U either have a leak in the air level system or a bad check valve in the system...when u turn off the truck the pump stops an the air leaks out...when i start the truck the auto level system turns on the air pump an fills it back up...have this serviced asap since it can burn out the air pump an the pump is many hundreds of dollars to replace
This is not normal.you could have a pressure hold valve that isn`t holding pressure when the car is shut off causing this or something in the system causing it,and when you start the car the compressor starts and pumps up and the ride height returns.these are difficult systems to find the problem so i would suggest you take it to shop that can do this type of work or the dealer and get it fixed.
