Question about Lexmark X1290 All-In-One InkJet Printer
Copy i am having problem copping,scaning or faxing. the buttons on the unit does not work. i just started using the unit this pass june i am able to print .
  • dkdaniel Sep 29, 2008
    I have tried re-installing the software and my all-in-one still will not copy or scan!
  • 109 Answers
See if you can start a scan from your computer. In your Start->All Programs->Lexmark 1200 Series folder, there should be the All-In-One Center or the Productivity Studio or some such software. You should be able to start a scan from there.
Steve
Posted on Sep 09, 2008
Hp m1536 scanning black
Replace CCD scanner head unit with flat cable...I think UR from india, you can get it in indian market..
Example image of scan head:
Aug 10, 2015 | HP LaserJet Pro M1536dnf Multifunction...
Tip
How to test, and setup the Fax machine on HP multifunctional printers.
Hi.
Please follow the instructions below to install and test the fax on an HP multifunctional unit.
1 - before connecting the printer install the software in the CD provided with the printer on the computer. The fax unit will also work in stand alone mode, but without installing the software you will not be able to control the unit from the connected computer.
2 - Have ready a phone cable. Ensure that the phone cable that you want to use has only two connectors:
3 - Connect one end of the telephone cord to the telephone jack andthen connect the other end of the cord to the socket labeled 1-Line on the back of the HP fax printer.
4 - The multifunction HP is now ready to send and receive Fax.
To send a basic fax:
1. Load your originals.
2. Enter the fax number by using the dial button on keypad.
3. Press START FAX Black.If the device detects an original loaded inthe automatic document feeder, it will send the document to the numberyou entered
If the Fax is not sending, then check that the original is loaded properly, then run the fax test following procedure below:
  1. press Setup
  2. select Tools
  3. select Run fax test
  4. press OK
Or:
  1. Load the original into the input tray.
  2. Press the Setup button (the one with a wrench) on the unit control panel.
  3. Press right arrow, select Tools, then press OK.
  4. On the Tools menu, press the right arrow to select Run Fax Test, and then press OK. The fax diagnostic test prints.
  5. Review the report.
If the test does not return ALL PASS , then setup the fax manually.
Change the HP fax settings
  1. Disconnect the telephone cord from the single-line telephone and then plug it into the port marked 1-Line at the back of the HP product.
  2. Press the Setup button (the one with a wrench) on the product control panel.
  3. Press the right arrow to select Basic Fax Setup or Advanced Fax Setup, then press the right arrow again to change settings to the settings listed in the table below.
After verifying Fax settings, try again sending a fax.
If still no luck, try calling the HP number listed on your user manual. In that case there may be a fault.
Also ensure that you do not have a VOIP phone rather than a landline phone, in that case setup will be completely different.
You can find driver software and manuals using the link below:
HP SUPPORT.
Regards.
on Feb 26, 2010 | Office Equipment & Supplies
Why our fax sending and receiving solid black
Its a problem with scaner unit. Reports are being printed out, and do not pass trough scaner, because of thath report is Ok.
If the fax is still under warranty, go to warranty provider service.
Next time dont buy "kids toy" for fax machine. Try laser Canon Fax L140.
May 20, 2010 | Canon FAX JX200 Fax / copier Plain Paper...
How to get it started to work. its because i have passed by cops before and it won't beep of anything and i really don't know how to operate it.
Make sure that the uint is in HIGHWAY mode. Is the unit reporting radar but is not making a sound or not reporting at all? You can do a factory reset too. Hold in the power and quiet buttons, while holding in these buttons,plug in the power cord, the unit should beep twice.
Jan 23, 2010 | 1595SE Radar Detector
How to do scannning
you can scanning application oftware.If it has no navigation key which use pc to scane.Only use application software.
Thank you very much for your requist.
Jun 08, 2009 | Samsung SCX-5115 Fax Machines
Not scaning
Hi m Harsh,
Try this, Go to start -- printers & faxes & delete all the files there except the basic fax .................
m sure this will work...........
byeeeeeee......
Apr 27, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Can not print the incoming fax as well as cannot copy a page
Hi
The scanner unit don't reach the scan possition.If you open the front cover,check and see if the is no obstruction in the scanner parth to flip down to the scan possition.Pull the scanner unit a few times foward down and backwards up.If that dont work the grease on the scanner clutch might cause the scanner not to go to scan possition.For service of that clutch you will have to take it to the Canon dealer.
Nov 12, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Gray line down middle of faxes/copies on panafax uf880
yes change a toner and clean the glass area under nearth the toner.
Oct 24, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
I am an owner of a machanical company and we have the Brother fax and printer MFC-9840CDW and do not know how to get the scaning part of it to work. Can you help?
The unit that you have has many functions ....copy, scan and print
Each of these functions is chosen by selecting the appropriate large rubber button with that picture on it
Are you able to use the other functions?
The software to manipulate the image scanned on this unit is limited, but the scan quality is very good.
Oct 07, 2008 | Heating & Cooling
Lexmark X1290 All-In-One InkJet Printer Logo
79 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
