Question about Behringer EUROPOWER EP1500 Car Audio Amplifier
Behringer ep1500 versus behringer eurolive b215 X 2- pa speakers.
I HAVE JUST PURCHASED THESE ITEMS BUT AM HAVING PROBLEM ON HOW AND WHERE ON THE AMPLIFIER TO CONNECT THESE SPEAKERS AND I HAVE A SPEAKON-SPEAKON CABLES FOR THE SPEAKER'S CONNECTION,PLEASE ADVISE ME.
    Problem Solver:
  • 19 Answers
The Amplifier will have wierd, notched, circular speakon cable connectors on the back, two, one for main left and one for main right. Press the button in on your speakon cable connector and twist it and lock it into place on the amplifer for right and left attachments, then do the same to your speakers.
Hopefully this helps.
Michael Lazar
http://www.AudioholicBlog.com/
Posted on Oct 03, 2008
Behringer B112D wont power up until 10 minutes after switching on
This will be a power supply problem. Take it in to your repair shop for service.
May 07, 2016 | Behringer Eurolive B112D Powered PA...
How do i change the woofer in the eurolive B215d..does the front screen pop out
Yes, the front screen should just be a compression fit. Something a bit stronger than a paperclip should work fine to pull it out. Work around the edges.
Jan 18, 2015 | Behringer Eurolive B215DWH 550W 2Way PA...
Where can I dowload the user manual
Here is the link to that manual.
http://www.behringer.com/EN/Products/B212D.aspx
Jan 02, 2015 | Behringer Eurolive B212A Speaker
Th lights on rare of the speaker are blinking no sound
I had two of these units fail exactly the same way. The amplifier assembly is the failing part.
If it's out of warranty, then you will need to order a replacement. Don't bother with Behringer support, they aren't helpful. I recommend a place called The Tone Garage. They have said they can order replacement amplifier assemblies in about 4 weeks.
Here is the link:
Eurolive B115D Powered PA Speaker
Apr 23, 2014 | Behringer Eurolive B115D Powered PA...
My speaker is shutting off randomly when hooked up to a mic
This problem has happened to others. If you purchased it new, Behringer will repair or replace it.
Feb 20, 2014 | Behringer EUROLIVE B212D Active PA Speaker...
Behringer b212d hums loudly
If it's only on one side, then you may have a defective cable within the system. That would be my first guess. If both sides hum, then an improper ground could be the culprit.
Oct 08, 2012 | Behringer EUROLIVE B212D Active 550-Watt...
I want to order a new volume pot for my Eurolive B215A powered speaker directly from Behringer, then fit it myself. Who do I contact to order the part?
Lots of luck. Behringer no longer sells direct. Fullcompass.com is their parts distributor. If they don't have it in stock, it takes months... I have had an order in for 6 months now. The procedure is you call Behringer at 1-425-672-0816 to get a part number and an incident type number. Then call Fullcompass and order the part at 1-800-356-5844 and tell them you need Behringer part. IF they have it in stock, then you are lucky.
May 18, 2011 | Behringer PA speaker Eurolive B212A
Behringer EUROPOWER EP1500 Car Audio Amplifier Logo
232 people viewed this question
Top Behringer Car Audio & Video Experts
xxxxxx xxx
Are you a Behringer Car Audio and Video Expert? Answer questions, earn points and help others
