Question about Maytag Dryers
I have a maytag gas dryer that when turned on it will heat up right the first time (apx. 20-30 sec. after turning on) then it won't heat up again at all.
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Check the lint filter in the dryer and clean it every load.
Now go outside and check the opening where the the dryer blows outside!
There is usually a screen at the out side or a flap like door. They both are there to keep small animals from getting in!
if the screen is blocked even half way you will not have heat enough to dry! Or the door type flap is stuck closed the same results!
If this does not solve the problem, you will need service!
Here is the service company I refer my appliance customers to0!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments!
1(800) 905-9505
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
I have a Maytag LSE1000. The dryer and washer each have an issue at the moment. The dryer intermittently won't engage when it is turned in. When you press the "regular" button to start it,...
I really have NO idea what's causing your Maytags to misbehave, BUT I can tell you that the Maytag service centers have always been very accommodating when I've called about problems with dishwashers, dryers, and washing machines.They have explained the construction of the appliance and even told me the type of tools I needed to make repairs! If you still have your owner's manual, the toll free number should be in there. I hope this helps!
Jul 28, 2011 | Maytag Dryers
Gas dryer dosn't heat properly
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jul 07, 2010 | Maytag MDG3600BW Gas Dryer
My Maytag DG212 gas dryer is not drying well, the hose and vent are clear. What I see is the flame will only last 10 to 15 sec. and then go out.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 02, 2010 | Dryers
No heat
heatman101
May 19, 2010 | Maytag MGD5600T Dryer
Drum still turns but no heat where do i find the heater
heatman101
May 12, 2010 | Maytag PYE2300AY Electric Dryer
The dryer runs about 10 seconds then shut off. It
Maytag gas dryer , runs for about 15 sec. heats up , then completly shuts off , Checked thermal fuse & it was blown , replaced & it ran for about 15 sec again & blew fuse again ....help .
Apr 26, 2010 | Maytag PYE3300 Dryer
Maytag gas dryer not heating
You may want to disconnect the vent from the back of the dryer and try it. Flame rollback will cycle the burner off by the high limit.
Considering what you have already done to it, if the problem still exists you probably have bad coils on the gas valve. make sure you replace them as a set.
The thermal fuse is a one time device. If it opens, the burner will not come on at all.
Apr 28, 2009 | Maytag Neptune MDG9700A Gas Dryer
Maytag MDG16CSBWW heating problem
I have a Miele Novotronic T560C. The tumble drier is working fine except the air circulating is cold - it does not heat up at all. What could the possible reason for this and/or solution?
Oct 05, 2008 | Maytag MDG16CS Gas Commercial Dryer
Maytag Gas Dryer SDG515DAWW - heating stopped
if it dont come on in 30 secs replace it
Dec 30, 2007 | Maytag MDG2706A Gas Dryer
Dryers Logo
43 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
