Question about TalkSwitch TS-200 Phone
Dead phone The TS-200's display is blank, until I pickup the handset, then the message light comes on and a few veretical bars on the display. This repeats with each on hook/off hook. I have replaced the power supply, however I get the same result.
Handset display lights up but is blank
If the batteries in handset are old then replace it. Follow battery change instructions in this manual.
http://service.us.panasonic.com/OPERMANPDF/KXTG5631S.pdf
Sep 12, 2014 | Panasonic Lands Phones
NOKIA 1203-2 HANDSET DEAD GIVE ME SOLUTION
set dead mobile mai sabse pahle kis section ko check karna chahiye.
Nov 23, 2010 | Nokia 1208 Cellular Phone
Own model KX-TG6031CM. Handset display is lit up
need access code to retrieve messages for kx-tg6031cm panasonic phone
Jan 23, 2010 | Panasonic Lands Phones
No led when handset on charge. no response. phone dead. Handset has not been used for few months.
1.The handset might have collected moisture , so you need to dry it out.
Remove back,sim and battery dry out by placing in a warm room NOT ON THE RADIATOR for 6 hours then connect back together then try.
2. Also take into account that no led`s will perhaps show until after 30 mins of charging i.e screen blank.3.
The phone may be dead due to the battery not having been charged for so long , go to your dealer and ask to check it with a new battery.
Hope some of that helps!
Nov 19, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Message waiting indicator light will not turn off keeps flashing
Slide the Nortel Grey Bar above the Hold & Rls buttons to reveal the setup button.
  1. Hit that button to show *Options List / # Setup list
  2. Press * to go into options.
  3. Use the arrow buttons or hit 3 to go into CLEAR MESSAGE WAITING
  4. Then hit 3 again to clear the message waiting
This should resolve the blinking light.
Nov 11, 2008 | Astra Meridian 9417 Corded Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Handset dead
Upma I have experienced this before and if the phone has been damp by body heat or other moisture then it does do this. try drying it out with a hairdrier on a cool setting. then leave it to dry properly for a couple of days in a warm NOT HOT place. the keypad will start to work and the battery will settle as well. let me know how this goes. t1m0thy
Jun 27, 2008 | Motorola Mobility RAZR V3x Cellular Phone
How do I add an extension handset to my current config?
IF it was a used handset it was likely registered to another base. I just switched bases (1line to a 2 line base). I had to "deregister" the handsets from the old base. I am not sure if you can deregister if the old base is not present? With the old base plugged into power I hit the "function key" at the bottom left of the handset and scrolled down to initial settings. Under registration is "deregistration". I selected that and it put the handset back to its default out of the box. Then simply hit the mute button on the New base and OK on the handset. Worked for all 5 of my old handsets.
Hope this helps
Jan 27, 2008 | Panasonic KX TGA270S Cordless Expansion...
Message Light flashing continously
Resetting the New Message LED
If the LED remains on after you’ve retrieved your messages, you may need to reset
the indicators. With the phone is in standby mode, press and hold find handset on
the base until the paging sound stops (about 5 seconds).
Dec 12, 2006 | Uniden TRU8865-2 Expandable System...
Handset stopped working properly
mine is doing the same thing. I did hook the phone directly up to a power supply and all was well.
Oct 31, 2006 | Vtech VT 2461 Cordless Phone
TalkSwitch TS-200 Phone Logo
29 people viewed this question
Top TalkSwitch Lands Phones Experts
Are you a TalkSwitch Lands Phone Expert? Answer questions, earn points and help others
