Question about HP iPAQ H5450 Pocket PC
HP 5450 screen not responding
Anyone had this problem befor.. All was well, and then one day the PDA starts this. The screen saver I had on it appears to be gone as well. On sign in, will nothing but the top rom , 123 appaers to work, and I think it is selecting 2 no mater what number you are using with those three choices. Desperate to get this resolved, any help would be much appreciated.
    Master:
  • 450 Answers
Try holding the stylus in the soft reset hole for about 5 seconds.
Posted on Sep 07, 2005
SOURCE:
How to change screen saver on hp mini
Hi Iosherrera,
I see that you are tying to change your screen saver on you HP mini 210-2160NR.
* Your HP mini 210-2160NR has Windows7 Starter Edition installed,
* click on start you will see a search bar type in screensaver,
* then choose Change screen saver,
* the Screen Saver Settings windows will appear on your screen, select the screen saver you desire then click on Apply then OK, this is where you can change your screen saver settings instead of going to personalize.
Windows7 starter edition does not have functions like the other window7 version but the above instructions are a work around to personalize your Windows7 starter.
I hope that this will answer your query regarding how to change your Screen Saver on your HP mini 210-2160NR, have a nice day.
Apr 11, 2011 | HEWLETT-PACKARD HP Mini Lavender Rose...
My ipaq 214 wont boot up. it just freezes on the HP screen. Ive tried pressing the reset button like over 100 times but it just freezes again. Ive also tried hard reset and that dosent work either. I have...
You could have a corrupted program on your PDA. You need to contact HP and have them re-flash or upgrade the firmware of your PDA and it should work much better than before.
Have a great day!
Oct 11, 2009 | HP iPAQ 214 Pocket PC
My pda hp 4700 won't turn on. It's about 3 years old
Assuming that the switches on the bottom case are in the correct position. Try reflashing with original HP rom:
http://wm6.winmobile.us/hpmain.htm
May 27, 2009 | HP iPAQ HX4700 Pocket PC
Touchscreen problems (HP RX or HX series)
If I understand correctly your problem, the touch screen of your PDA is not working.
Well, this is a common IPAQ failure. When happens, the only options to repair it are:
1. Soft reset of the PDA. If still does not work, then go to next step.
2. Replace the top digitizer glass.
It requires a very skillful person to do it. If you have not experience with fixing electronic devices, then I do suggest you to send it to repair.
Besides that is necessary to open it, you will require a soldering iron, and desolder the digitizer part and remove it from the LCD screen, which if is not done properly with the right tools, it's easy to damage the LCD screen assembly.
Also, if it's not opened right, is possible to damage permanently the mainboard if is bent or warped.
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3715 (or RX3115) PDAs.
I have nothing against Chinese manufactured parts, but after buy around 10 digitizers in the last couple of years for different Ipaq PDAs, I found out that only 3 worked fine, so I know what I am talking about.
Best regards,
May 25, 2009 | HP iPAQ HX2110 Pocket PC
Dropped PDA
You don't have to crack the screen if it is LCD. The "bleeding into the screen" and "black lines" could be symptoms of leaking liquid from the damage/impact of being dropped. Where you send it for repairs would depend on the manufacturer, the store you bought it from, and if you have a service plan or not.
Let us know what the situation is.
Dec 30, 2007 | HP iPAQ RX3115 Pocket PC
Bogdan, could you give me a solution to contact you about this PDA? Give me your email adress or your cell phone number (mine are tiby_olimp@yahoo.fr and 0746761410)
Jun 09, 2007 | HP iPAQ RX3715 Pocket PC
Dropped PDA
First of all, you must dissasemble the pda if you have some experience with that. There are some possible problems, one regarding the display connector to the motherboard and the other to the motherboard itself.Probably the display connector isn't atached firmly to the motherboard. There is a worse scenario where you may accidentaly burned some dc convertors on the mainboard when attemting to power on after the pda was dropped. If you can, dissasemble the pda, check the connectors, remove and reconect the back-up battery, and then, just to be shure, perform a hard reset.
Jan 11, 2007 | HP iPAQ rx1950 Pocket PC
Jeode on PDA
relic day, we put these in the trash here, its mostly useless.
in today's world.
no country stated, my guess not in usa on this usa forum.
we have no service here on that relic .
why not ask HP this, not fixya, we are not HP.
why not go there and get them to laugh and cringe and cry.
on this old dog PDA.
here is the real HP, not fake, not spam the REAL DEAL HP.
drum roll......... snare drum rim shot....
https://h30434.www3.hp.com/
Nov 10, 2017 | HP iPAQ RZ1715 Pocket PC
Visual Studio.NET on PDA
The PDA uses the Compact .NET framework. You develop with Visual Studio .NET on the PC - just start a new Smart Device Project (select Pocket PC, not Windows CE in the second screen)
Sep 14, 2005 | HP iPAQ h6315/h6365 Pocket PC
Screen saver
go to Start > PROGRAMS > Dockware. Now click on the top left hand corner of screen. Click on 'Setup' to uncheck the box to Automatically start Dockware.
Sep 08, 2005 | HP iPAQ HX4700 Pocket PC
HP iPAQ H5450 Pocket PC Logo
71 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
