Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
GE Profile Artica Refrigerator
Our refrigerator is about 4 years old. The freezer and refrigerator has stopped working. It did start working again, after it was left unplugged for a couple of days, but quit again.
Thanks for you help.
stephanie
206 546-4280
  • mlap43 Jan 21, 2009
    GE Profile stainless top freezer w/ external water and ice dispenser in freezer door. Gradually reaches point where food in freezer thaws, and refrigerator section gets too warm. After thorough manual defrost, fridge works well for a couple of weeks then problem begins again. Need to know location of defrost timer and coils. Can one over-ride the timer and turn ON the defrost cycle? Thanks.
  • Anonymous Feb 27, 2009
    I had the same problem. We just got it repaired yesterday and found out that it has two motherboards, one of which went out. We were lucky that it was only one of the boards and not the second board and the compressor (which still may go out). From my understanding this is a common problem, and I am trying to find out if there was some kind of recall and any notice to the consumer?
  • 1,543 Answers
OK, it sounds like you have a defrost problem. When left unplugged for a few days the frost melted off the evaporator (the cooling coils behind the freezer wall) but after you ran it again, the coils blocked the air flow again, usually happens after a week or so, depending on # of door openings, humidity in home, etc. Most likely you have a burnt out defrost heater.
Posted on Aug 28, 2008
Ge profile artica profile freezer on top -- refrigerator clicking and not cooling
Check compressor is working. If not, replace relay and check. If still compressor not working, you have to replace compressor.
Feb 12, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Temperature in refrigerator will not stay set. It keeps getting colder. I have a GE Artica model PSS27SGMD. It is a side by side with ice through the door. It is +- 9 years old
GE Artica had problems with the "Motherboards" originally installed. They have since switched manufacturers so my educated guess that is the problem.
Jan 08, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
7 year old GE profile Artica refrigerator and freezer suddenly unable to cool
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 24, 2010 | GE Refrigerators
Making a clicking noise and not cooling
This could be a relay on the control board or the compressor is short cycling or both. You can use my assistance to help you resolve this or call a technician, this depends on you. I am very familiar with the Artica/Profile and know that if you can follow instructions and use a test meter we can get this fixed. I would like your complete model number so I can refer to the exact model you have. I will leave you contact information and a service manual and a web page to use with the diagnostics. This problem will not get better, Sea Breeze
Jan 26, 2010 | GE Profile Arctica Stainless Steel Top...
My GE refrigerator artica is not getting cold. The fan works, but it appears the compressor is not activating. The refrigerator is only 7 years old.
OK the Artica is complex in that a failure with the compressor not starting can be a series of effects that return to the mother board. I can from this end help you solve and or eliminate the problem with one on one cumunication. Most likely if the compressor is not starting the problem is a chain reaction of problems that have lead to this. I you would like my assitance let me know. But to give a simple answer for the Artica/Profile is not possible for even the best, Sea Breeze
Oct 23, 2009 | GE Refrigerators
My freezer (ge artica) temperature goes up to 40%, then cools dow
The main problem with the Artica/Profile is that they have a main control board and a thermostat board inside the fresh food compartment. I have a repair manual and will send you a copy if you want but we are going to have to look at the control boards for burn marks. Let me know if you need me. Thanks, Sea Breeze
Jul 15, 2009 | GE Profile Arctica Stainless Steel Top...
GE Profile Artica side by side stainless steel wont get cold
The Profile and Artica are good refrigerators. the problem may be the defrost element, defrost thermostat or the mother board. Let me know if you want help on this one. Thanks Sea Breeze
Jun 18, 2009 | GE Profile Arctica Stainless Steel Top...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
Ge Profile Freezer not working
Main pcb failure but just check the wireing at the bottom of the freezer door as it can affect the control system
Feb 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PSW26M Artica Cooling and Ice Maker Problems
on the back of the frig is a small rectangle panel. inside that panel is the motherboard that controls the whole refrigerator. thoughs boards have been nothing but trouble. one of the problems it causes when it goes bad is the problem your having. replace the board to fix it
Nov 29, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
613 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
