Question about Palm VIIx Handheld
Connection problems between handheld and computer
I do a hotsync. The box comes up and says "Connecting to handheld", the second handheld picture is "grayed=out" and then a get an error that says it lost connection. I have changed cradles to see if that is the problem and that doesn't seem to fix it.
4 Suggested Answers
  • 473 Answers
SOURCE: Connection is lost (6410)
As previously stated a 6410 error is a comunication error between your Palm and your computer. Uninstalling and reinstalling Palm desktop will do nothing to rectify your issue. You say it stops on recognizing handheld. Do you have another Palm connect USB adapter to try or another computer that has COM ports on it so you can perform a serial HotSync? Under the current configuration you will not be able to perform a complete synchronization. You have a week connection between your Palm and your computer.
Posted on Sep 12, 2005
SOURCE: Hotsync (on its own) Problem
i have fixed this issue.
you must open up the phone a little ... with a soft tooth brush and clean around the connectors ... you probably spilled something and some rust has made a connection across some of the bus lines near the bottom of the device.
also clean near the bottom on the circuit board almost immediately right next to where the battery is.
Posted on Apr 09, 2008
rwandrew
  • 115 Answers
SOURCE: Palm Vx will not Hot Sync
Great news!!! Glad you are set...
Posted on Jan 28, 2009
SOURCE: Hotsync
I am having the same issue and can't find the solution anywhere online.
Posted on Oct 15, 2009
0 characters
1 Points
Unable to connect with desktop through usb cable
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Palm Desktop 6.2 & Hotsync manager (windows) cannot ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
Jan 03, 2016 | Palm TX Handheld
Can't sync my palm z22 to my computer
I had this problem recently and once I checked all of my settings, and adjusted a couple, it worked fine. To do that, on the desktop computer, open Palm Desktop and go to HotSync and then, under that is Setup. When the set up window opens, click on connections and be sure the type of connection you use is selected. In my case, I use the USB cable. Close that window. On the handheld, click on the hotsync image and be sure the connection method matches what you set up. Local or modem are your choices. My selection is local. Go to Preferences on the handheld and select Communication. Select connection and a window opens.From that list, I selected cradle/cable. Hopefully that will work for you. Try doing a hotsync at that point, and see if the problem is fixed. Mine was.
Jun 24, 2010 | Palm Z22 Handheld
Hotsync
Jul 06, 2009 | Palm Treo 755p Smartphone
I am unable to HotSync and cannot load HotSync manager
Reinstall Hotsync manager and make sure selected port is correct. Use alternate method to sync like Infrared
May 29, 2009 | Sony CLIE PEG-TJ37 Handheld
Can't get device to hotsync
First thought is that the cable has become defective - they do go wrong.
Assuming the visor is fine other than when hotsyncing, I suggest you reinstall the Desktop manager and hotsync manager on your PC or Mac, HAVING BACKED UP ALL FILES of course.
Sometimes the managers get corrupted and cause problems. Try that first, then check cable and finally a hard reset, assuming you have hotsynced recently and so won't lose loads of information.
May 21, 2009 | Handspring Visor Deluxe Handheld
I reinstaled the Palm Desktop again it worked....
Sep 20, 2008 | Sony CLIE PEG-TJ37 Handheld
Selected com port not available
Please un-install and re-install the software,, that should fix the problem,
Jun 09, 2008 | Palm Treo 755p Smartphone
Feb 07, 2008 | Palm Treo 650 Handheld
Hotsync problem
With a USB 1.1 machine .. try this ...My work around - disconnect ALL USB devices from the computer, NO multiport hubs, make a direct USB connection to one of the available open ports, then reboot the computer. Upon gaining control, then try to hotsync. If I had any other items connected or ran any other programs prior to hotsync, I was not able to perform a successful hotsync. The qwerks of the T5 and the sync conduits. Hope this helps Bob
Aug 09, 2007 | Palm TX Handheld
First open the HotSync custom menu, start changing conduits to do nothing. Work your way down the list until you end up with a complete HotSync. If you still have the 6410 error, unplug the USB adapter, replug and try your HotSync again. The USB adapter may be the week link in this equation.
Sep 12, 2005 | Palm IIIe Special Edition Handheld
Palm VIIx Handheld Logo
15 people viewed this question
Top Palm PDAs Experts
MUSTAFA BULENT...
MUSTAFA BULENT...
David Payne
David Payne
Nataly Roberts
Nataly Roberts
Are you a Palm PDA Expert? Answer questions, earn points and help others
