Question about Toshiba e-Studio 232 Black and White Copier
Paper jam One of the technicians said that it is due to the fuser roller is worn out. Do you think if I replace the fuser roller will solve the problem?
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 1,362 Answers
Very well could be,
1-if the plastic over the lower fuser is wrinkled torn or missing it will cause jams
2-if the top fuser roller is losing it's teflon coat also
when you do replace the roler/s change the claws also.
Posted on Aug 28, 2008
I have HP Laserjet M1005 printer. I have a paper jam problem at exit and bottam paper fold at fuser. pls solv my problem. thanx
Check for any obstructions inside the fuser, could be something stuck or could be the fuser film has worn out. If so you can replace just the film or the entire fuser. Should sort your problem out
Jul 14, 2016 | HP LaserJet M1005 Printer
Hp 4345 has error code 13.20.00 paper jam in tray 2 and also has a grinding noise by the fuser how can i fix it
The printer may need a "swing plate" replaced to solve the fuser noise. Remove the fuser and look at the black gear inside the printer on the left side. Do the teeth on that gear look worn ? If so that gear (swing plate) needs to be replaced. Its a hard job to do. Can you turn the fuser gears with it out of the machine without them skipping ? The tray 2 jam may just be worn rollers in tray 2 or a stuck sensor. Good luck !
Aug 06, 2013 | HP LaserJet M4345 MultiFunction Printer
Paper jams in heater
An overheated fuser is one of the most common causes of a paper jam. When large loads of print jobs are pushed through a printer, the fuser slowly starts to warm up. As the fuser warms up, the heat causes the corners of the printer paper to bend. The hotter the fuser gets, the more the paper bends. Eventually the paper bends so much that it causes the paper to get stuck in the fuser, causing a jam.
If you cannot find any other reason for a continuous printer jam, the problem may be the roller. A cracked roller can easily grab a piece of paper and get it caught. A glazed-over or dirty roller can also cause the paper to get caught on the roller and jam the printer. If the roller is cracked or glazed, you may need to call your print technician or replace the roller.
Mar 03, 2011 | Ricoh Aficio CL7000DTL Laser Printer
Paper cringling and jamming on print. Drum looks worn.
this sounds just like a worn out fuser. pull the fuser out and inspect the rolllers if the orange roller (the pressure roller) has bad wrinkling or if the shinny sleave of the roller has slid off to one side replace hte fuser
Mar 08, 2010 | Lexmark Optra T612 Laser Printer
Hello, my Brother MFC-7420 started a few months ago to wrinkle the sheets, like an accordion. a technician said is the fusor and another technician says it is the drum, which one is right?
The fuser is most likely your candidate. A drum transfers the image onto the paper, but the transfer is made with an electric charge. The fuser applies heat and pressure to bond the toner to the paper.
If the fuser rollers are worn or there's heavy buildup on them, they will cause the paper to skew, crease and/or jam.
In the case of the paper bunching up and looking like an 'accordion', if this happens at the entrance guide to the fuser assembly, you're pretty much guaranteed the fuser's either jammed or defective.
Sep 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper jam in fuser
Sounds like a timing jam, check paper supply, fanned, good quality, check and clean paper feed rollers.
Registration rollers clean?
If you are a tech, check and clean paper feed clutches, registration clutch. Check fuser for bearings, fuser drive, fuser roller cleaner or worn rollers.
Check exit sensor, is it out of place, is the actuator worn out, is the paper curling and coming off of the paper too early,
Try these, hope it is of some help.
Apr 23, 2009 | Office Equipment & Supplies
HP LJ P3005 13.31.00 ERROR
As i can understand whenever you try to print with rear door closed printed page should come on top from top output roller however paper gets jammed.
Try to print a page using rear door open and it should come out from the rear drop down tray it printed page comes out successfully with rear flap open than paper gets jammed at top due to faulty top output roller.
However if the paper gets jammed at fuser with rear door closed than it is issue with fuser in that case you need to get fuser replaced at the same time replace 20 tooth gear next to fuser.
Thanks and Regards
Neeraj Sharma
Apr 11, 2009 | HP LaserJet P3005n Printer
Hp 4100 paper is jammed between rollers the back panel should come off? and then how do I get fuser out to unjam paper
Hi Jacque,
I gather the paper has got into the fuser and cannot get into the output bin. Few things...
1. Clean output rollers. Are rollers moving?
2. Check gears on the fuser unit. Any broken or worn gears?
3. Check default paper size setting in printer, paper size setting on tray, paper size setting in printer driver and document page.
4. Leave the back door open. Does the printer still jams? If it does, see it could be paper pick up problem. Use different trays or the manual feed. Also the fuser unit could be the problem.
5. All else fails, replace the output assembly.
Dec 18, 2008 | HP LaserJet 4100 Printer
Paper Jam
If you are getting a lot of jams in the fuser then there is a problem in the fuser unit !
Is it jamming like an accordion? if Yes, then the problem is w/ the little fingers in the fuser, they are worn and need to be replaced. The rollers in the fuser should be shiny and smooth if not they ca also cause jams.
What black thingy are we talking about and where? if it's the fuser rollers ( where the paper exits and gets hot then try cleaning w/reg soap & water rag then wipe off.
Nov 17, 2008 | Sharp AR-153E Copier
Brother 4100e paper jam
Can be tricky people usally damage the fuser rollers removing this jam with pliers/tweezers, it has concertined and stuck after fuser rollers and before exit rollers it will be stuck on the switch best bet is to dismantle properly and remove fuser then dismantle fuser and remove jam, another thing to be concerned about is why did it, three seneraros, Damp paper going threw fuser dries and crincles(use fresh paper from sealed packet), fuser is worn(have fuser replaced), just a bad bit of paper (just have fuser jam removed. Fusrr runs on 240v, covers break easy
Oct 15, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Toshiba e-Studio 232 Black and White Copier Logo
78 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
