Question about Car Audio & Video
My car sound system start crackaling when i turn it up. the sub sound fine but my 6x9s crackal and my standard door speakers. p.s only just starting doing it
    Novelist:
  • 100 Answers
Sorry to say but if your speakers crackle when you turn them up you need to not turn them up so much or buy new ones. That crackling sound is a blown speaker. It could also be a bad connection but most likely blown or under-driven speakers. Good luck.
-Andrew Hawkins
Posted on Aug 27, 2008
Crackaling with in wall sub
Could be a burnt resistor or faulty power transitor.
Dec 16, 2012 | Audio Players & Recorders
I have my computer monitior hooked up to my polaroid flat screen tv. Worked fine for a while, then got a blue screen that says "not support". It has also been making a loud screech and a crackaling noise....
The 'NOT SUPPORT' message is due to the video signal resolution form your PC is too high for the TV to display, you need to set your PC video resolution to the native resolution of this TV.
Loud screeching sound may be causing by failing amplifiers if it comes through the speaker or may be from the power supply module due to bad/dying DC filter caps.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Sep 01, 2010 | Polaroid Televison & Video
I have everything hooked up just as the schematics say and have sound from my front speakers but nothing from the back 6x9's or the subs?
well let me start by saying your trying to power way to much on this little amp you should be using a 5 channel if you wanna do all that try just hooking up the front speakers and 6x9s
Mar 28, 2010 | Rockford Fosgate Punch 201S Car Audio...
How to hook it up to system with two 10s 400 watts per sub and two 6x9s at 200 watts each?,subs behind seats, 6x9s in doors. IF i need another amp i have one,to help push. But either way i need your help...
Hello www_mitzjohn,
I'd definitely use another amp.
The 2-channel Sony is well suited for powering the 6X9's but a monoblock would be better for the subs. The different types of speakers running from the same channel will not sound very good and likely it'll be impossible to get the impedances to match.
You'll want to set the Sony to send higher frequencies to the 6X9's, but not to the subs. You can't adjust the channels individually. So, just connect each 6X9 to one channel of the Sony and use a monoblock subwoofer amp for the subs.
Hope this helps.
Oct 31, 2009 | Sony XM-2150GSX Car Audio Amplifier
Sound Problem
the audio amp inside the main module is fried. It needs to be replaced, make sure you get the exact numerical match for the circuit board. and inspect the flip side for no signs of burnt cicuits. replace that, and you will no longer have problems.
Dec 09, 2008 | Dell W2600 26 in. LCD Television
Sound System Does Not Sound Good from Laptop
UMM mell if its making a crackaling sound i hate to say either your sound system is broken or cant handle the song or the clrackiling is in the song its self..... maybe be into your comuter control pannel u might be able to play witht he bass and all to see what it can and cant handle but thats about it sorry, also make shure everything is in the right jack and all.....
Oct 05, 2008 | ASUS Computers & Internet
Starting up samsung x05
sounds as if you have a motherboard problem. If you are not comfortable in taking the bottom half of the case to see if that "crackaling noise" was.. then you can send it into samsung for repairs and estimate. If you are comfortable, first put your nose near a heat vent and see if it smells funny, like a little bit burnt. if so, its a gonner. You can look around once you remove the bottom pannals for burn residue or any signs of problems and report back if you need further assistance
Sep 11, 2008 | Samsung X05 Notebook
Speaker installment
I would run a 250-500 watt 2 channel high input capable amp.  run the original wires to the orginal speakers and jump off the original wires to the amp to push the secondary 6X9's you have.  So my understanding is.  you want the 4 original speakers and subs and add 2 additional speakers making 6 speakers not uncluding subs..
Head units care barely push 4 decent normal size speaker.  Usually they are 30-55watt per channel.  If you have 2 non sub speakers that are 250 watt max.. that's 500 total but don't push the amp all the way...start with it at 1/4 and listen to your stereo at a higher than nominal volume slowly turning up the amp.
James Mac
Sep 09, 2008 | JBL LC-S960 Car Speaker
Motorcyle installation
Hi 1 2fade,
The market in Motorcycles, especially Harley Davidson pushes for helmet speakers. You cannot possibly get good sound when riding with externally mounted speakers. Only when sitting at an event will give you decent sounds. You probably already know this. I suggest pioneer Marine grade equipment, and a premium brand of Marine grade. I also suggest you gett a Helmet set so you can enjoy great music while riding if you dont already have it.
Nov 22, 2007 | A D S 346im Coaxial Car Speaker
Car Audio & Video Logo
108 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
