make sure your printer is turned on.
  2. Open the printer access door by lifting from the recessed hand-holds on the sides of the unit. autourg00977009id2130369.jpg
    The printhead moves to an accessible position for handling the ink cartridges. The ink cartridges are seated in the printhead.
  3. Pinch the latch on the ink cartridge with your thumb and forefinger and lift it out of the print head. Remove both ink cartridges.
    caution.gif CAUTION:
    Insert the ink cartridges into the newly installed printhead as soon as possible to prevent any drying of the ink.
  4. Unlatch the printhead by lifting the rectangular latch on the top of the printhead.
  5. Remove the old printhead from the carriage .
  6. Remove the new printhead from its bag.
    Do not touch copper contacts on the printhead, as this may damage it.
  7. Remove and discard the black plastic casing and the orange protective cap.
  8. Place the new printhead into the carriage.
  9. Push firmly against the target label on the printhead until you hear it click into place.
  10. Re install the ink cartridges. As needed, see Replacing ink cartridges.
  11. Close the printer access door. The printer should now complete a printhead calibration to ensure that it is ready to for normal operation.
Nov 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
New color ink cartidge won't work
Did you remove the tape on the bottom of the cartridge before you installed it?
Jun 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Ink
  1. Buy only genuine Dell replacement cartridges. Dell states their printer cartridges cannot be refilled with ink and that only their cartridges work in the printer.
  2. Bring the cartridge carrier of the printer to the center so you can access the ink cartridges. Open the cover of the printer and the carrier slides to the center. Make sure the printer is turned on.
  3. Remove the old black ink cartridge to use the color cartridge. If you allow the old black cartridge to remain in the printer, you will get error messages that the ink is low. The printer may also keep reverting back to the black ink as the default color when printing.
  4. Open the package of the new color cartridge carefully. Remove any blue packing tape that's on the ink cartridge. Take care not to touch the gold area or you could damage the cartridge. Insert the new color cartridge into the correct slot in the printer, the right side of the cartridge carrier. The ink cartridges aren't interchangeable; they need to be placed in the correct slot.
  5. Close the cover on your printer after installing the color cartridge. Run a print test to make sure the color cartridge is installed correctly. Use the Dell Ink Management System to monitor your printer and all-in-one functions. Thanks Thiru
Jun 15, 2009 | Dell 810 All-In-One InkJet Printer
Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
May 27, 2009 | HP Business InkJet 2800 Printer
New ink cartridge for Kodak Easy Share 5300 will not work
The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error.
So to fix your problem Open the access door and Remove the ink cartridges. Then download and install the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
I hope this helps
Mar 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
